Starting from zero - building small block stroker ignition #2860388
12/15/20 05:43 PM
12/15/20 05:43 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I don't have anything so I will need a complete compatible system so I am looking for recommendations on distributor, ignition module, wires etc. Also, I will be using a transbrake
This is a street/grudge race '70 Duster
Thanks !
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860390
12/15/20 05:44 PM
12/15/20 05:44 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If you don't have anything build a Gen III Hemi
68 Barracuda Formula S 340
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860392
12/15/20 05:47 PM
12/15/20 05:47 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Nooo I have engine mapped out just no ignition. I had thought about the G3 but lost interest real quick!
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860393
12/15/20 05:48 PM
12/15/20 05:48 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Lots of MSD 7AL3’s out there for sale and they work great. I use them in al my race cars. MSD Blaster coil, and I usually use ultra 40 plug wires. Lots of guys switching to digital or Grid systems
Ohhh MSD distributor too
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860394
12/15/20 05:48 PM
12/15/20 05:48 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Ahh Ok gotcha.
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860399
12/15/20 05:59 PM
12/15/20 05:59 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The MSD stuff seems to be the go to for most people. Depending on your budget, you could go with the 7AL-3, if there is more in your budget, the Power Grid system. I'd run a crank trigger as well.
Alan Jones
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860419
12/15/20 06:46 PM
12/15/20 06:46 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
For my street/strip small block I run a MSD distributor and a MSD Digital 6 ignition box.
Re: Starting from zero - building small block stroker ignition [Re: justinp61] #2860466
12/15/20 08:32 PM
12/15/20 08:32 PM
Wichita
GY3 Online content
GY3  Online Content
Wichita
When you say "grudge" car, I assume it has a power adder?
I use an old analog 6AL with the adjustable timing control box added and a dial rev limiter hooked to a recurved stock distributor.
Thinking about upgrading to a 7AL3, though....
'63 Dodge 330
11.19 @ 121 mph
Re: Starting from zero - building small block stroker ignition [Re: GY3] #2860487
12/15/20 09:20 PM
12/15/20 09:20 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
Yes, I will be adding nitrous and this is my first experience with a transbrake and I’m trying to figure out how to make all that work.
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860490
12/15/20 09:28 PM
12/15/20 09:28 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Something like this to control you nitrous and T-brake might be a good idea.
https://leashelectronics.com/products/single-stage-nitrous-board
I don't run any MSD stuff anymore but I would buy the baddest box you can afford. Most power adder stuff grows to more and more power and you might as well avoid buying twice.
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860511
12/15/20 10:02 PM
12/15/20 10:02 PM
PA.
"Little"John
"Little"John
PA.
Go as crazy as you want to go, it’s only money
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860521
12/15/20 11:13 PM
12/15/20 11:13 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
I’m finding out adding the transbrake is whole new multifaceted element. A lot different from foot braking with throttle activated nitrous micro switch.
Re: Starting from zero - building small block stroker ignition [Re: pittsburghracer] #2860522
12/15/20 11:14 PM
12/15/20 11:14 PM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
That’s something serious right there !
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860535
12/15/20 11:40 PM
12/15/20 11:40 PM
iagree
Don't buy any of the combination street and strip MSD boxes for your deal, buy race only up twocents
Once you get bit by the power bug you will find out there is never to much power, just like never having to much money, sex, traction HP and on and on whistling devil
Another thing to remember is on the spark plug gap, you may need to close it up some as the power level increases and the coil wire and spark plug wires won't live as long either due to the ignition making more energy to make the spark jump across the plug gaps on power adder motors shruggy
Speed cost money, how fast do YOU want to GO whistling grin
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860618
12/16/20 09:25 AM
12/16/20 09:25 AM
an8sec70cuda Offline
Big power w/ nitrous...get the MSD grid system if you can afford it. If you need a little more of a budget friendly option, get the MSD 6AL-2 programmable (6530). That's what I did.
For distributors I like the MSD pro billets, locked out, and use a crank trigger.
I also strongly recommend the Leash nitrous controller and their wiring board. Great working simple setup.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Starting from zero - building small block stroker ignition [Re: an8sec70cuda] #2860622
12/16/20 09:32 AM
12/16/20 09:32 AM
That one little box on the left replaced the 3 boxes on the right.
CHIP
Re: Starting from zero - building small block stroker ignition [Re: Bad340fish] #2860635
12/16/20 10:02 AM
12/16/20 10:02 AM
Wichita
GY3 Online content
GY3  Online Content
Wichita
I use the Leash single stage board and it works great! It made wiring up the nitrous system super simple.
'63 Dodge 330
11.19 @ 121 mph
Re: Starting from zero - building small block stroker ignition [Re: an8sec70cuda] #2860637
12/16/20 10:13 AM
12/16/20 10:13 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
The part number is helpful ! After doing some reading I though the MSD 6AL-2 64213 would have been fine but I think the 6530 is a better choice
Re: Starting from zero - building small block stroker ignition [Re: Cab_Burge] #2860640
12/16/20 10:15 AM
12/16/20 10:15 AM
mississippi
lostdog Offline OP
lostdog  Offline OP
mississippi
iagree
I agree but I'm aiming to strike a balance between what I think I need and what I will actually use. Like I would like to think I will stack a two stage kit on this thing and let it rock but the reality is I may never shoot more than a single 200 to it
Re: Starting from zero - building small block stroker ignition [Re: lostdog] #2860669
12/16/20 11:10 AM
12/16/20 11:10 AM
Most are spraying one big kit and using a progressive to control it. Less complicated than multiple systems.
CHIP
