Re: Steering Wheel Question
[Re: JFChallenger440]
#2863357
12/22/20 01:34 PM
12/22/20 01:34 PM
Posts: 18,153 Mass
DAYCLONA
Mass
Just a quick question does an original 69/70 Plymouth Roadrunner steering wheel fit a 69 Dodge Coronet ok ? Thanks The 70 steering column has the ignition switch mounted in it, thus making a larger diameter housing, the B body wood grain wheels were modified with an adapter ring to cover this change, the "standard" wheels are unique to their year applications 68-69 are compatible, 70 are one year only applications... Might help if you list, post pics of what you intend to do, so that you can be helped further in your swap?
#2863428
12/22/20 03:58 PM
12/22/20 03:58 PM
Posts: 3,365 St. Charles, MO
wingman
Uncreative Title
Uncreative Title
St. Charles, MO
you could get them on 69 and 70 for sure..
1969 Dodge Coronet Super Bee 383 A4 1970 Plymouth Road Runner 440 FC7 (sold)
[Re: wingman]
#2863649
12/22/20 11:12 PM
12/22/20 11:12 PM
Posts: 3,518 Lansing, MI
70gtx440dana
Lansing, MI
That appears to be a 70 only wheel...the 69 wheel is different.
70 Road Runner 383-4 4 speed FJ5 & black guts 70 Charger R/T 440-4 4 speed FJ5 & white guts
#2863960
12/23/20 04:07 PM
12/23/20 04:07 PM
70gtx440dana
Lansing, MI
It's a 70 only A & B body deluxe steering wheel. Both pad and wheel are 70. They both have a grained texture.....this wheel appears to have been restored/refurbished based on the amount of grain remaining on the wheel.
[Re: 70gtx440dana]
#2864151
12/23/20 11:54 PM
12/23/20 11:54 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
It's a 70 only A & B body deluxe steering wheel. Both pad and wheel are 70. They both have a grained texture.....this wheel appears to have been restored/refurbished based on the amount of grain remaining on the wheel. I agree with this. The whole thing looks like it was shot with a thick, glossy coating. That’s unfortunate, as the pad had a more satin sheen.
I’m listening.
[Re: Big Bad Bee]
#2864256
12/24/20 11:03 AM
12/24/20 11:03 AM
Posts: 2,252 New York
rarefish
New York
The thing that I have discovered is that the 1969 horn pad had double stitching and the metal horn ring was a separate piece. In 1970 the pad had single stitching and the metal horn ring was now integrated with the pad as a single piece. Here is a picture of the 1969 double stitch pad.
