My world aluminum block showed up!
#2872598
01/11/21 03:10 PM
01/11/21 03:10 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I had it shipped directly to my machine shop, and in the excitement forgot to take pictures. BUT i did get and extra flyer in the box so hear are three pics with info.
Re: My world aluminum block showed up!
[Re: gregsdart]
#2872601
01/11/21 03:11 PM
01/11/21 03:11 PM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Congrats!! How long did fulfillment take? That's an interesting detail Mitchell continues to market the GM trans provision, after Mopar dumped it (on the iron). Very different products.
Rich H.
Esse Quam Videri
[Re: Clanton]
#2872630
01/11/21 03:45 PM
01/11/21 03:45 PM
Posts: 7,497 Minnesota
Hemi_Joel
Minnesota
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2872677
01/11/21 04:16 PM
01/11/21 04:16 PM
Posts: 10,044 MN
JERICOGTX
MN
Congrats Greg! Who is doing the machine work?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2872682
01/11/21 04:22 PM
01/11/21 04:22 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
nice to see they are shipping
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: JERICOGTX]
#2872741
01/11/21 05:39 PM
01/11/21 05:39 PM
gregsdart
Congrats Greg! Who is doing the machine work? I will definately start a build thread, but not sure if i will dyno it, since it will be identical to the iron block build i dynod in june. It will be a 549 cube motor, 4.500 bore with 4.315 stroke. I got to 4.315 stroke by offset grinding my Crower 4.15 center weighted crank to 2.2 bearings. Heads ,cam and intake will be the same. 440-1, 3x intake, Terminator injection methanol, and 285/296/114 .867 and .800 lift using Jesel 1.7 rockers. R&R is doing the machine work.
[Re: Cab_Burge]
#2872803
01/11/21 07:25 PM
01/11/21 07:25 PM
gregsdart
I've ran both types of cam drives but not back to back on the same motor with exactly the same cam timing, both worked well My new almost all out motor will be similar yours, 4.500 bore x4.375 stroke in a Koleno high nickel cast iron block with a set of fresh B1-MC heads and around 15.0 to 1 compression on E85 with two Dominator carbs on a sheet metal tunnel ram, hoping for 1000 HP + at or near 8000 RPM Cab i bet you will be closer to 1100 hp with a real stout cam. Cam specs?
[Re: gregsdart]
#2872842
01/11/21 08:31 PM
01/11/21 08:31 PM
Posts: 43,283 Bend,OR USA
Cab_Burge
I bought the B1 cam from Dave Koffel several years ago before I bought the B1-MC heads, not sure if I will use it or get one for the motor with the B1-MC heads I order a KB aluminum 4.500 bore RB block several years back and got it last summer and now may not use it for myself, I'm thinking of building as a 572 C.I. pump gas motor with the B1 heads I have now to sell, hoping on making over or near 800 HP on Oregon pump swill with those parts
