Hydro Boost
#2854345
12/02/20 01:51 PM
12/02/20 01:51 PM
Posts: 16,152 Mesa, Arizona
dart4forte
Mesa, Arizona
Who’s running a hydro boost braking system and which system did you use?
Abe Lincoln
Re: Hydro Boost
[Re: dart4forte]
#2854449
12/02/20 05:29 PM
12/02/20 05:29 PM
Posts: 1,307 BC, Canada
Black_Bee
BC, Canada
Who’s running a hydro boost braking system and which system did you use? I installed one in my '69 Super Bee back in 2014. I used a Hydratech kit on my Wilwood master cylinder w/ 4-wheel disk brakes (Wilwood front and Dr Diff rear) and it has worked flawlessly all this time.
Paul '69 Super Bee 383 EFI Turbo
Re: Hydro Boost
[Re: dart4forte]
#2856370
12/07/20 05:02 AM
12/07/20 05:02 AM
Posts: 84 Norway
cudaerik
Norway
Running a 1991 Chevrolet Suburban unit that I picked up at the yard for 30 bucks, had to modify the length of the push rod and made a new baseplate for it to mount it on the firewall. pressed new hoses at a local hydraulic hose shop. Here is an article that covers the whole thing (I know it's Chevy but would be the same process to do this on a Mopar) https://bangshift.com/general-news/...-on-your-classic-gm-muscle-car-or-truck/
1970 Plymouth Cuda, 512cid on 230 400 block, 5 speed manual.(TKO 600) 1970 Dodge Charger 500, 446cid, 5speed manual.(TKO 600) 1969 Plymouth Roadrunner, 383cid, 5speed manual (Tremec TKX)
Re: Hydro Boost
[Re: bonefish]
#2856752
12/07/20 07:43 PM
12/07/20 07:43 PM
Black_Bee
BC, Canada
is there any way to use one of those with manual steering? There is no reason why you couldn't run a power steering pump with a manual steering box and use the pressure output from the pump to only run the hydro boost. You could probably even use an electric power steering pump to do it if you wanted to avoid the stock engine driven PS pump.
Re: Hydro Boost
[Re: Black_Bee]
#2856908
12/08/20 05:59 AM
12/08/20 05:59 AM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I used one off a 2000 diesel pickup truck on my 92. What I learned is most all the systems are basically the same with differences being with the mounting plate, I made my own, the pushrod length and eyelet size and the master cylinder mounting. You can buy a rebuild kit for them for about $40 so a junkyard unit is just as good as a $200 reman unit if you reseal it. Just use a master cylinder that matches. Depending on the unit will depend on what you have to do to the pushrod. I would stay away from the Dodge truck unit as the pushrod is too long and the master cylinder is clocked differently with an adapter so it ends up being longer. The GM 3500 van units are common in the yards and probably the easiest one to adapt.
Re: Hydro Boost
[Re: Black_Bee]
#2856913
12/08/20 06:38 AM
12/08/20 06:38 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
is there any way to use one of those with manual steering? There is no reason why you couldn't run a power steering pump with a manual steering box and use the pressure output from the pump to only run the hydro boost. You could probably even use an electric power steering pump to do it if you wanted to avoid the stock engine driven PS pump. THANKS, never thought of that.
