383 Intakes - Edelbrock - Mopar - Dual planes #28570
07/28/06 07:46 PM
07/28/06 07:46 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Have a performer intake right now - Got rid of the Edelbrock 1407 750 cfm - Bought a new Edelbrock 1412 800 cfm carb
Running the 284 - 484 cam with 906 heads
Stock exhaust manifolds
Engine .030 over - Speed pro flat tops - Balanced
Timing 38 degrees total
Engine runs awesome - Just looking for a little more
This is a street car - I run the factory dual snorkel air cleaner - Car came from the factory with carter avs so thats why i keep working with the edelbrock carbs - Like that sort of factory appearance with a little extra
Running 3:91 gears
Whats everyones take on intakes
Performer Rpm - I know this is a great choice but hood clearance - I will keep the factory air cleaner - No exceptions - Bulge hood ,but those hood braces
Whats your opinion on the Edelbrock performer intake ???
Is the Edelbrock DP4B for 383 Better ???
How about Mopar Dual plane 4529117 ???
Looking for opinions and answers on these four intakes
Thanx Scott
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28571
07/28/06 08:08 PM
07/28/06 08:08 PM
Upper Midwest
MoparforLife Offline
Upper Midwest
About the only advantage ofver teh Stock cast iron intake is it looks nice and is lighter. Find a DP4B dual plane or a RPM. Use a drop base air cleaner so that you will clear the hood. Trouble is you are working on taking air and fuel in but are still trying to get it out by using the stock manifolds. You need to improve the exhaust flow to utilize the intake and cam capabilities.
Clean it, if it's Dirty. Oil it, if it Squeaks. But: Don't fix it, if it Works!
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: MoparforLife] #28572
07/28/06 08:56 PM
07/28/06 08:56 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
In my opinion the best intake on a mild street 383 combo is the Performer RPM hands down. We have one on my boys 400 in his Dart and we wanted to keep the stock hood no matter what. It fits with about 1-1/2" of room. But it's an A-body so I don't know if it will fit in your car. It has great low end and mid range with good pull up to around 6500. If it won't fit I also like the Holley Street Dominator. It's a single plane and it has great top end and good low end for a single plane. We have used both on my sons car and they both ran in the 11.50's with the RPM having the better 1/8 time and .04 better in the 1/4 but was about 1 mph less then the SD. Here is the Performer RPM on his 400. Ron
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: 383man] #28573
07/28/06 09:02 PM
07/28/06 09:02 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Here is his car with the stock hood and the Performer RPM under it. I agree with Don that good exh flow will help. Ron
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28574
07/29/06 01:44 AM
07/29/06 01:44 AM
arizona, usa
lokalik Offline
lokalik  Offline
arizona, usa
i like the performer. i have one on my 383. 70 sport satellite, using 1/2 inch taper spacer and a drop base with the stock hood and speed demon. car runs very good.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28575
07/29/06 02:38 AM
07/29/06 02:38 AM
I have the Eddy Performer on mine now with the stock air cleaner and a 1" spacer under the Eddy 600 carb. I do have more of a drop base under the factory air cleaner and it's smaller in size so it makes the air cleaner unsilenced. I have an Edelbrock DP4B to go on it mostly for more factory appearing looks. The performer has the egr setup which is ugly.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes #28576
07/29/06 04:15 PM
07/29/06 04:15 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
The Performer is baically like the stock intake. It does not give much performance gain over the stock intake. Ron
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28577
07/29/06 05:15 PM
07/29/06 05:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
DP4B is a great intake use it w/ a 1/2 inch 4 hole spacer. The rpm is tall. The Performer isn't much better than stock.
How much stall you got? that 484 cam likes about 3000+ and at least 10:1 compression.
Coming soon!!!!
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: Mr.Yuck] #28578
07/29/06 06:41 PM
07/29/06 06:41 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Find a used Holley Street Dominator.Proballt the best BB intake ever made and it will fit under the stock hood.Good bottom and top end.Just they only remake them for the RB motor.Rocky
Chrysler Firepower
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: therocks] #28579
07/30/06 01:42 AM
07/30/06 01:42 AM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Thanx for all the info guys
I am running 2500 stall and just under 10:1 compression
Headers - Probably in the near future , but not right now
I have heard and read great things about the holley intake and eddy rpm - Mopar muscle , I have an issue were they tested 11 intakes on a 440 - Wow those two were nothing short of amazing on the dyno - The DP4 are for sale on ebay all the time
How much will a Carb Spacer help on the Performer Intake that i have right now ??? If any or time to start looking for an new intake also
Siberian Huskies
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28580
07/30/06 09:47 AM
07/30/06 09:47 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I'd try a 4 hole 1/2 inch. If you want to go w/ a longer (/6) throttle cable and use a drop base you could try a 1" although not sure if it would help. I see they have new tapered 4 hole spacers I might try one of those on my 440 build...but they aren't cheap! Ine good thing about spacers is they get the carb off the hot intake. Make sure you get the valley pan w/ heat riser block offs. This will also keep the intake temp down. Good luck.
Coming soon!!!!
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: Mr.Yuck] #28581
07/30/06 10:38 AM
07/30/06 10:38 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
Cant hurt to try the intake spacer. They are cheap. I dont know if you will feel anything in the seat of your pants, but some back to back track runs will tell the story. As cheap as they are your could buy a few different types and report back.
I have a B engine SD for my car.
Doc.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: Mr.Yuck] #28582
07/30/06 01:10 PM
07/30/06 01:10 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Already have the Fel Pro valley pan with block offs installed
Going to the Nats in a few weeks , will look into some carb spacers or possibly a used Holley or Eddy Rpm intake for under a million
Siberian Huskies
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28583
07/30/06 01:16 PM
07/30/06 01:16 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
yeah I decided to sell my RPM and get a street dominator. RPM is way too tall to clear the hood in my satellite without a drop base air cleaner, plus with the SD I can keep my thermoquad.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: DaytonaTurbo] #28584
07/30/06 01:29 PM
07/30/06 01:29 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
And a Holley or Eddy/Carter bolts on without an adapter!
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: DaytonaTurbo] #28585
07/31/06 12:37 PM
07/31/06 12:37 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
you have a 440 , the hood clearance issue is less with a low deck as the OP has .
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: bee1971] #28586
07/31/06 12:53 PM
07/31/06 12:53 PM
Cornfield. IN
Clair Offline
Pot Stirrer #4
Clair  Offline
Pot Stirrer #4
Cornfield. IN
For the best bang for the buck I would switch cams. The 484 has 2 much overlap for logs.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: JohnRR] #28587
07/31/06 01:34 PM
07/31/06 01:34 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I run an RPM on my 383 in a 67 Satellite. I like the stock look too, I even painted the manifold so it would look as stock as possible, but Theres no way a complete stock air cleaner would fit. I really wanted to use the Eddy RPM package and already had the cam, so I made due. I took a drop base cleaner, painted it black and found a re-production sticker. Even this setup barely clears. Its not stock, but it has that low-key look and I really like how it turned out. I do think if you run a drop base & put the stock top over the element & it would work, & retain the stock look. If I can ever figure out how to publish pics to the web, I'll throw a pic in.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: StealthWedge67] #28588
07/31/06 02:12 PM
07/31/06 02:12 PM
Puyallup, WA
Puyallup, WA
figured it out.... Heres mine, That's a Performer RPM with an Eddy 750 atop. It's close, but it fits under the stock hood.
Re: 383 Intakes - Edelbrock - Mopar - Dual planes [Re: StealthWedge67] #28589
07/31/06 06:57 PM
07/31/06 06:57 PM
Sobieski Wi
bee1971 Offline OP
bee1971  Offline OP
Sobieski Wi
Looks like your using the factory kick down linkage - How does that work using the RPM Intake
I know they make higher adapters(Aftermarket) for that style linkage but on my 71 Bee my kickdown linkage is different - Not a threaded rod - 71 uses a one piece rod that you loosen a bolt and slide it were you need it for kickdown - Look at my attachment or picture of engine in earlier thread
Havnt seen this type of higher adapters for 71 kickdown linkage using the RPM Intake
Thanx Scott
Siberian Huskies
