Re: Slow Climb out of the Grave "Need Fuel SOS"
[Re: Diego_Ted]
#2862974
12/21/20 03:09 PM
12/21/20 03:09 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
With pumps that provide a lot of pressure and volume your best bet is to set it at between 5.0 to 6.5 lbs. of pressure with the motor running at idle speed so you can get set like it will be running with at the track. I've used from 4.0 to 9.5 lbs. of pressure on some of my old race cars before switching to one of the bigger, better high pressure and high volume pump like yours is now, my current S/P car has a front mounted fuel cell with a BG 400 pump with a Magna Fuel 4 port regulator that is currently set at 5.5 lbs. with the motor idling at or above 1200 RPM running E 85 pump fuel, this combination works very well, 8.86 at 150.6 MPH in the 1/4 mile so far, soon to go faster Monte Smith had advice many racers on this forum with the bigger race pumps to use between 4.5 to 6.0 lbs. while idling tp prevent the higher pressures to foam the fuel going into the fuel bowls I listen and turn down my pressures on this car from 7.5 Lb. to 5.0 Lb. and saw no loss or gain in ET or MPH
[Re: Diego_Ted]
#2863029
12/21/20 05:07 PM
12/21/20 05:07 PM
Thumperdart
State of confusion
Glad to see ya back around you've been gone for a bit.....I base pressures on needle n seat sizes, bigger = less pressure so with .120's 6 psi max, .130 and up 5 psi or less with gas......
[Re: dvw]
#2863302
12/22/20 11:44 AM
12/22/20 11:44 AM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
If it were mine it would be at 28ish and forget it. Glad to see you inching closer to racing again.
[Re: Al_Alguire]
#2863404
12/22/20 03:19 PM
12/22/20 03:19 PM
Posts: 5,406 Diego-Town, CA
Diego_Ted
Diego-Town, CA
Thx guys, I really dig the help as I can use it in my OG state. Truly always loved being a part of this board. Al it's going to be slow but fun, I always said when I retired Racing would be part of it and here it is.
thx again guys but know this is only the beginning !!! LOL
Diego
[Re: Diego_Ted]
#2863446
12/22/20 04:25 PM
12/22/20 04:25 PM
Cab_Burge
Ted, I didn't change my pump pressure setting to the regulator setting. I did change the regulator setting to the carb from 7.5 to 5.0 lbs. with no measurable differences in performances or idling i
