Rear speaker mounting #2854909
12/03/20 06:35 PM
12/03/20 06:35 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
I am adding a single rear speaker mounted on the left side of the rear shelf deck on my 69 Charger. It never had a speaker when built. What fasteners mounted the speaker? Pictures? Thanks.
Re: Rear speaker mounting [Re: NITROUSN] #2855513
12/04/20 11:19 PM
12/04/20 11:19 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
This is in my 69 A12 Road Runner on the left/driver's side rear package shelf and I believe it to be as installed from the factory in 1969. It may not be but if not then someone will chime in and let us know. Posting the photos to get some responses if the Philips screws are original?
Mike
Re: Rear speaker mounting [Re: A12] #2855592
12/05/20 08:54 AM
12/05/20 08:54 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Mine has a standard looking philips screw without the collar like Mikes and from the same plant. May have been different suppliers of screws over time or different screw bins??? Gotta love these posts, kind of like wing nuts and washers LOL I talked to the original owner and he said he never had any reason to pull the speaker loose
1969 Hemi Roadrunner 2nd owner
Re: Rear speaker mounting [Re: 69hemibeep] #2855855
12/05/20 09:05 PM
12/05/20 09:05 PM
N
NITROUSN Offline OP
NITROUSN  Offline OP
N
Thanks for the responses. Looks like I should just find a suitable Phillip's screw and possible washer. Car is not by the numbers but I would like it to look somewhat close. Thanks again.
