383 Intakes - Edelbrock - Mopar - Dual planes
#28570
07/28/06 07:46 PM
07/28/06 07:46 PM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
Have a performer intake right now - Got rid of the Edelbrock 1407 750 cfm - Bought a new Edelbrock 1412 800 cfm carb
Running the 284 - 484 cam with 906 heads Stock exhaust manifolds Engine .030 over - Speed pro flat tops - Balanced Timing 38 degrees total Engine runs awesome - Just looking for a little more This is a street car - I run the factory dual snorkel air cleaner - Car came from the factory with carter avs so thats why i keep working with the edelbrock carbs - Like that sort of factory appearance with a little extra
Running 3:91 gears
Whats everyones take on intakes Performer Rpm - I know this is a great choice but hood clearance - I will keep the factory air cleaner - No exceptions - Bulge hood ,but those hood braces
Whats your opinion on the Edelbrock performer intake ???
Is the Edelbrock DP4B for 383 Better ???
How about Mopar Dual plane 4529117 ???
Looking for opinions and answers on these four intakes Thanx Scott
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
Re: 383 Intakes - Edelbrock - Mopar - Dual planes
[Re: bee1971]
#28575
07/29/06 02:38 AM
07/29/06 02:38 AM
I have the Eddy Performer on mine now with the stock air cleaner and a 1" spacer under the Eddy 600 carb. I do have more of a drop base under the factory air cleaner and it's smaller in size so it makes the air cleaner unsilenced. I have an Edelbrock DP4B to go on it mostly for more factory appearing looks. The performer has the egr setup which is ugly.
[Re: Mr.Yuck]
#28578
07/29/06 06:41 PM
07/29/06 06:41 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Find a used Holley Street Dominator.Proballt the best BB intake ever made and it will fit under the stock hood.Good bottom and top end.Just they only remake them for the RB motor.Rocky
Chrysler Firepower
[Re: therocks]
#28579
07/30/06 01:42 AM
07/30/06 01:42 AM
bee1971
Sobieski Wi
Thanx for all the info guys I am running 2500 stall and just under 10:1 compression Headers - Probably in the near future , but not right now I have heard and read great things about the holley intake and eddy rpm - Mopar muscle , I have an issue were they tested 11 intakes on a 440 - Wow those two were nothing short of amazing on the dyno - The DP4 are for sale on ebay all the time How much will a Carb Spacer help on the Performer Intake that i have right now ??? If any or time to start looking for an new intake also
[Re: DaytonaTurbo]
#28585
07/31/06 12:37 PM
07/31/06 12:37 PM
Posts: 75,008 U.S.S.A.
JohnRR
U.S.S.A.
yeah I decided to sell my RPM and get a street dominator. RPM is way too tall to clear the hood in my satellite without a drop base air cleaner, plus with the SD I can keep my thermoquad.
you have a 440 , the hood clearance issue is less with a low deck as the OP has .
[Re: JohnRR]
#28587
07/31/06 01:34 PM
07/31/06 01:34 PM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
I run an RPM on my 383 in a 67 Satellite. I like the stock look too, I even painted the manifold so it would look as stock as possible, but Theres no way a complete stock air cleaner would fit. I really wanted to use the Eddy RPM package and already had the cam, so I made due. I took a drop base cleaner, painted it black and found a re-production sticker. Even this setup barely clears. Its not stock, but it has that low-key look and I really like how it turned out. I do think if you run a drop base & put the stock top over the element & it would work, & retain the stock look. If I can ever figure out how to publish pics to the web, I'll throw a pic in.
[Re: StealthWedge67]
#28588
07/31/06 02:12 PM
07/31/06 02:12 PM
StealthWedge67
Puyallup, WA
figured it out.... Heres mine, That's a Performer RPM with an Eddy 750 atop. It's close, but it fits under the stock hood.
