piece together vs buying one done #2852651
11/28/20 05:43 PM
11/28/20 05:43 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
I have never bought a crate motor before and I have had several motors put together from a 273 all the way to a 426 hemi. One both the hemis I purchased pieces as money permitted then took it all to the machine shop, but I am just wandering is it worth all the leg work? I see several places that off turn key done motors and was just wandering what's everyone else's view on this?
Re: piece together vs buying one done [Re: maxie] #2852663
11/28/20 06:27 PM
11/28/20 06:27 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Only as good as the man who did the work.
If he's not there, doesn't remember, didn't complete it you're walking into a minefield.
I could name a famous MoPar shop that forget to check if the rods cleared the block before they shipped it... and they didn't, the engine had never been turned over.
Boffin Emeritus
Re: piece together vs buying one done [Re: polyspheric] #2852668
11/28/20 06:47 PM
11/28/20 06:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Agree, there are good and not-so-good.
I'm paranoid enough now that on a crate I'd want to open it up & double check, and I'd want to run it on a test stand before plugging it in.
But much of what I see advertised seems a pretty good deal. Time is money in some situations...
About 30 years a go a noted & well-known SoCal engine builder with Hemi experience from his days in SS driving & tuning for Landy, rebuilt my tired Hemi.
Ran great - still does - though I had to get the carbs sorted out.
10 years after that, he went through my drag-race SB, and it had problems right away, and I took it back to him.
Those flaws went uncorrected & turned fatal on its 3rd pass, only saved the intake & valve covers.
$10,000 out the window, teardown showed horrible stuff, valve reliefs milled through the pistons, oiling & fastener & torque mistakes, I could go on.
Re: piece together vs buying one done [Re: polyspheric] #2852690
11/28/20 07:49 PM
11/28/20 07:49 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
How is that even possible? Got to spin the crank to install the rods. Just absolutely pathetic.
Re: piece together vs buying one done [Re: maxie] #2852695
11/28/20 07:56 PM
11/28/20 07:56 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If it isn't a daily driver, then no reason not to do it yourself if you have the knowledge. Even on daily driver stuff I will still buy a core and go through it, then swap it out. Just this last year, I have bought two small block stroker builds with spun bearings because so called machine shops used full width bearings on fillet crank journals. I just can't bring myself to trust anyone else's work.
Re: piece together vs buying one done [Re: maxie] #2852698
11/28/20 07:59 PM
11/28/20 07:59 PM
AndyF Online content
AndyF  Online Content
The only way for a shop to be efficient at building crate engines is to use all new parts but that option doesn't exist for SB or BB Mopar engines. So the whole concept of crate engines for SB or BB Mopar engines is lacking. The shop I work with has a supply of core engines and he builds one BB Mopar per month on average. That isn't exactly a crate engine shop but he builds them often enough that he keeps parts in stock and he knows how they go together. If you go to a shop like Barton or Best Machine they might build more than an engine a week. Volume helps to keep the price down but nobody offers true volume pricing on Mopar engines since nobody is building enough engines to drive the price of parts down.
Re: piece together vs buying one done [Re: AndyF] #2852748
11/28/20 10:18 PM
11/28/20 10:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
I would trust a crate job as far as I can throw it!! Even just machine shop work has to be rechecked for accuracy!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: piece together vs buying one done [Re: hemi-itis] #2852763
11/28/20 10:54 PM
11/28/20 10:54 PM
Indiana
maxie Offline OP
maxie  Offline OP
Indiana
it is sad that I live right outside of Indianapolis and I bought a set of heads from Porter off the east coast.
Re: piece together vs buying one done [Re: hemi-itis] #2853695
12/01/20 09:25 AM
12/01/20 09:25 AM
an8sec70cuda Offline
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: piece together vs buying one done [Re: an8sec70cuda] #2853719
12/01/20 10:41 AM
12/01/20 10:41 AM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I enjoy the building part of it so for me I would much rather piece it together. Plus that way I can put the best parts in it. I enjoy building the motor more than driving the car. I guess I'm a motorhead. When a friends car blows up he thinks it's the end of the world and I'm over in the corner thinking.......YES!
2011 Drag Pak Challenger
Re: piece together vs buying one done [Re: rickseeman] #2853730
12/01/20 10:58 AM
12/01/20 10:58 AM
hemi-itis Offline
hemi-itis  Offline
I agree,yet the machine work needs to be verified and rechecked BEFORE assembly! scope
Have heard too many stories,,,,,guides to tight,,,or loose. Final cylinder finish,pistin fit, you get the picture.
Re: piece together vs buying one done [Re: maxie] #2853782
12/01/20 01:24 PM
12/01/20 01:24 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
I typically (when time isn't a concern) piece a motor together. As stated prior, you get to put the parts in that you want at the price you want to pay. I look for opportunity's for cost savings and don't feel the need to have" a motor that has all new parts in it when sometimes used will do. Also as with what was posted (somewhere here on MOPARTS) Speedmaster (for example) had a 40% off sale. You don't get those discounts when buying a Crate/complete motor assembly. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
