SCAT OR EAGLE I BEAM #2865523
12/27/20 11:41 PM
12/27/20 11:41 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I'm putting together a 318 that should be in the 450- 475 range@7K. I've used H beams before with great success. Found a set of Scat and Eagle I beams within $25.00 of each other. Thought that eagle has been low in quality. Scat the better deal?
Re: SCAT OR EAGLE I BEAM [Re: A/MP] #2865535
12/28/20 12:04 AM
12/28/20 12:04 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Molnar been considered?
Re: SCAT OR EAGLE I BEAM [Re: A/MP] #2865546
12/28/20 01:18 AM
12/28/20 01:18 AM
Cab_Burge Online work
Cab_Burge  Online Work
I had a SRP forged street piston fail with a Scat I beam rod while warming a stroker pump gas street 340 motor up on a engine dyno to get the oil temp. above 130 F and break in the cam at around 2000 RPM in less than 15 minutes whiney The wrist pin, one rod bolt and the rod where in the oil pan after the rod putting a hole in the side of the oil pan with no warning puke whiney
I sent pictures to both Scat and SRP, SRP ask me to send them the piston as one side of it had broken off at the bottom of the ring land and let the wrist pin fly rant SRP did nothing about that other than say they didn't know why it failed after looking at it down
My message is don't buy the cheapest parts based on price if want better parts in your motor and no problems later work
Re: SCAT OR EAGLE I BEAM [Re: Cab_Burge] #2865593
12/28/20 09:23 AM
12/28/20 09:23 AM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Word round the camp fire is that the Scat with the 7/16ths cap screw is the superior piece.
Springing for the bolt upgrade is never a bad idea either.
Re: SCAT OR EAGLE I BEAM [Re: tubtar] #2865615
12/28/20 10:32 AM
12/28/20 10:32 AM
Locomotion Offline
Locomotion  Offline
Eagle SIR small block rods have 3/8" bolts and made from 5140 steel.
Scat I-beam small block rods have 7/16" bolts and made from 4340 steel.
The Eagle SIR isn't a bad rod when used in the right application and the Scat is a little bit heavier, but the Scat has more advantages and would be my choice.
It's always best to keep piston weight down.
Re: SCAT OR EAGLE I BEAM [Re: Locomotion] #2865643
12/28/20 12:03 PM
12/28/20 12:03 PM
East Coast
A/MP Offline OP
A/MP  Offline OP
East Coast
I always try to get the complete reciprocating weight down. That has always been my take away from catastrophic failures
Re: SCAT OR EAGLE I BEAM [Re: Locomotion] #2865739
12/28/20 03:15 PM
12/28/20 03:15 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
What he said....
Tony
70 AARCuda Vitamin C
Re: SCAT OR EAGLE I BEAM [Re: A/MP] #2865743
12/28/20 03:18 PM
12/28/20 03:18 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I'd opt for the Scat personally. In our family 4 motors have scat rods and thus far no issues.
Re: SCAT OR EAGLE I BEAM [Re: A/MP] #2866590
12/30/20 04:48 PM
12/30/20 04:48 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
My two cents- SCAT.
No interest in Eagle I beams or Eagle cast cranks after seeing pics of the carnage here and elsewhere.
Re: SCAT OR EAGLE I BEAM [Re: J_BODY] #2866883
12/31/20 10:49 AM
12/31/20 10:49 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
X2
