Re: Thrust bearing flaking
[Re: 70satelliteguy]
#2864415
12/24/20 05:16 PM
12/24/20 05:16 PM
Posts: 4,675 On the parachute mount
n20mstr
What block ? Alum or steel Chamfer the edge of the bearing at the parting line to diver some oil to the rear of the bearing . I also have a prelube Peterson remote filter mount . I always pre lube for a minute or longer after sitting overnight or longer
....BAD A$$ STREET CAR.....
[Re: jwb123]
#2864431
12/24/20 05:57 PM
12/24/20 05:57 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Mega block ,727 fresh rebuild ,converter rebuilt 3-4 years ago. Front and back surface measure less than 2 thousands difference in wear . Did not check endplay recently or before or after but combination has been trouble free for years. Do not have a pre-lube. Mike
[Re: NITROUSN]
#2864597
12/25/20 11:37 AM
12/25/20 11:37 AM
Posts: 1,301 Penna
70satelliteguy
Penna
Yes I do run Nitrous when we have the heads up street legal events. Launch on 2 step at 4500 with brake. Converter is a PTC built for Nitrous use and rebuilt 2014. Mike
