Re: 1 7/8 “ LA stroker / A Body race headers
[Re: MR_P_BODY]
#2859330
12/13/20 12:36 PM
12/13/20 12:36 PM
Posts: 361 mississippi
lostdog
mississippi
What are the specs on the engine and cam.. I build all my own headers so I cant suggest what company 360 base 040 over stroker Super victor intake Trick flow 190 heads Harland sharp 1.5’s Cam 245/253 @050. Lift .600/.600, 727 manual valve body Thinking 4:30 gear.
[Re: MR_P_BODY]
#2859362
12/13/20 01:18 PM
12/13/20 01:18 PM
Posts: 4,991 new jersey usa
11secdart
new jersey usa
My advice stay away from TTIs not happy with mine .. poor fit and quality.. take a look at Tubular Automotive brand ran them for years on my s/b Dart and am probably going back to them.
[Re: justinp61]
#2859377
12/13/20 01:46 PM
12/13/20 01:46 PM
lostdog
mississippi
I've been running Hedman Huslers for years and really like them. One tube on each side goes out through the fenderwell though.
I don't think it'll need the 4.30 gears
I was looking at those too but trying to avoid fender exit - not counting it out. Just trying to avoid it.
[Re: lostdog]
#2859403
12/13/20 02:18 PM
12/13/20 02:18 PM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
I was looking at those too but trying to avoid fender exit - not counting it out. Just trying to avoid it. About ten years ago I was in the process of building my 408 and Ryan Johnson had my heads freshening them up. He and I were talking on the phone about the build and headers came up. Since my 340 had TTI's on it I was considering a new set of 1 7/8" TTI's for the 408. Ryan told me to go with Hedmans, IIRC he said they were worth over 30 hp on the dyno than TTI's, so I bought Hedman's. The easiest set of headers to install that I've ever owned, they are like a jig saw puzzle to put together though. ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif)
[Re: justinp61]
#2859407
12/13/20 02:26 PM
12/13/20 02:26 PM
lostdog
mississippi
I was looking at those too but trying to avoid fender exit - not counting it out. Just trying to avoid it. About ten years ago I was in the process of building my 408 and Ryan Johnson had my heads freshening them up. He and I were talking on the phone about the build and headers came up. Since my 340 had TTI's on it I was considering a new set of 1 7/8" TTI's for the 408. Ryan told me to go with Hedmans, IIRC he said they were worth over 30 hp on the dyno than TTI's, so I bought Hedman's. The easiest set of headers to install that I've ever owned, they are like a jig saw puzzle to put together though. That’s good information to have. And thank you for the pictures - now that I see it doesn’t take much cutting for the exit pipes , I’d be good with that especially if they’re not so hard to install. I appreciate your help!
[Re: justinp61]
#2859441
12/13/20 03:35 PM
12/13/20 03:35 PM
Posts: 8,035 Tulsa OK
Bad340fish
Tulsa OK
I think the headman are best for power from everything I have read. That being said I have TTI 1 7/8" on my W2 418 and they fit great, the passenger side one is super easy to install and almost requires two people because it will literally fall out after you install it. The drivers side is not easy, but once it is in it fits great. I just leave it in the car when I take the motor out and that takes all the pain out of it haha.
68 Barracuda Formula S 340
[Re: justinp61]
#2859563
12/13/20 08:26 PM
12/13/20 08:26 PM
Posts: 4,457 Washington
madscientist
Washington
I was looking at those too but trying to avoid fender exit - not counting it out. Just trying to avoid it. About ten years ago I was in the process of building my 408 and Ryan Johnson had my heads freshening them up. He and I were talking on the phone about the build and headers came up. Since my 340 had TTI's on it I was considering a new set of 1 7/8" TTI's for the 408. Ryan told me to go with Hedmans, IIRC he said they were worth over 30 hp on the dyno than TTI's, so I bought Hedman's. The easiest set of headers to install that I've ever owned, they are like a jig saw puzzle to put together though. You can get most of that 30 HP loss from the TTI’s by cutting off their junk collectors and putting some nice collectors on there. The TTI collectors are just terrible.
[Re: madscientist]
#2859702
12/14/20 06:40 AM
12/14/20 06:40 AM
Posts: 89 Georgia and Washington
JMCarter
True, on my 360 Stock Eliminator Volare I cut off the TTI collectors and put on Mark Lelchook’s merge collectors (beautiful work BTW) and picked up .05 with no other changes.
[Re: justinp61]
#2859744
12/14/20 10:18 AM
12/14/20 10:18 AM
Posts: 1,534 bronx n.y
one bad fish
bronx n.y
I cut the flanges on mine to make them easier to install.
any tire issue when turning
[Re: one bad fish]
#2859872
12/14/20 03:23 PM
12/14/20 03:23 PM
justinp61
W. Kentucky
any tire issue when turning None, I run a M/T SR 26 X 6 radial.
[Re: justinp61]
#2859886
12/14/20 03:38 PM
12/14/20 03:38 PM
one bad fish
bronx n.y
ok I cut the flanges on mine to make them easier to install.
any tire issue when turning None, I run a M/T SR 26 X 6 radial. ok i run a 27 1/2 m/t
