Thrust bearing flaking #2864406
12/24/20 05:01 PM
12/24/20 05:01 PM
Penna
70satelliteguy Offline OP
Penna
Anyone have or see thrust bearing surface flaking off ? I found a small piece in the oil pan . Bearing thrust surface itself does not look bad other than flaking . Bearings look happy in the rest of the motor. This is a BB stroker with Callies crankshaft that has not seen this in the past teardowns.
Bad bearing???
Thanks Mike
Re: Thrust bearing flaking [Re: 70satelliteguy] #2864415
12/24/20 05:16 PM
12/24/20 05:16 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
What block ? Alum or steel
Chamfer the edge of the bearing at the parting line to diver some oil to the rear of the bearing . I also have a prelube Peterson remote filter mount . I always pre lube for a minute or longer after sitting overnight or longer
....BAD A$$ STREET CAR.....
Re: Thrust bearing flaking [Re: 70satelliteguy] #2864419
12/24/20 05:18 PM
12/24/20 05:18 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Need more info, automatic or stick? Did you check the endplay when it was assembled, and before it came apart? Have you recently changed a converter, or transmission? It looks to me like lack of endplay, many things can cause or be part of the problem.
Re: Thrust bearing flaking [Re: jwb123] #2864431
12/24/20 05:57 PM
12/24/20 05:57 PM
Penna
Penna
Mega block ,727 fresh rebuild ,converter rebuilt 3-4 years ago. Front and back surface measure less than 2 thousands difference in wear . Did not check endplay recently or before or after but combination has been trouble free for years. Do not have a pre-lube.
Mike
Re: Thrust bearing flaking [Re: 70satelliteguy] #2864577
12/25/20 10:28 AM
12/25/20 10:28 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Do you run nitrous? Possible converter ballooning?
Re: Thrust bearing flaking [Re: NITROUSN] #2864597
12/25/20 11:37 AM
12/25/20 11:37 AM
Penna
Penna
Yes I do run Nitrous when we have the heads up street legal events. Launch on 2 step at 4500 with brake. Converter is a PTC built for Nitrous use and rebuilt 2014.
Mike
Re: Thrust bearing flaking [Re: 70satelliteguy] #2864689
12/25/20 05:11 PM
12/25/20 05:11 PM
Ct
W
Wirenut Offline
Wirenut  Offline
W
Ct
Same brand , style, and material as before ?
Have you changed fuel or oil brand , type ?
Same interval between tear downs?
Re: Thrust bearing flaking [Re: Wirenut] #2864714
12/25/20 06:11 PM
12/25/20 06:11 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
