1970 Alternator Recommendation #2855864
12/05/20 10:31 PM
12/05/20 10:31 PM
MoreParts Offline OP
Anyone have a part number and seller to a new 60ish amp round back single groove AND double spade alternator? I'm looking for a replacement and the ones that show up are all square backs. I've found the round backs with some '69 cars but they're all single spade.
Re: 1970 Alternator Recommendation [Re: MoreParts] #2855887
12/06/20 12:34 AM
12/06/20 12:34 AM
I found the PowerMaster 7018. It's a 95amp. Any concerns for stock wiring?
https://www.speedwaymotors.com/Powermaster-7018-Retro-Alternator-95-Amps-V-belt-12V-Chrysler,335545.html
Re: 1970 Alternator Recommendation [Re: MoreParts] #2855901
12/06/20 04:27 AM
12/06/20 04:27 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I have several 1970-71 toys running the PowerMaster 7018 on the stock wiring/stock amp meter ZERO issues, Zero failures, the oldest 7018 unit I have in use is approximately 16 yrs old...
Mike
Re: 1970 Alternator Recommendation [Re: DAYCLONA] #2855903
12/06/20 06:23 AM
12/06/20 06:23 AM
Just put in my order. Thanks!
Re: 1970 Alternator Recommendation [Re: MoreParts] #2871016
01/08/21 11:56 AM
01/08/21 11:56 AM
Maryland
wally426ci Offline
wally426ci  Offline
Maryland
How did it go? Looks like they no longer make the 75 Amp versions which I run. Just curious in case I need to order....
Re: 1970 Alternator Recommendation [Re: wally426ci] #2871389
01/08/21 10:24 PM
01/08/21 10:24 PM
It went well. Installed and looks like an original. I spoke with one of their tech people and I was told the casting is all new too. The back bearing looks like an original style too. I painted the front pulley black, installed my red tag label, and black plastic hot wire protector and it's back to looking very close to factory. None of the scary wire melting problems I was concerned about. I don't see any significant difference over the prior alt I had that was rated at 65amps though so I predict you won't see much either if you already have a 75. I guess the car just pulls what it needs.
Re: 1970 Alternator Recommendation [Re: MoreParts] #2871442
01/09/21 12:43 AM
01/09/21 12:43 AM
BDW Offline
BDW  Offline
Got a pic of the install?
Re: 1970 Alternator Recommendation [Re: MoreParts] #2871512
01/09/21 10:29 AM
01/09/21 10:29 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
My concern with the OE design is, if something were to occur with the battery and all 95 amps head through the bulkhead connector to the ammeter, I can't imagine things would end well. Unless I'm mistaken on how the OE meter would respond.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: 1970 Alternator Recommendation [Re: A39Coronet] #2871516
01/09/21 10:36 AM
01/09/21 10:36 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
If you look at the stock ammeter in a '68-'70 Charger, high scale is 40 amperes. So if you ran 95 amps through it, the needle would be pegged to the right. Fortunately ammeters are pretty rugged and I doubt if the gauge would be damaged but the stock wiring harness at 95 amps? That probably won't turn out well.
Re: 1970 Alternator Recommendation [Re: A39Coronet] #2871564
01/09/21 11:58 AM
01/09/21 11:58 AM
Long Island, NY
70plymA34 Offline
70plymA34  Offline
Long Island, NY
Wouldn't the fusible link prevent that? or is that in line with the battery?
Super Commando
Re: 1970 Alternator Recommendation [Re: 70plymA34] #2871672
01/09/21 03:00 PM
01/09/21 03:00 PM
One of the things the tech told me was the alternator doesn't put out the full amperage at low idle. That occurs at max rpm. I'm not sure how that would play out with a bad component type situation, but I can say from my own use of the alt I don't see a difference with things like the brightness of my rally gauges at idle.
Re: 1970 Alternator Recommendation [Re: BDW] #2871715
01/09/21 03:50 PM
01/09/21 03:50 PM
Re: 1970 Alternator Recommendation [Re: MoreParts] #2871726
01/09/21 04:01 PM
01/09/21 04:01 PM
BDW Offline
BDW  Offline
Looks good, thx for the pics
Re: 1970 Alternator Recommendation [Re: BDW] #2871744
01/09/21 04:26 PM
01/09/21 04:26 PM
Glad to help!
Re: 1970 Alternator Recommendation [Re: MoreParts] #2872294
01/10/21 10:00 PM
01/10/21 10:00 PM
People's Republic of Kali
70runner Offline
70runner  Offline
The wire/insulation near the alternator battery terminal looks like it might benefit from a replacement/retape, up to the connector. Never know when you might be wrenching in the area.
Re: 1970 Alternator Recommendation [Re: 70runner] #2872329
01/10/21 11:31 PM
01/10/21 11:31 PM
Good point. I may give some of that liquid insulation I've seen you can paint on from Home Depot a shot.
