Re: piece together vs buying one done
[Re: maxie]
#2852663
11/28/20 06:27 PM
11/28/20 06:27 PM
Posts: 4,206 New York
polyspheric
New York
Only as good as the man who did the work. If he's not there, doesn't remember, didn't complete it you're walking into a minefield. I could name a famous MoPar shop that forget to check if the rods cleared the block before they shipped it... and they didn't, the engine had never been turned over.
Boffin Emeritus
[Re: polyspheric]
#2852668
11/28/20 06:47 PM
11/28/20 06:47 PM
Posts: 20,748 A collage of whims
topside
A collage of whims
Agree, there are good and not-so-good. I'm paranoid enough now that on a crate I'd want to open it up & double check, and I'd want to run it on a test stand before plugging it in. But much of what I see advertised seems a pretty good deal. Time is money in some situations... About 30 years a go a noted & well-known SoCal engine builder with Hemi experience from his days in SS driving & tuning for Landy, rebuilt my tired Hemi. Ran great - still does - though I had to get the carbs sorted out. 10 years after that, he went through my drag-race SB, and it had problems right away, and I took it back to him. Those flaws went uncorrected & turned fatal on its 3rd pass, only saved the intake & valve covers. $10,000 out the window, teardown showed horrible stuff, valve reliefs milled through the pistons, oiling & fastener & torque mistakes, I could go on.
[Re: polyspheric]
#2852690
11/28/20 07:49 PM
11/28/20 07:49 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
Only as good as the man who did the work. If he's not there, doesn't remember, didn't complete it you're walking into a minefield. I could name a famous MoPar shop that forget to check if the rods cleared the block before they shipped it... and they didn't, the engine had never been turned over. How is that even possible? Got to spin the crank to install the rods. Just absolutely pathetic.
[Re: AndyF]
#2852748
11/28/20 10:18 PM
11/28/20 10:18 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
I would trust a crate job as far as I can throw it!! Even just machine shop work has to be rechecked for accuracy!
[Re: hemi-itis]
#2853695
12/01/20 09:25 AM
12/01/20 09:25 AM
Posts: 13,354 Marion, South Carolina [><]
an8sec70cuda
[Re: an8sec70cuda]
#2853719
12/01/20 10:41 AM
12/01/20 10:41 AM
Posts: 2,631 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I enjoy the building part of it so for me I would much rather piece it together. Plus that way I can put the best parts in it. I enjoy building the motor more than driving the car. I guess I'm a motorhead. When a friends car blows up he thinks it's the end of the world and I'm over in the corner thinking.......YES!
2011 Drag Pak Challenger
[Re: rickseeman]
#2853730
12/01/20 10:58 AM
12/01/20 10:58 AM
hemi-itis
I enjoy the building part of it so for me I would much rather piece it together. Plus that way I can put the best parts in it. I enjoy building the motor more than driving the car. I guess I'm a motorhead. When a friends car blows up he thinks it's the end of the world and I'm over in the corner thinking.......YES! I agree,yet the machine work needs to be verified and rechecked BEFORE assembly! Have heard too many stories,,,,,guides to tight,,,or loose. Final cylinder finish,pistin fit, you get the picture.
[Re: maxie]
#2853782
12/01/20 01:24 PM
12/01/20 01:24 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
I typically (when time isn't a concern) piece a motor together. As stated prior, you get to put the parts in that you want at the price you want to pay. I look for opportunity's for cost savings and don't feel the need to have" a motor that has all new parts in it when sometimes used will do. Also as with what was posted (somewhere here on MOPARTS) Speedmaster (for example) had a 40% off sale. You don't get those discounts when buying a Crate/complete motor assembly.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
