Science behind Mopar cooling??
#2866166
12/29/20 07:28 PM
12/29/20 07:28 PM
Posts: 7,982 Scranton, PA
Montclaire
Scranton, PA
Hello, I have a 74 Barracuda with a transplanted 440. This is a factory non-AC car so it has a 22" radiator (newer stock-style replacement for the 1974 factory 19" unit). I'm going through the cooling system and will be replacing the water pump. As I understand it, non-AC cars got a 22" radiator, the larger pulley and an 8 blade pump. AC cars got a larger radiator, the smaller pulley and 6 blade pump. The net effect was a slightly under-driven pump on the non-AC cars and an over-driven pump with AC (around 140%).
I have both pulleys to choose from but haven't decided on a pump yet. I am not running AC, just want to cool the 440. Now, some subscribe to the theory that a faster pump is always better but I can't see how that would be accurate. The factory obviously had a reason for two different setups. My guess would be to give the coolant enough time to properly do its job with the smaller radiator. The AC cars probably got a 6 blade pump to reduce cavitation and the smaller pulley to increase pressure in the system. What did non-AC police package cars use?
Thanks in advance
Re: Science behind Mopar cooling??
[Re: dragon slayer]
#2866257
12/29/20 10:46 PM
12/29/20 10:46 PM
Montclaire
Scranton, PA
It's running hot at lower speeds (as is steam, not just high on the gauge). I'll be adding a shroud and a 5-blade viscous fan to replace the mickey mouse flex fan that's on it now, along with new cap, thermostat, cooler plugs, checking the advance, etc. It already has an overflow tank and runs cool enough at speed so I'm assuming it's not blocked up otherwise. I came across this thread: http://www.dodgecharger.com/forum/index.php?PHPSESSID=qdp6mreo87eglkba11hdrim0o0&topic=60599.0There's a lot to read there but starting on page 8 there is a comparison of water pumps. Pump #1 is a motor home piece with an 8 blade impeller measuring 4.375" across that has really good flow numbers at low speed. So not only is there a difference in the number of fins, but also the diameter of the impeller, and I'm assuming the pitch of the fins determines the curve of the flow. It looks like I am better off with an 8-blade pump so long as the impeller is big enough. NAPA makes a stock looking one. I can always speed it up with the smaller pulley I guess, which will give more flow at lower rpms. This is just a street car, it may see a bigger cam as the motor feels pretty tame right now but nothing wild. It's going to see a lot of low speed city driving under 40mph so it'll have to run a little cooler to be happy. The last owner also opened up the hood scoops which doesn't do much on the Barracuda hoods (may actually hurt) so they'll get plugged back up, too.
[Re: AndyF]
#2866270
12/29/20 11:21 PM
12/29/20 11:21 PM
Montclaire
Scranton, PA
For a street car I'd duplicate the HD cooling package that you could get with the tow package. Andy, I'd love to but it's got the narrow yoke and I'm not cutting it for a bigger rad. Chrysler built a lot of big blocks with 22" radiators so I'm sure it'll be ok if the parts are matched.
[Re: mrob]
#2866409
12/30/20 11:49 AM
12/30/20 11:49 AM
Posts: 348 Isle of Sheeps
Gtxxjon
Isle of Sheeps
There is no one answer to this I bet? Every big block car I have ever owned always needed a 26 inch radiator! No engine driven fan was ever good enough to ‘draw out heat’ in a traffic jam. So it’s twin electric fans if you wannabe safe! On the whole it will not be needed, in slow traffic one fan will suffice. In heavy traffic both fans will deffo be needed and a good charging system to cope too. Water pump selection is a difficult choice but an all Ali set-up, pump and housing is a must. The pump blades must have a backing plate as this reduces cavitation and the Chevy spiral style pumps are useless...
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
[Re: Montclaire]
#2866426
12/30/20 12:28 PM
12/30/20 12:28 PM
RapidRobert
It's running hot at lower speeds (as is steam, not just high on the gauge). runs cool enough at speed so I'm assuming it's not blocked up otherwise. as said you need more air and or water flow. after the fan/shroud I would get the 8 blader & tack weld an anticav plate behind the vanes (cut the round piece in two & weld on each half
[Re: Montclaire]
#2866444
12/30/20 01:06 PM
12/30/20 01:06 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The reason for overdriving the pump was to turn the fan faster, more cooling airflow at low speeds. Turning the pump faster could cause cavitation, thus the smaller impeller.
[Re: moparx]
#2866522
12/30/20 03:03 PM
12/30/20 03:03 PM
Posts: 2,520 God's Country Maryland
GODSCOUNTRY340
Chrysler used the 6 vain pumps on AC cars for this reason, remember there was an AC condenser in front of the radiator that isn't there with non AC cars. The condenser is not only restricting airflow through the radiator but it's transferring it's heat to the radiator so, Chrysler slowed the flow through the radiator to give the fluid more time to cool.
[Re: GODSCOUNTRY340]
#2866546
12/30/20 03:29 PM
12/30/20 03:29 PM
Posts: 6,279 nowhere
Sniper
nowhere
Chrysler slowed the flow through the radiator to give the fluid more time to cool. Not how that works at all. If the water spends more time in the radiator to "cool", then it also spends more time in the engine getting "hot". So, at best, it would be a wash. The biggest factor in thermodynamics the the temperature differential not the time in the radiator.
#2866549
12/30/20 03:33 PM
12/30/20 03:33 PM
Posts: 21,830 Kirkland, Washington
Pacnorthcuda
Chrysler used the 6 vain pumps on AC cars for this reason, remember there was an AC condenser in front of the radiator that isn't there with non AC cars. The condenser is not only restricting airflow through the radiator but it's transferring it's heat to the radiator so, Chrysler slowed the flow through the radiator to give the fluid more time to cool. Nope. As Kunkel stated above, it’s to increase airflow while not increasing the opportunity for cavitation.
[Re: John_Kunkel]
#2866576
12/30/20 04:18 PM
12/30/20 04:18 PM
Montclaire
Scranton, PA
The reason for overdriving the pump was to turn the fan faster, more cooling airflow at low speeds. Turning the pump faster could cause cavitation, thus the smaller impeller. Now that makes a lot of sense. The iron pumps do not seem to need the anti-cavitation plate as they have a flat backing surface for the impeller. The aluminum pumps usually have a cavity so they would require the plate. I'll be using an iron 8-blade pump with an impeller over 4". Right now the car has the larger pulley on it. If I pull the pump and find it's an 8-blade, I'll swap to the smaller pulley with the shroud and clutch fan and see how it does.
