Re: Starting from zero - building small block stroker ignition
[Re: lostdog]
#2860390
12/15/20 05:44 PM
12/15/20 05:44 PM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
If you don't have anything build a Gen III Hemi
68 Barracuda Formula S 340
[Re: Bad340fish]
#2860392
12/15/20 05:47 PM
12/15/20 05:47 PM
Posts: 361 mississippi
lostdog
mississippi
If you don't have anything build a Gen III Hemi Nooo I have engine mapped out just no ignition. I had thought about the G3 but lost interest real quick!
[Re: lostdog]
#2860393
12/15/20 05:48 PM
12/15/20 05:48 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Lots of MSD 7AL3’s out there for sale and they work great. I use them in al my race cars. MSD Blaster coil, and I usually use ultra 40 plug wires. Lots of guys switching to digital or Grid systems
Ohhh MSD distributor too
[Re: Bad340fish]
#2860399
12/15/20 05:59 PM
12/15/20 05:59 PM
Posts: 6,139 Melbourne , Australia
LA360
The MSD stuff seems to be the go to for most people. Depending on your budget, you could go with the 7AL-3, if there is more in your budget, the Power Grid system. I'd run a crank trigger as well.
Alan Jones
[Re: justinp61]
#2860466
12/15/20 08:32 PM
12/15/20 08:32 PM
Posts: 4,672 Wichita
GY3
Wichita
When you say "grudge" car, I assume it has a power adder?
I use an old analog 6AL with the adjustable timing control box added and a dial rev limiter hooked to a recurved stock distributor.
Thinking about upgrading to a 7AL3, though....
[Re: GY3]
#2860487
12/15/20 09:20 PM
12/15/20 09:20 PM
lostdog
mississippi
Thinking about upgrading to a 7AL3, though.... Yes, I will be adding nitrous and this is my first experience with a transbrake and I’m trying to figure out how to make all that work.
[Re: lostdog]
#2860490
12/15/20 09:28 PM
12/15/20 09:28 PM
Bad340fish
Tulsa OK
Something like this to control you nitrous and T-brake might be a good idea. https://leashelectronics.com/products/single-stage-nitrous-boardI don't run any MSD stuff anymore but I would buy the baddest box you can afford. Most power adder stuff grows to more and more power and you might as well avoid buying twice.
[Re: Bad340fish]
#2860511
12/15/20 10:02 PM
12/15/20 10:02 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Go as crazy as you want to go, it’s only money
[Re: pittsburghracer]
#2860522
12/15/20 11:14 PM
12/15/20 11:14 PM
lostdog
mississippi
That’s something serious right there !
[Re: lostdog]
#2860618
12/16/20 09:25 AM
12/16/20 09:25 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
Big power w/ nitrous...get the MSD grid system if you can afford it. If you need a little more of a budget friendly option, get the MSD 6AL-2 programmable (6530). That's what I did. For distributors I like the MSD pro billets, locked out, and use a crank trigger.
I also strongly recommend the Leash nitrous controller and their wiring board. Great working simple setup.
[Re: an8sec70cuda]
#2860622
12/16/20 09:32 AM
12/16/20 09:32 AM
an8sec70cuda
That one little box on the left replaced the 3 boxes on the right.
[Re: Bad340fish]
#2860635
12/16/20 10:02 AM
12/16/20 10:02 AM
GY3
Wichita
I use the Leash single stage board and it works great! It made wiring up the nitrous system super simple.
[Re: an8sec70cuda]
#2860637
12/16/20 10:13 AM
12/16/20 10:13 AM
lostdog
mississippi
I also strongly recommend the Leash nitrous controller and their wiring board. Great working simple setup. The part number is helpful ! After doing some reading I though the MSD 6AL-2 64213 would have been fine but I think the 6530 is a better choice
[Re: lostdog]
#2860669
12/16/20 11:10 AM
12/16/20 11:10 AM
an8sec70cuda
Most are spraying one big kit and using a progressive to control it. Less complicated than multiple systems.
