413-426 Forged Pistons. Any interest? #2849676
11/21/20 06:43 PM
11/21/20 06:43 PM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
Any interest in pistons for 413 and 426 wedge? Idea is to offer a std 4.250 bore ( which should save the 413 blocks) and 3 oversizes. for the 426 blocks.
No max wedge pistons but they may have a very small dome if needed to raise cr. 5-7cc?
specs
Stock stroke 3.750
2.07 c.d
1/16 1/16 3/16 ring pack
Accumulator groove
.990 pin
Flat top with 4.5 cc notches
Complete w/pins and locks.
Approx 640 Grams
Your comments are welcome.
Leave the gun.......take the Cannoli's....Mike
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2849740
11/21/20 09:13 PM
11/21/20 09:13 PM
Florida STAYcation
dOrk ! Offline
The village idiot's idiot
dOrk !  Offline
Florida STAYcation
I’m interested .... but THAT MANY over sizes ?
What kind of cost ?
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2849800
11/22/20 12:15 AM
11/22/20 12:15 AM
AndyF Online content
AndyF  Online Content
426 engine blocks are fairly rare and anyone who can afford a block could easily afford custom pistons. 413 blocks on the other hand are fairly cheap to find since they aren't very desirable. Therefore, I bet you could sell some inexpensive pistons to low buck guys who round up a 413 block and want a decent compression piston. If it was me I'd design a 413 piston that provide 9.5 to 10.0 compression with a cheap head like the 440Source or the E Street. If you do that you might find a market niche in the low buck area. I don't think I'd bother making a 426W piston. Demand for them has to be close to zero.
Re: 413-426 Forged Pistons. Any interest? [Re: dOrk !] #2849881
11/22/20 11:59 AM
11/22/20 11:59 AM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
What kind of cost ?
Cost should be about the same as the 383 pistons I did a couple years back. 625.00. Just floating a balloon on oversizes.
Re: 413-426 Forged Pistons. Any interest? [Re: AndyF] #2849887
11/22/20 12:22 PM
11/22/20 12:22 PM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
Andy, I think you are correct. 426 demand would be low. However I can use 1 piston blank to cover 3 wedge engines. That is the reason I included all the oversizes.May only need one size. Otherwise this piston is exactly what you called for. Lots of 413 blocks out there.Nothing wrong with a 426 for mostly street use with a E street or pro maxx type cyl head. On a performance note these pistons really wake up these engines esp when they have a stock or trw type piston. My customers all have been very happy with the 383 piston.
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2849906
11/22/20 01:11 PM
11/22/20 01:11 PM
You can offer all the oversizes you want but I wouldn't invest in a lot of inventory.
Re: 413-426 Forged Pistons. Any interest? [Re: AndyF] #2849949
11/22/20 02:17 PM
11/22/20 02:17 PM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
I agree. Thank you for the comments
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2849976
11/22/20 03:13 PM
11/22/20 03:13 PM
Florida STAYcation
dOrk ! Offline
dOrk !  Offline
Florida STAYcation
413 blocks aren’t very desirable?
Been awhile since I’ve done any extensive engine work but I’ve heard way diff than that.
Those 413 industrial blocks are some stout pieces
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2850104
11/22/20 07:32 PM
11/22/20 07:32 PM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
.040" o.s. for a 413 that would be able to make a 0 deck with a light deck cut , and SMALL valve reliefs . ,< big reliefs reduce compression , most cams are normaly only .500" lift ! >
why waist my thick cyl wall by maxing it out on first rebuild .
might bore it to 426 second time around .
thicker walls stay more stable !
Re: 413-426 Forged Pistons. Any interest? [Re: calrobb2000] #2850743
11/23/20 10:09 PM
11/23/20 10:09 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
I would be interested in the 4.250 bore, if these are a Go let me know, Thanks
Re: 413-426 Forged Pistons. Any interest? [Re: wyoming] #2851472
11/25/20 05:04 PM
11/25/20 05:04 PM
USA
SSAAHemiFan Offline
SSAAHemiFan  Offline
USA
I am interested - I have a street wedge that should clean up at .020 or .030 over. Restoration engine
Re: 413-426 Forged Pistons. Any interest? [Re: SSAAHemiFan] #2853195
11/30/20 01:01 AM
11/30/20 01:01 AM
Mi,U.S.A.
mike s Offline OP
mike s  Offline OP
Mi,U.S.A.
I will be in touch ,as I have to work this out with Icon. Likely will be a preorder deal. Thanks for the interest.
Re: 413-426 Forged Pistons. Any interest? [Re: mike s] #2904275
03/30/21 12:41 PM
03/30/21 12:41 PM
las vegas,nv
mopar muscle7271 Offline
las vegas,nv
Yah lookin for 426 wedge pistons
Re: 413-426 Forged Pistons. Any interest? [Re: mopar muscle7271] #2904462
03/31/21 06:14 AM
03/31/21 06:14 AM
Isle of Sheeps
Gtxxjon Offline
Gtxxjon  Offline
Isle of Sheeps
Nice one Mike,
Someone showing some genuine interest in early RB’s!
I have two 413 blocks, both with little to no wear.
Can I find a set of stock pistons from a 60’s high comp engine?
NO they all got junked when folks bored them for 426 cubes....
Like the idea of 0.990 pins too.
Flat top around Zero deck with some valve reliefs and ‘light as a feather’ whooppee dino
The 60’s are back in fashion again... drive
Carpe diem, quam minimum credula postero, thanx Horace!
There’s no point trying to fix stuff that ain’t broke,,, 'but if ain’t broke',,, you is not trying hard enough...
Re: 413-426 Forged Pistons. Any interest? [Re: Gtxxjon] #2905027
04/01/21 05:59 PM
04/01/21 05:59 PM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
I would check ring availability before I'd spec piston sizes. 413's might be best with cleaning up at 4.200 or something, due to ring sizing, is what I'm trying to say. S/F....Ken M
Re: 413-426 Forged Pistons. Any interest? [Re: EchoSixMike] #2905165
04/02/21 12:04 AM
04/02/21 12:04 AM
iI had Auto Tec, Race Tec, make the last stet of 413 pistons I had made, 4.150 stroke with a 6.86 long hemi rod bored to 4.25 after sonic testing it first.
The block is a 1972 industrial, marine, truck block with the 6 bolt forged steel crank that i used to build a offset 3.91 stroke crank with low deck mains in a 400 block pump gas motor.
I'm going to use the the built 413 block pump gas motor in my 1963 Plymouth Fury and tell everybody that is a truck motor warmed up a little devil whistling grin
