Cummins Engine Codes? #2872312
01/10/21 10:47 PM
01/10/21 10:47 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
What's this going to cost me?
P22B5 -O2 Sensor 1/2 Pump cell current Trim cut open
P2000 -Nox Absorber efficiency below threshold Bank1
Re: Cummins Engine Codes? [Re: Dragula] #2873463
01/12/21 11:25 PM
01/12/21 11:25 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
DELETE!! that what it means!
Look under the passenger side outer frame rail in the location of the O2 module.... does it appear that the O2 wiring harness has an overlay harness? Usually IDed by extra wiring zip tied to existing wiring. If it looks bone stock, I see a wiring harness overlay, the updated O2 sensor module, and a pair of o2 sensors in your future.... I’d also want the pcm at the latest flash update. God I hated that era of Cummins.... Those things had to WORK to be happy. Definitely wasn’t daily driver short trip material.
Re: Cummins Engine Codes? [Re: J_BODY] #2874474
01/14/21 08:33 PM
01/14/21 08:33 PM
Alberta
440_Offroader Offline
Alberta
This... sawzall
I had a 2011 and was getting 8mpg. Deleted dpf, egr and added a tuner. Got 14mpg and way more power!
Re: Cummins Engine Codes? [Re: 440_Offroader] #2874550
01/15/21 12:07 AM
01/15/21 12:07 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
This... sawzall
and let’s not over look extended oil change interval too! No more fuel polluted crankcase smile
