Re: 68 Charger 3 on the tree [Re: 6PakBee] #2866723
12/30/20 09:13 PM
12/30/20 09:13 PM
Kent, WA
triple_green Offline
Kent, WA
There was a light green one down the street from us growing up. It now has a fresh paint job and a 528 hemi in it.
68 Charger, 383 HP console auto, spring green, stock restoration
Re: 68 Charger 3 on the tree [Re: 1sprinter] #2866930
12/31/20 12:26 PM
12/31/20 12:26 PM
IN
GTX4spd Offline
GTX4spd  Offline
IN
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: 68 Charger 3 on the tree [Re: Alaskan_TA] #2868352
01/03/21 03:10 AM
01/03/21 03:10 AM
Medina, Ohio
HEMICUDA Offline
HEMICUDA  Offline
Medina, Ohio
Originally Posted by Alaskan_TA
Originally Posted by 6bblgt
for reasons UNKNOWN the "US shipped 1968 Charger OPTION & ACCESSORY Report" is in ERROR - it shows 0 "zero" 3-speed manual transmission installed ***** the 4-speed numbers are in ERROR also blush
the 3-speed manual (column shift) transmission was the STANDARD transmission behind the 318 V8 & the mid-year introduced 225 /6 (an automatic transmission was a ~$200 OPTION)
from WARD's AUTOMOTIVE YEARBOOK (1968 model year):
96,108 = total 1968 Dodge Chargers
90.4% = 86,881 = total 1968 Dodge Chargers with automatic transmission
7.2% = 6,920 = total 1968 Dodge Chargers with 4-speed manual transmission (all floor shift & 383, 440, HEMI)
2.4% = 2,307 = total 1968 Dodge Chargers with 3-speed manual transmission (all column shift & 225, 318)
99.0% = 195,147 = total 1968 Dodge Chargers with V-8
1.0% = 961 = total 1968 Dodge Chargers with /6
the manner in which these numbers are calculated results in a number that is accurate to +/- 48 cars (0.05%)
"IF" the installation rate for the 3-speed manual transmission was the same for 225 & 318 powered Chargers, ~60 /6 Chargers would have been built with the 3-speed manual transmission for the 1968 model year
Really?
More assumptions?
Is the red color an indicator of a HUGE assumption or ?
If there is no true answer at this time, it truly is OK to say there is no true answer at this time. twocents
“More assumptions?” Ah, no, sounds more like a very educated extrapolation to me. twocents twocents
