Can pick up a KB 4.84 borespace block cheap #2866156
12/29/20 06:58 PM
12/29/20 06:58 PM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
Do you need a special crankshaft for a spreadbore block?
Might pull the trigger on this block. It was never hurt.
1st time going big block.
Re: Can pick up a KB 4.84 borespace block cheap [Re: Sammy] #2866243
12/29/20 10:17 PM
12/29/20 10:17 PM
Think about what they had to do to move the cylinder wall centers shruggy
Better yet call the company that cast that block twocents
I'm trying to remember when and which version Mopar racing block came with the 4.84 bore spacing, I'm thinking around when Darrel Alderman started driving for Mopar and those blocks had the distributor in the rear like BB Chevy blocks do, special block, special heads and so on work
I can't remember the names of those heads either whiney
Re: Can pick up a KB 4.84 borespace block cheap [Re: Cab_Burge] #2866256
12/29/20 10:45 PM
12/29/20 10:45 PM
NY
B1duster Offline
B1duster  Offline
NY
Indy 600-13 heads, B1TS heads, Predator, had 4.84 versions I think, there may be more. Dodge pro stock heads ?
Re: Can pick up a KB 4.84 borespace block cheap [Re: B1duster] #2866333
12/30/20 08:40 AM
12/30/20 08:40 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
yes needs indy 600-13 or heads designed for that bores space. the motor will make some serious power so , not sure what you have now but more may need to be upgraded in the car. Even if you end up not using it, it can be flipped. For good info, call Chuck at Best Machine. They have built a few of these 4.84 bore spaced engines and im sure he could fill you in. You can build big cubes as that block can go 4.60 bore
....BAD A$$ STREET CAR.....
Re: Can pick up a KB 4.84 borespace block cheap [Re: n20mstr] #2866340
12/30/20 09:11 AM
12/30/20 09:11 AM
Wind Gap,Pa.
Sammy Offline OP
Sammy  Offline OP
Wind Gap,Pa.
I'm asking if the crank is a special design for a 4.84 bore space.
Re: Can pick up a KB 4.84 borespace block cheap [Re: Sammy] #2866343
12/30/20 09:21 AM
12/30/20 09:21 AM
N
n20mstr Offline
n20mstr  Offline
N
That im not sure of. Chuck at Best Machine would know, also maybe Sasquatch on here would know as he is a dealer for KB,
Re: Can pick up a KB 4.84 borespace block cheap [Re: Sammy] #2866402
12/30/20 11:36 AM
12/30/20 11:36 AM
Romulus, MI
GTS340 Offline
GTS340  Offline
Romulus, MI
You could but it isn't necessary. Custom pistons with an opening between the pin bosses to accommodate the offset small end of the rod, or run the rods with enough side clearance to accommodate the offset.
I'm sure someone will chime in saying excessive side clearance will kill oil pressure, which is entirely untrue
Re: Can pick up a KB 4.84 borespace block cheap [Re: GTS340] #2866550
12/30/20 03:34 PM
12/30/20 03:34 PM
nebr
gtscrose Offline
gtscrose  Offline
nebr
I have some pistons and GRP rods for a 600-13 combo.
If interested email me.
gtscrose@longlines.com
thanks,
Chuck
