Steering Wheel Question #2863312
12/22/20 12:30 PM
12/22/20 12:30 PM
London, England
JFChallenger440 Offline OP
London, England
Just a quick question does an original 69/70 Plymouth Roadrunner steering wheel fit a 69 Dodge Coronet ok ? Thanks
Re: Steering Wheel Question [Re: JFChallenger440] #2863342
12/22/20 01:16 PM
12/22/20 01:16 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
Should be no problem between '68 & '69, and probably '70.
Re: Steering Wheel Question [Re: JFChallenger440] #2863357
12/22/20 01:34 PM
12/22/20 01:34 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The 70 steering column has the ignition switch mounted in it, thus making a larger diameter housing, the B body wood grain wheels were modified with an adapter ring to cover this change, the "standard" wheels are unique to their year applications 68-69 are compatible, 70 are one year only applications...
Might help if you list, post pics of what you intend to do, so that you can be helped further in your swap?
Re: Steering Wheel Question [Re: DAYCLONA] #2863363
12/22/20 01:43 PM
12/22/20 01:43 PM
London, England
London, England
Thanks for the replies , it’s actually a steering wheel I’m selling , any idea what exact year this would be from ? Thanks
Re: Steering Wheel Question [Re: JFChallenger440] #2863428
12/22/20 03:58 PM
12/22/20 03:58 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
you could get them on 69 and 70 for sure..
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Steering Wheel Question [Re: wingman] #2863649
12/22/20 11:12 PM
12/22/20 11:12 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
That appears to be a 70 only wheel...the 69 wheel is different.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: Steering Wheel Question [Re: 70gtx440dana] #2863786
12/23/20 09:22 AM
12/23/20 09:22 AM
SE Pa.
LimeliteAero Offline
SE Pa.
I just can't tell from the pic, Is the plastic finish smooth or grained? only 70's were grained.
Re: Steering Wheel Question [Re: LimeliteAero] #2863955
12/23/20 03:59 PM
12/23/20 03:59 PM
London, England
London, England
You mean the center horn pad ? It’s grained
Re: Steering Wheel Question [Re: JFChallenger440] #2863960
12/23/20 04:07 PM
12/23/20 04:07 PM
Lansing, MI
Lansing, MI
It's a 70 only A & B body deluxe steering wheel. Both pad and wheel are 70. They both have a grained texture.....this wheel appears to have been restored/refurbished based on the amount of grain remaining on the wheel. twocents
Re: Steering Wheel Question [Re: 70gtx440dana] #2864151
12/23/20 11:54 PM
12/23/20 11:54 PM
Spokane Valley, WA
Big Bad Bee Offline
Big Bad Bee  Offline
Spokane Valley, WA
I agree with this. The whole thing looks like it was shot with a thick, glossy coating. That’s unfortunate, as the pad had a more satin sheen.
I’m listening.
Re: Steering Wheel Question [Re: Big Bad Bee] #2864256
12/24/20 11:03 AM
12/24/20 11:03 AM
New York
rarefish Offline
rarefish  Offline
New York
The thing that I have discovered is that the 1969 horn pad had double stitching and the metal horn ring was a separate piece.
In 1970 the pad had single stitching and the metal horn ring was now integrated with the pad as a single piece.
Here is a picture of the 1969 double stitch pad.
