A12 wiring to solenoid #2868610
01/03/21 07:29 PM
01/03/21 07:29 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Is the wiring to the solenoid a separate wire or does it come out of the wiring harness? I ordered my harness from year one and it has no wire in the harness, unless they sent the wrong one.
Re: A12 wiring to solenoid [Re: fastmark] #2868633
01/03/21 08:46 PM
01/03/21 08:46 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
The "high idle" solenoid wire is completely separate from the wiring harness. There is also a plastic clip with self adhesive backing to adhere to the driver's side valve cover to keep it away from the throttle linkage.
Re: A12 wiring to solenoid [Re: A12] #2868641
01/03/21 09:04 PM
01/03/21 09:04 PM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Zone in on this vintage pic.
68 Charger
70 Cuda
Re: A12 wiring to solenoid [Re: fastmark] #2868645
01/03/21 09:15 PM
01/03/21 09:15 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Factory B&W media photograph:
MikeR
Re: A12 wiring to solenoid [Re: A12] #2868764
01/04/21 09:06 AM
01/04/21 09:06 AM
Dallas, Texas
FC7cuda Offline
FC7cuda  Offline
Dallas, Texas
Btw, I have a 69 solenoid I’ll trade for a 70 if anyone has/needs.
68 Charger
70 Cuda
Re: A12 wiring to solenoid [Re: FC7cuda] #2868796
01/04/21 11:31 AM
01/04/21 11:31 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What number are you looking for, preferably the Delco-Remy number and not the Chrysler PN (the DR number is stamped on the solenoid). Also, are you looking for NOS or used operational?
Re: A12 wiring to solenoid [Re: fastmark] #2868817
01/04/21 12:05 PM
01/04/21 12:05 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I thought that a separate wire goes from the ballast resistor to the solenoid.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: A12 wiring to solenoid [Re: 70sixpkrt] #2868844
01/04/21 01:14 PM
01/04/21 01:14 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Back of the alternator IIRC....
Re: A12 wiring to solenoid [Re: DAYCLONA] #2868877
01/04/21 02:33 PM
01/04/21 02:33 PM
A727Tflite Offline
A727Tflite  Offline
Neither - goes to the voltage regulator.
Re: A12 wiring to solenoid [Re: A727Tflite] #2868904
01/04/21 03:41 PM
01/04/21 03:41 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Photos from low mileage "survivor" A12 Bees" (each less than 7k miles at the time of photos)
Re: A12 wiring to solenoid [Re: A12] #2869002
01/04/21 06:35 PM
01/04/21 06:35 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
Ok. I bought the coil wire but I did not get the solenoid wire. Where do you get the solenoid wire from?
Re: A12 wiring to solenoid [Re: fastmark] #2869048
01/04/21 07:26 PM
01/04/21 07:26 PM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
Megaparts carries most or all of the M&H wire harnesses..
