Anyone using an FST carburetor? **UPDATE**
#2862189
12/19/20 03:32 PM
12/19/20 03:32 PM
Guitar Jones
I know they are a start up company but their stuff looks nice. They have the exact carb I've been looking for that no one else makes, 750 CFM, mechanical secondaries, electric choke, single inlet side hung floats. They are on back order however, I'm thinking they are waiting on supply from their Chinese supplier but can't confirm that. I ordered one in October and now it looks like it will be March before they are available, I've contacted Jegs, who tried calling them twice with no answer, I've emailed them and so has Jegs, but never received a response. Not sure I want to deal with that or not.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
Re: Anyone using an FST carburetor?
[Re: Guitar Jones]
#2862226
12/19/20 05:37 PM
12/19/20 05:37 PM
Posts: 14,494 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
At this point...... based on what you’re saying....... it would be a “pass” for me.
[Re: J_BODY]
#2862241
12/19/20 06:16 PM
12/19/20 06:16 PM
fast68plymouth
So. Burlington, Vt.
I was referring to the lack of any contact from them....... and one of their dealers also not getting any response from them.
Of course, it’s pretty easy for me to take that stand....... I’m fairly “carb rich” at the moment.
[Re: J_BODY]
#2862258
12/19/20 06:45 PM
12/19/20 06:45 PM
Guitar Jones
I'm not getting a warm fuzzy feeling that is for sure, but with the chinese flu and the holidays, I'm willing to give them the benefit of the doubt. I wanted the mechanical secondaries so I could control the opening and the side hung floats for off roading. There just isn't any other options. Jegs does have the 650 cfm version in stock, that's probably big enough anyway. It's not a race car.
[Re: Guitar Jones]
#2862293
12/19/20 07:54 PM
12/19/20 07:54 PM
Posts: 12,058 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Why not give Dominic (Thumperdart) a call? He does more than Dominators. And I 'll bet he'll be easier to get a hold of.
Master, again and still
[Re: DaveRS23]
#2862328
12/19/20 09:05 PM
12/19/20 09:05 PM
Guitar Jones
Because I don't know of any other side hung rear fuel bowl with an accelerator pump. If that was available I could have pieced one together myself. Probably not for the price of this one though.
[Re: Guitar Jones]
#2862337
12/19/20 09:22 PM
12/19/20 09:22 PM
Posts: 4,457 Washington
madscientist
Washington
Because I don't know of any other side hung rear fuel bowl with an accelerator pump. If that was available I could have pieced one together myself. Probably not for the price of this one though. I’ve been through two of them. You need to verify the tune up. I have had them on the phone several times. If I have to use email to talk to anyone like that I won’t do business with them. Their stuff is very very nice and the price is right. The problem is getting them. So far since the Covid, they haven’t been getting orders filled.
[Re: J_BODY]
#2862339
12/19/20 09:41 PM
12/19/20 09:41 PM
Posts: 19,317 State of confusion
Thumperdart
State of confusion
As I understand it it's all Chinese......not to piss in anyone's cereal....
[Re: Guitar Jones]
#2862386
12/20/20 12:22 AM
12/20/20 12:22 AM
Posts: 4,713 Moved to N.E. Tennessee
GomangoCuda
It Because I don't know of any other side hung rear fuel bowl with an accelerator pump. If that was available I could have pieced one together myself. Probably not for the price of this one though. Does it have to be single inlet? Plug the transfer tube holes on two primary bowls,. Instant dual feed, double pumper with side hung bowls. Should be able to plug those holes and make fuel lines in less than an hour.
[Re: Cab_Burge]
#2862397
12/20/20 12:58 AM
12/20/20 12:58 AM
GomangoCuda
The early, pre 1975 or so, 660 and 850 CFM center squirter tunnel ram carbs. had what your looking for Probably not available new anymore Nope. Center squirters only have one pump. BUT they did also make a 750 double pumper tunnelram carb with side hung floats. I don't remember the list number.
[Re: GomangoCuda]
#2862415
12/20/20 02:07 AM
12/20/20 02:07 AM
Guitar Jones
Interesting thought but it's only $300 for the 650 carb. I'll give it a try. Thanks all.
[Re: GomangoCuda]
#2862417
12/20/20 02:13 AM
12/20/20 02:13 AM
Posts: 2,072 CA
crackedback
CA
The early, pre 1975 or so, 660 and 850 CFM center squirter tunnel ram carbs. had what your looking for Probably not available new anymore Nope. Center squirters only have one pump. BUT they did also make a 750 double pumper tunnelram carb with side hung floats. I don't remember the list number. 6109? 660 were one 50cc pump, IIRC. one squirter, one pump
[Re: crackedback]
#2862426
12/20/20 04:26 AM
12/20/20 04:26 AM
Posts: 43,157 Bend,OR USA
Cab_Burge
Your correct on the 660 center squirters Holley sold a ton of them, not so on the bigger 850 Center squirters, It took me a long time to find two of them and then I let them go before using them on a tunnel ram intake
[Re: GomangoCuda]
#2862452
12/20/20 08:33 AM
12/20/20 08:33 AM
Posts: 287 PA
Harry's Taxi 2
PA
The early, pre 1975 or so, 660 and 850 CFM center squirter tunnel ram carbs. had what your looking for Probably not available new anymore Nope. Center squirters only have one pump. BUT they did also make a 750 double pumper tunnelram carb with side hung floats. I don't remember the list number. yes, 6109
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
[Re: DaveRS23]
#2862466
12/20/20 10:03 AM
12/20/20 10:03 AM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
Why not give Dominic (Thumperdart) a call? He does more than Dominators. And I 'll bet he'll be easier to get a hold of. +1! Untitled by Greg Ault, on Flickr
[Re: Harry's Taxi 2]
#2862531
12/20/20 01:43 PM
12/20/20 01:43 PM
GomangoCuda
The early, pre 1975 or so, 660 and 850 CFM center squirter tunnel ram carbs. had what your looking for Probably not available new anymore Nope. Center squirters only have one pump. BUT they did also make a 750 double pumper tunnelram carb with side hung floats. I don't remember the list number. yes, 6109 That's the one. 750 double pumper with side hung bowls. Made for use on tunnel rams back in the 70's. No idea when they were discontinued. IIRC they were kind of popular on jet boat engines.
