2017 Ram 2500 noisy frt wheel bearing? #2864301
12/24/20 01:16 PM
12/24/20 01:16 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Is this a known issue?
Not the brakes. I replaced them months ago. I hear a definitely grinding while rolling through my neighborhood (where its quiet enough to hear). Doesn't go away applying brakes. Noise only stops when the truck stops. 85,000 miles. No water driving (other than rain) or boat ramps ever.
When I got a TWO THOUSAND DOLLAR BRAKE JOB QOUTE about a year ago from both a dealer and a local tire store, one of them mentioned wheel bearings like that a "maintenance item". I have never had a wheel bearing issue in 40 years of owning vehicles.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: 71TA] #2864318
12/24/20 01:50 PM
12/24/20 01:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Jack it up and spin the front wheels. That will let you know if it's wheel bearings ,which are an issues on Rams. I had to replace both sides on my 2014 RT Ram at 50k miles. Not a hard job.
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: stumpy] #2864625
12/25/20 01:42 PM
12/25/20 01:42 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Unitized wheel bearings are pretty much all junk. Not because the bearing itself is junk but because there isn't enough grease in it to dirty the palm of your hand.
I had a Ford Contour that you could set your watch for 35,000 miles and a front bearing would start to howl.
You could actually get one apart without wrecking it and I was able the pack an additional amount of bearing grease into it equal to the size of a chicken egg. That, oddly enough was the amount we were taught in high school shop class to pack in a wheel bearing.
That set of bearings outlived the car.
Kevin
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: 71TA] #2864696
12/25/20 05:30 PM
12/25/20 05:30 PM
Alberta
440_Offroader Offline
Alberta
My '01 4x4 2500 24V has 190k km's (120k miles) and my wheel bearings are still original, and so are my u-joints. Your milage seems pretty low for needing wheel bearings. I've had a couple newer Dodge 3500 work trucks with more miles than my own truck, that never had front wheel bearings done either. But... I probably just jinxed myself.
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: 440_Offroader] #2864745
12/25/20 07:47 PM
12/25/20 07:47 PM
Central NY
GarageDodge Offline
GarageDodge  Offline
Central NY
I have wheel bearings go over 200k,and others only last about 30k.I guess its the luck of the draw,oem or aftermarket.
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: GarageDodge] #2865200
12/27/20 11:48 AM
12/27/20 11:48 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
180k on both my bearings on my 01 as well as all unjoints. Replaced a hanger bearing at 150k. Luckily desert life has been easy on stuff. Not an easy job on nordern rusty stuff....
Re: 2017 Ram 2500 noisy frt wheel bearing? [Re: 71TA] #2865485
12/27/20 10:19 PM
12/27/20 10:19 PM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
Are your tires older or worn? I’ve had tire a make a sound similar to a wheel bearing going bad.
Also make sure one of your disc brake splash shields isn’t slightly bent and rubbing something. I had this right after a brake job.
