R11 and rear speaker #2861402
12/17/20 05:21 PM
12/17/20 05:21 PM
SE Wisconsin, USA
RP's R/T's Offline OP
SE Wisconsin, USA
On an E-Body, what option got you the rear speaker/fader switch for the Radio.
Re: R11 and rear speaker [Re: RP's R/T's] #2861426
12/17/20 06:25 PM
12/17/20 06:25 PM
italy
antonellomopar Offline
italy
R 31...my 71 Challenger has this code on the broadcast sheet along with R 11. But since we are on this subject, this option had one speaker in the rear, or two? Package shelf is empty now...
Re: R11 and rear speaker [Re: antonellomopar] #2861524
12/17/20 10:15 PM
12/17/20 10:15 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
If it’s one speaker, what part number is stamped on the speaker? How were they mounted? Pics anyone?
China is the enemy.
Re: R11 and rear speaker [Re: antonellomopar] #2861552
12/17/20 11:13 PM
12/17/20 11:13 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Single rear speaker on driver's side.
Re: R11 and rear speaker [Re: skdmark] #2861564
12/17/20 11:46 PM
12/17/20 11:46 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
I just took these out of an October '69 built '70 'cuda with factory R22 & R31 (a single speaker with R11 would be the same speaker on the LH side) scope
both were mounted with 3 screws - shruggy - don't know if that's how it left the factory or if one fell out of each speaker
1970 cars with STEREO (AM/FM or AM w/8-track) had two rear speakers VS. one speaker for the mono AM radio - they used the same R31 code for rear speaker(s)
moparts 70 cuda R22 R31 lh.jpgmoparts 70 cuda R22 R31 rh.jpgmoparts 70 cuda R22 R31.jpg
Re: R11 and rear speaker [Re: 6bblgt] #2861569
12/17/20 11:57 PM
12/17/20 11:57 PM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Thanks! I didn’t know they used screws!
China is the enemy.
Re: R11 and rear speaker [Re: RP's R/T's] #2861581
12/18/20 12:27 AM
12/18/20 12:27 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Similar to the '69 B-body method of mounting the single rear speaker:
https://board.moparts.org/ubbthread...9/rear-speaker-mounting.html#Post2854909
Re: R11 and rear speaker [Re: A12] #2861604
12/18/20 02:55 AM
12/18/20 02:55 AM
Connecticut
1972CudaV21 Offline
1972CudaV21  Offline
Connecticut
Good info! Thanks for sharing👍
China is the enemy.
Re: R11 and rear speaker [Re: 1972CudaV21] #2861701
12/18/20 12:33 PM
12/18/20 12:33 PM
italy
italy
Thank you for the reply. Very exhaustive. But what about the package tray cardboard? If single speaker, grille were on both sides I guess. Never seen a sigle grille cardboard...
Re: R11 and rear speaker [Re: antonellomopar] #2861878
12/18/20 06:21 PM
12/18/20 06:21 PM
SE-WI
skdmark Offline
skdmark  Offline
SE-WI
Correct.
Package tray would have driver and passenger side cutouts even with one rear speaker.
