1969 Plymouth B body rear window seal
#2870579
01/07/21 05:58 PM
01/07/21 05:58 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Is it supposed to have a gasket or not?
I was always under the impression there was only sealer/no gasket was used on the 1969 Plymouth B body rear window.
You can imagine my surprise when, after 30 years of ownership I popped the back window out of my '69 GTX to find it installed with a gasket under it, but spacer blocks/sealer on top of it.
Was that a hacked installation/some slob's idea of a repair, or were any of them actually made that way?
My thinking: If it's supposed to have a gasket, it's a little odd that nobody sells one.
(I haven't got as far as checking glass date codes, but that might help explain part of it)
thanks
Rich H.
Esse Quam Videri
Re: 1969 Plymouth B body rear window seal
[Re: NITROUSN]
#2871149
01/08/21 02:57 PM
01/08/21 02:57 PM
ZIPPY
S.E. Michigan
Thanks for confirming. Maybe some repair shops idea of an improvement
Rich H.
Esse Quam Videri
[Re: Stanton]
#2871281
01/08/21 07:03 PM
01/08/21 07:03 PM
Posts: 18,409 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
They did use a gasket and I believe they're still available from a windshield installer. They only used spacer blocks for the gap at the bottom between the dutchman panel. No they did not use a molded rubber seal. Butyl is all they used on the rear. Front did use a molded rubber locking style seal.
[Re: TJP]
#2871491
01/09/21 09:16 AM
01/09/21 09:16 AM
Posts: 1,383 Az
69hemibeep
Az
The 3M tape comes with spacer blocks
1969 Hemi Roadrunner 2nd owner
[Re: NITROUSN]
#2872657
01/11/21 04:00 PM
01/11/21 04:00 PM
Posts: 2,367 Wheatfield, NY
Cuda340
Wheatfield, NY
They did use a gasket and I believe they're still available from a windshield installer. They only used spacer blocks for the gap at the bottom between the dutchman panel. No they did not use a molded rubber seal. Butyl is all they used on the rear. Front did use a molded rubber locking style seal. THIS IS CORRECT. Butyl tape, no gasket. I guess the factory used 3/8" butyl tape. But you will NEVER get the moldings back on. That's why 5/16" is recommended. Yes the 3M kit comes with the spacer blocks. Its about 20 bucks at NAPA. make sure you get the 3M kit not the house brand kit.
