Hydro Boost #2854345
12/02/20 01:51 PM
12/02/20 01:51 PM
Mesa, Arizona
dart4forte Offline OP
Mesa, Arizona
Who’s running a hydro boost braking system and which system did you use?
Abe Lincoln
Re: Hydro Boost [Re: dart4forte] #2854379
12/02/20 02:36 PM
12/02/20 02:36 PM
Odessa, Fl
blowndart Offline
blowndart  Offline
Odessa, Fl
i run one. It's a system that I adapted from a 90's mustang. I wanted power brake with a hemi in a body, Not many other ways to do it.
Re: Hydro Boost [Re: dart4forte] #2854449
12/02/20 05:29 PM
12/02/20 05:29 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
I installed one in my '69 Super Bee back in 2014.
I used a Hydratech kit on my Wilwood master cylinder w/ 4-wheel disk brakes (Wilwood front and Dr Diff rear) and it has worked flawlessly all this time.
beer
Paul
'69 Super Bee 383 EFI Turbo
Re: Hydro Boost [Re: dart4forte] #2854602
12/02/20 10:59 PM
12/02/20 10:59 PM
ILL
Greentween Offline
Greentween  Offline
ILL
I have the kit from sterlingworth on ebay. If you want to piece together yourself and fab the mounting plate, he also sells the special socket you need.
https://www.ebay.com/usr/sterlingworth16
I made some videos on youtube about the install.
https://www.youtube.com/watch?v=NrjRnQGj5fU&t=37s
Re: Hydro Boost [Re: dart4forte] #2855382
12/04/20 06:42 PM
12/04/20 06:42 PM
Alberta Canada
PossessedDuster Offline
Alberta Canada
I have a Hydratech system in my Belvedere. Going from manual brakes to power was a huge step but the car stops so much better with no other changes.
No problems with the system and the install went without any issues.
With disc up front drum in the rear I did need to adjust the proportioning valve as the drums wanted to lock up instantly with the extra pressure but it dialed in quick and works great.
Re: Hydro Boost [Re: dart4forte] #2856370
12/07/20 05:02 AM
12/07/20 05:02 AM
Norway
cudaerik Offline
cudaerik  Offline
Norway
Running a 1991 Chevrolet Suburban unit that I picked up at the yard for 30 bucks, had to modify the length of the push rod and made a new baseplate for it to mount it on the firewall. pressed new hoses at a local hydraulic hose shop. Here is an article that covers the whole thing (I know it's Chevy but would be the same process to do this on a Mopar) https://bangshift.com/general-news/...-on-your-classic-gm-muscle-car-or-truck/
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600)
1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600)
1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Hydro Boost [Re: cudaerik] #2856371
12/07/20 05:13 AM
12/07/20 05:13 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
is there any way to use one of those with manual steering?
Re: Hydro Boost [Re: bonefish] #2856752
12/07/20 07:43 PM
12/07/20 07:43 PM
BC, Canada
Black_Bee Offline
Black_Bee  Offline
BC, Canada
There is no reason why you couldn't run a power steering pump with a manual steering box and use the pressure output from the pump to only run the hydro boost. You could probably even use an electric power steering pump to do it if you wanted to avoid the stock engine driven PS pump.
beer
Paul
Re: Hydro Boost [Re: Black_Bee] #2856908
12/08/20 05:59 AM
12/08/20 05:59 AM
Guitar Jones Offline
I used one off a 2000 diesel pickup truck on my 92. What I learned is most all the systems are basically the same with differences being with the mounting plate, I made my own, the pushrod length and eyelet size and the master cylinder mounting. You can buy a rebuild kit for them for about $40 so a junkyard unit is just as good as a $200 reman unit if you reseal it. Just use a master cylinder that matches. Depending on the unit will depend on what you have to do to the pushrod. I would stay away from the Dodge truck unit as the pushrod is too long and the master cylinder is clocked differently with an adapter so it ends up being longer. The GM 3500 van units are common in the yards and probably the easiest one to adapt.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Hydro Boost [Re: Black_Bee] #2856913
12/08/20 06:38 AM
12/08/20 06:38 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
beer
THANKS, never thought of that.
