big block timing chain set recommendations #2843125
11/07/20 05:19 PM
11/07/20 05:19 PM
St.Pete,Florida
lancer493 Offline OP
St.Pete,Florida
Am looking for a quality replacement 9 way ajustable timing chain set for big block roller cam race motor. Currently have a Cloyes unit with a thrust bearing that I am done trying to work with. They dropped the ball with that one. I remember talking with Cab about that one. Not sure what his solution was. I will be using a thrust button or Mancini thrust bearing and an Indy cast timing cover.Trickflow has one listed as part# TFS 61678525 and was wondering if that set was up to the job. Would like to hear from all who have had good results with any others also. Thanks,Bill
Re: big block timing chain set recommendations [Re: lancer493] #2843818
11/09/20 08:59 AM
11/09/20 08:59 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Rollmaster.
69 GTX 68 Road Runner
Re: big block timing chain set recommendations [Re: JERICOGTX] #2843846
11/09/20 09:36 AM
11/09/20 09:36 AM
an8sec70cuda Offline
Originally Posted by JERICOGTX
Rollmaster.
iagree
CHIP
'06 GMC 2500HD LBZ Duramax
Re: big block timing chain set recommendations [Re: an8sec70cuda] #2843906
11/09/20 10:38 AM
11/09/20 10:38 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
I thought PROGEAR is what everone was suggesting at one time shruggy
Re: big block timing chain set recommendations [Re: RATTRAP] #2843928
11/09/20 11:27 AM
11/09/20 11:27 AM
St.Pete,Florida
St.Pete,Florida
Anyone have any experience with using a Trick flow or any other unit with a cam thrust button and Indy cast alum. timing cover for solid roller applicaton. Cab has recommended comp cams #7125 and it looks really good on the face of the cam gear from the photos. Looks like more room to accomodate a thrust button and bolts. Thanks, Bill
Re: big block timing chain set recommendations [Re: RATTRAP] #2843936
11/09/20 11:37 AM
11/09/20 11:37 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
I bought one and the gears looked nice. Comes with a rolon chain however and I saw some reports of failures so bought a Rollmaster set to replace it.
Re: big block timing chain set recommendations [Re: INTMD8] #2844217
11/09/20 07:50 PM
11/09/20 07:50 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Rollmater gears, Iwis chain.
Re: big block timing chain set recommendations [Re: jim sciortino] #2844358
11/10/20 02:58 AM
11/10/20 02:58 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
Rollmaster. The original owner was a Mopar guy.
Re: big block timing chain set recommendations [Re: 572B1] #2844404
11/10/20 09:11 AM
11/10/20 09:11 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Ok
After reading these post's I will not install the Cloyes timing chain that i purchased a while back for my Future block, Now im waiting on the CS5150 rollmaster that i just ordered.
Re: big block timing chain set recommendations [Re: RATTRAP] #2844407
11/10/20 09:20 AM
11/10/20 09:20 AM
Ok
Wise choice. Years ago when I freshened up my hemi I found some metal chunks in the oil pan. Didn't know where they came from initially...motor was running perfect. After looking over everything, I found the timing chain center links were breaking apart and the pieces were piling up in the oil pan. Luckily they weren't small enough to make it though the oil pickup. It was the expensive billet Cloyes Hex-a-just timing set.
Replaced it w/ a Rollmaster and it's been fine ever since.
CHIP
Re: big block timing chain set recommendations [Re: an8sec70cuda] #2844410
11/10/20 09:33 AM
11/10/20 09:33 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
Yup!
Its the billet Cloyes Hex-a-just timing set that im shelfing for the Rollmaster
Re: big block timing chain set recommendations [Re: RATTRAP] #2847918
11/18/20 12:04 AM
11/18/20 12:04 AM
Memphis
HemiRick Offline
HemiRick  Offline
Memphis
I was looking for a timing set for my 5.0 Mustang and this thread was just in time. Ordered a Rollmaster 10030 and its the nicest timing set I've ever seen.....Really like the torrington bearings.
Take care,
Rick
68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: big block timing chain set recommendations [Re: lancer493] #2848442
11/19/20 01:50 AM
11/19/20 01:50 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
Anything can fail under the right circumstances.
- Stu Harmon
Re: big block timing chain set recommendations [Re: feets] #2848453
11/19/20 03:31 AM
11/19/20 03:31 AM
Dude, you have the worst luck I've seen shock
How bad did that failure affect the rest of the motor?
Re: big block timing chain set recommendations [Re: feets] #2848471
11/19/20 06:15 AM
11/19/20 06:15 AM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
My first thought,Is that a rollmaster?
Then after looking at the gear i see its casted steel, Im guessing the cheap part was the right circumstance for the failure.
Re: big block timing chain set recommendations [Re: Cab_Burge] #2848494
11/19/20 08:45 AM
11/19/20 08:45 AM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
That was the reason I had to tear the 440 down last time.
It is a Comp double roller set driving a .480" cam with standard Eddy heads and springs. I had about 45 minutes run time on it and was on the highway for a break in run when it happened.
We never did figure out what the exact cause was. The cam bolt washer is bent back over the bolt head so the gear was leaning on it pretty hard. The locating pin was sheared. Instead of a drilled hole for the pin Comp used a slot cut upwards from the bolt hole. We can only assume the gear shifted slightly when the pin broke and tension pulled it down on the bolt. That broke out the back side of the grear and it let go.
The strange part was damage to the rear edges of the lobes in front of each cam journal. It also took chunks out of the associated lifters.
I was out of warranty by time (2 years on the shelf) but Comp engineers had never seen that failure and replaced the cam, lifters, and timing set. No complaints with them as the went out of their way to help.
We could not rule out assembly error so I wrote it off and Sh!t Happens.
12 valves lightly kissed pistons and the front main bearing was wasted.
- Stu Harmon
Re: big block timing chain set recommendations [Re: lancer493] #2848502
11/19/20 09:07 AM
11/19/20 09:07 AM
Mt Morris Michigan
mopar dave Online content
mopar dave  Online Content
Mt Morris Michigan
The ProGear is the one you want. The last 2 cloyes is used wore out fast. The ProGear will last you a long time.
Re: big block timing chain set recommendations [Re: mopar dave] #2848537
11/19/20 10:34 AM
11/19/20 10:34 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
been very satisfied with PROGEAR'
Re: big block timing chain set recommendations [Re: mopar dave] #2848737
11/19/20 04:30 PM
11/19/20 04:30 PM
Who makes the ProGear timing sets?
Re: big block timing chain set recommendations [Re: lancer493] #2848900
11/20/20 04:23 AM
11/20/20 04:23 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
The 3-bolt 9-way roller thrust version from 440 Source has worked fine for me, but I'm only 700# open spring pressure on a 0.720" lift cam.
Use the same timing sets in 3 or 4 other engines with smaller cams.
