old hemi info needed #2873329
01/12/21 06:22 PM
01/12/21 06:22 PM
Lee Co. Fla.
5carguy Offline OP
5carguy  Offline OP
Lee Co. Fla.
I have an old hemi engine.I think it's a 392.Only numbers I can find are CE5732182.Can someone tell me what this is?
TIA
Re: old hemi info needed [Re: 5carguy] #2873395
01/12/21 08:48 PM
01/12/21 08:48 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
CE57 looks to be a '57 392 out of an Imperial. Hot Hemi Heads is the resource for the early stuff.
http://www.hothemiheads.com/
Re: old hemi info needed [Re: Jim_Lusk] #2873398
01/12/21 08:55 PM
01/12/21 08:55 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
I second that!
When I was into the older Hemi stuff, that was the place for info.
My Monster are real!
Living within your means makes life pretty easy.
Re: old hemi info needed [Re: 5carguy] #2873733
01/13/21 01:12 PM
01/13/21 01:12 PM
Sonora CA
Mopar_Rich Offline
Mopar_Rich  Offline
Sonora CA
Check out chapter one of my HEMI book: How to Build Max-Performance HEMI Engines.
Re: old hemi info needed [Re: Mopar_Rich] #2873765
01/13/21 01:38 PM
01/13/21 01:38 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
IIRC, you can tell the difference between 354 & 392 by deck height.
Visible from outside by the height of the deck vs. water pump.
354 & 392 each have their fan-base.
Re: old hemi info needed [Re: topside] #2873803
01/13/21 02:35 PM
01/13/21 02:35 PM
All the early Mopar V8 have their year and brand in the serial number stamped onto the right front edge of the lifter valley beside the passenger head scope
You do need the translation codes to understand them also so maybe Hot Heads has that info on their web site luck scope
Re: old hemi info needed [Re: Cab_Burge] #2953522
08/13/21 05:36 PM
08/13/21 05:36 PM
Ft Worth Texas
desotodude Offline
desotodude  Offline
Ft Worth Texas
67 vertman is right. hot hemi heads have a few list you can get information from. first two numbers indicate the year. The only thing I have never found is the list that tells you what vehicle it came out of specifically. Maybe 67 vertman will tell us his secrect for that!! Go to Facebook and search groups. there is one called old Hemi's and another you need to get with called first gen hemis and also first second hemis.
Re: old hemi info needed [Re: desotodude] #2953537
08/13/21 06:32 PM
08/13/21 06:32 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
CE57 is a '57 392 out of an Imperial - per the Hot Heads index
Re: old hemi info needed [Re: Stanton] #2953760
08/14/21 03:54 PM
08/14/21 03:54 PM
moparx Offline
moparx  Offline
as i understand, weren't all 392's cast and assembled in 1957 ?
beer
Re: old hemi info needed [Re: moparx] #2953777
08/14/21 04:36 PM
08/14/21 04:36 PM
beer
Nope, cast and assembled in 1956, 1957 and 1958 scope
Re: old hemi info needed [Re: Cab_Burge] #2954265
08/16/21 12:53 PM
08/16/21 12:53 PM
moparx Offline
moparx  Offline
i remember hearing or reading that somewhere, and it stuck in my feeble brain for some reason.
now i will have to search out where that baloney came from. if/when i find that, i will post it.
thanks Cab ! bow
beer
Re: old hemi info needed [Re: moparx] #2954279
08/16/21 01:28 PM
08/16/21 01:28 PM
The 1956 C.I. 354 Hemi passenger car motors where used for one year only, they were cast and assembled in 1955 and 1956 but only installed in the 1956 Chryslers and Imperials shruggy
Re: old hemi info needed [Re: Cab_Burge] #2954310
08/16/21 02:38 PM
08/16/21 02:38 PM
moparx Offline
moparx  Offline
i was just going on what i heard/saw about the 392 blocks so ? shruggy
if i can find that, i will post the source. it may have been related to the single shaft rocker setup being introduced in 1959, chrysler's projections of how many 392s would be needed for the 1958 model year cars, plus marine and industrial needs for ?? years in the future.
beer
Re: old hemi info needed [Re: moparx] #2954368
08/16/21 05:21 PM
08/16/21 05:21 PM
As far as I know Chrysler never used the 392 motors in any thing other than their productions cars in 1957 and 1958.
The marine, industrial, and larger(5 ton+) truck hemi motors were all 331 or 354 is what I remember and seeing in use back in the days long gone by scope
Re: old hemi info needed [Re: Cab_Burge] #2954655
08/17/21 01:05 PM
08/17/21 01:05 PM
moparx Offline
moparx  Offline
thanks Cab. i'm glad you are here to keep the record straight ! bow
i wish you were closer, as i have the desire to build one of the 392's on my shelf before i croak, and you would be a great help in me doing so ! up
beer
