Page 1 of 3 1 2 3
My world aluminum block showed up! #2872598
01/11/21 02:10 PM
01/11/21 02:10 PM
gregsdart Offline OP
I had it shipped directly to my machine shop, and in the excitement forgot to take pictures. BUT i did get and extra flyer in the box so hear are three pics with info.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
Re: My world aluminum block showed up! [Re: gregsdart] #2872601
01/11/21 02:11 PM
01/11/21 02:11 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Congrats!! up
How long did fulfillment take?
That's an interesting detail Mitchell continues to market the GM trans provision, after Mopar dumped it (on the iron). Very different products.
Rich H.
Esse Quam Videri
Re: My world aluminum block showed up! [Re: ZIPPY] #2872607
01/11/21 02:19 PM
01/11/21 02:19 PM
I am not sure how long, as Todd Marsh ordered two on his dime and i put my name on one of them mid december?
Re: My world aluminum block showed up! [Re: gregsdart] #2872611
01/11/21 02:23 PM
01/11/21 02:23 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Not bad at all up
Rich H.
Esse Quam Videri
Re: My world aluminum block showed up! [Re: gregsdart] #2872615
01/11/21 02:33 PM
01/11/21 02:33 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
congrats, and I am sure it will make you a lot of power and fun. I bought one several years back, one of the best investments I ever made for my drag car.
Re: My world aluminum block showed up! [Re: gregsdart] #2872619
01/11/21 02:37 PM
01/11/21 02:37 PM
tboomer Online content
tboomer  Online Content
That's pretty cool Greg! Going to start a build thread? wave
Re: My world aluminum block showed up! [Re: gregsdart] #2872623
01/11/21 02:40 PM
01/11/21 02:40 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I bet it is a big relief to have it in your hands.Good for you!
Re: My world aluminum block showed up! [Re: Clanton] #2872630
01/11/21 02:45 PM
01/11/21 02:45 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Nice! Is it a Hemi?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: My world aluminum block showed up! [Re: Hemi_Joel] #2872677
01/11/21 03:16 PM
01/11/21 03:16 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Congrats Greg! Who is doing the machine work?
69 GTX 68 Road Runner
Re: My world aluminum block showed up! [Re: JERICOGTX] #2872682
01/11/21 03:22 PM
01/11/21 03:22 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nice to see they are shipping
Tex
New best ET 10.259@129.65 .
New best MPH 130.94
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: My world aluminum block showed up! [Re: tex013] #2872704
01/11/21 03:50 PM
01/11/21 03:50 PM
Tampa FL
BillR1212 Offline
BillR1212  Offline
Tampa FL
Looks good - can't wait to see the build. I'm eyeing one for my Christmas list next year.
Re: My world aluminum block showed up! [Re: JERICOGTX] #2872741
01/11/21 04:39 PM
01/11/21 04:39 PM
I will definately start a build thread, but not sure if i will dyno it, since it will be identical to the iron block build i dynod in june. It will be a 549 cube motor, 4.500 bore with 4.315 stroke. I got to 4.315 stroke by offset grinding my Crower 4.15 center weighted crank to 2.2 bearings. Heads ,cam and intake will be the same. 440-1, 3x intake, Terminator injection methanol, and 285/296/114 .867 and .800 lift using Jesel 1.7 rockers. R&R is doing the machine work.
Re: My world aluminum block showed up! [Re: BillR1212] #2872742
01/11/21 04:40 PM
01/11/21 04:40 PM
MD
JACK1440 Offline
JACK1440  Offline
MD
Nice.... I have me one of them. Nice block.
Re: My world aluminum block showed up! [Re: gregsdart] #2872788
01/11/21 05:49 PM
01/11/21 05:49 PM
you may be surprised on the differences in the dyno testing results with the only parts differences is the block material, I would love to see that also scope Please up luck
I know the only thing that really matters is the time slip and the owner liking the new block or not up work
Re: My world aluminum block showed up! [Re: Cab_Burge] #2872797
01/11/21 06:09 PM
01/11/21 06:09 PM
Cab, got rid of the gear drive, going to a belt drive, so there is that change.
Re: My world aluminum block showed up! [Re: gregsdart] #2872800
01/11/21 06:16 PM
01/11/21 06:16 PM
I've ran both types of cam drives but not back to back on the same motor with exactly the same cam timing, both worked well up
My new almost all out motor will be similar yours, 4.500 bore x4.375 stroke in a Koleno high nickel cast iron block with a set of fresh B1-MC heads and around 15.0 to 1 compression on E85 with two Dominator carbs on a sheet metal tunnel ram, hoping for 1000 HP + at or near 8000 RPM luck
Re: My world aluminum block showed up! [Re: gregsdart] #2872801
01/11/21 06:17 PM
01/11/21 06:17 PM
Windsor ,Ca.
K
Keith Richards Offline
K
Windsor ,Ca.
Ours has been in this car for about 6 years now, can hear the gear drive pulling through the water box, funny how the camera picks up that sound. 572" - 11/1 compression on pump gas.
https://www.youtube.com/watch?v=BInq18SSVrU
Re: My world aluminum block showed up! [Re: Cab_Burge] #2872803
01/11/21 06:25 PM
01/11/21 06:25 PM
Cab i bet you will be closer to 1100 hp with a real stout cam. Cam specs?
Re: My world aluminum block showed up! [Re: gregsdart] #2872842
01/11/21 07:31 PM
01/11/21 07:31 PM
I bought the B1 cam from Dave Koffel several years ago before I bought the B1-MC heads, not sure if I will use it or get one for the motor with the B1-MC heads confused
I order a KB aluminum 4.500 bore RB block several years back and got it last summer and now may not use it for myself, I'm thinking of building as a 572 C.I. pump gas motor with the B1 heads I have now to sell, hoping on making over or near 800 HP on Oregon pump swill with those parts luck
Re: My world aluminum block showed up! [Re: gregsdart] #2872873
01/11/21 08:33 PM
01/11/21 08:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Congrats on the new bullet.
R&R did my W-9's and I was very happy with the work and the price.
Looking forward to seeing this one make some noise !
Page 1 of 3 1 2 3
