Re: '93 Dakota suddenly won't run below NOT fixed [Re: Grizzly] #2840173
11/01/20 01:52 PM
11/01/20 01:52 PM
Between Houston & Galveston TX
SattyNoCar Online work OP
SattyNoCar  Online Work OP
Originally Posted by Grizzly
Originally Posted by Satilite73
The new one is under warranty, so I may just swap it out after checking a few things. scope hammer
That's a good move, my experience with aftermarket sensors or anything electrical is terrible. If the part is NS1 at the dealer, go to Pick and Pull and grab a few.
I read somewhere that aftermarket replacement parts like this don't play well with the computer? I priced a 'genuine' Mopar one and the price was $70-$100. shock I bought a Standard Brand one from ORileys for $42.
With my bum ankle, I haven't had the ability to go wander a PNP for parts. frowwn
John
Re: '93 Dakota suddenly won't run below NOT fixed [Re: moparx] #2840174
11/01/20 01:53 PM
11/01/20 01:53 PM
Originally Posted by moparx
Originally Posted by TJP
Silly question? Any chance the temp sensor is bad and possibly going open or giving the wrong value to the ECM. shruggy Just a thought wink
i have seen temperature sensors act like that when they have a "coating" of sorts on the bulb that sees the coolant.
when shined up to "new" brass, sometimes they come back to life.
would be an easy thing to try.
beer
Is there more than one? Temp gauge seems to work correctly. shruggy
John
Re: '93 Dakota suddenly won't run below NOT fixed [Re: SattyNoCar] #2840196
11/01/20 02:29 PM
11/01/20 02:29 PM
Before I scampered off to ORileys, I took a look the new IAC I had installed. Unlike the old one, it IS adjustable. Hmmmm. Went to Standards website, and found instructions on how to adjust it. My part came with no instructions, and I didn't know I HAD to adjust it. mad
Well, I made an adjustment and have it running now. I'll see how it is once it gets up to temp.
PART LINKY with link to instructions.
luck
John
Re: '93 Dakota suddenly won't run below NOT fixed [Re: SattyNoCar] #2840203
11/01/20 02:42 PM
11/01/20 02:42 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
beer
There are actually two temp sensors on the Magnums. One is for the gauge, the other is for the computer.
They are close to each other, but one kinda hides back in there.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: '93 Dakota suddenly won't run below NOT fixed [Re: hp383] #2840366
11/01/20 08:05 PM
11/01/20 08:05 PM
I think it needs a little more adjusting, but for now, she's a runner again! Thanks everyone! beer
John
Re: '93 Dakota suddenly won't run below NOT fixed [Re: SattyNoCar] #2840378
11/01/20 08:37 PM
11/01/20 08:37 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Yeah, the PCM is reading in milivolts.........if them Jobber Clowns can't get a cotter pin hole in the right spot on ball joints, you can be certain their voltage range is at least a decimal point out of spec down
You are so missing out on the finer things, I just picked up a Hurst shifter from PNP for 7 dollars yesterday! grin Glad you got it fixed, sounds good to me. up
Mo' Farts
Moderated by "tbagger".
Re: '93 Dakota suddenly won't run below NOT fixed [Re: Grizzly] #2841004
11/02/20 10:44 PM
11/02/20 10:44 PM
Well, still not 100%. frown (haven't made more adjustments since video) It's in the upper 50's here now and I used the truck tonite to run a few errands after work.
Cold start, started fine, idle was a little low, but it did idle. Full temp, idled as in video.
However, that gray area between not quite cold and not quite hot caused issues. I had to two foot it a few times until the temp came back up.
popcorn
John
Re: '93 Dakota suddenly won't run below MAYBE fixedd [Re: SattyNoCar] #2853047
11/29/20 06:50 PM
11/29/20 06:50 PM
Well, got tired of jackin' with the aftermarket part and bought a genuine MOPAR one instead........
shock
Initial driving impressions are that the truck has NEVER run this smooth or has been as responsive.
Stop and go traffic, blasting down the freeway, cold start, hot start, lukewarm start, it never missed a beat.
Dare I say I have my truck back? work
luck
John
Re: '93 Dakota suddenly won't run below MAYBE fixedd [Re: SattyNoCar] #2853143
11/29/20 10:16 PM
11/29/20 10:16 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Did you buy the Mopar one from a dealer, or someplace else? Mind telling us how much it cost? Gene
Re: '93 Dakota suddenly won't run below MAYBE fixedd [Re: SattyNoCar] #2853150
11/29/20 10:43 PM
11/29/20 10:43 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
[quote=Satilite73]
What OE part,temp sensor? or??
Re: '93 Dakota suddenly won't run below MAYBE fixedd [Re: RTSrunner] #2853174
11/29/20 11:52 PM
11/29/20 11:52 PM
The only place I could find an IAC was on ebay.
Here's the listing: Mopar 53030657AB Idle Air Control
Supposedly the last one they had in stock.
Got here sooner than estimated.
Local dealer didn't have one and couldn't get one. Knowing one was on ebay, I didn't argue with the dealer about it.
John
Re: '93 Dakota suddenly won't run below MAYBE fixedd [Re: SattyNoCar] #2853570
11/30/20 09:39 PM
11/30/20 09:39 PM
bump because I don't know if the people who asked questions got their answer......
John
Re: '93 Dakota suddenly won't run below 1200RPM? [Re: SattyNoCar] #2854214
12/02/20 10:43 AM
12/02/20 10:43 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
Its always sounds ignorant and bad to say "I saw on the internet...." But via the internet watching legit techs/shop owners on Youtube- and repair podcasts I learned about 5 years ago when it comes to certain models - replacement sensors and computers must be an OEM unit and is the the only choice- no matter how much $$$. The trusted aftermarket name brands of yesteryear have thrown in the towel and went extra cheapie cheap.
Keep old mopars alive.
Re: '93 Dakota suddenly won't run below 1200RPM? [Re: 2boltmain] #2855524
12/05/20 01:10 AM
12/05/20 01:10 AM
iagree 100% The first one that popped into my mind when reading that statement was MOOG, but it seems prevalent with all aftermarket companies now. Unless I do something to eliminate the factory electronics in my truck, I'm pretty sure they're gonna be its downfall above anything else. frowwn flame
John
Re: '93 Dakota suddenly won't run below 1200RPM? [Re: SattyNoCar] #2855590
12/05/20 09:50 AM
12/05/20 09:50 AM
Holland MI Ottawa
2
2boltmain Offline
2boltmain  Offline
Holland MI Ottawa
A repair shop in Louisiana that has a Q&A show calls OEM parts "The Best of the Worst."
Re: '93 Dakota suddenly won't run below 1200RPM? [Re: SattyNoCar] #2855633
12/05/20 11:48 AM
12/05/20 11:48 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I was going to suggest Microsquirt, which is what I am using on my 51 Plymouth's EFI swap. However, you are still stuck with poor aftermarket parts for sensors and such. Junkyard here we come.
