Re: big block timing chain set recommendations
[Re: JERICOGTX]
#2843846
11/09/20 09:36 AM
11/09/20 09:36 AM
Posts: 13,351 Marion, South Carolina [><]
an8sec70cuda
[Re: RATTRAP]
#2843936
11/09/20 11:37 AM
11/09/20 11:37 AM
Posts: 710 Lake Villa Il
INTMD8
Lake Villa Il
I thought PROGEAR is what everone was suggesting at one time I bought one and the gears looked nice. Comes with a rolon chain however and I saw some reports of failures so bought a Rollmaster set to replace it.
[Re: 572B1]
#2844404
11/10/20 09:11 AM
11/10/20 09:11 AM
Posts: 1,581 N/E, Michigan
RATTRAP
N/E, Michigan
Ok After reading these post's I will not install the Cloyes timing chain that i purchased a while back for my Future block, Now im waiting on the CS5150 rollmaster that i just ordered.
[Re: RATTRAP]
#2844407
11/10/20 09:20 AM
11/10/20 09:20 AM
an8sec70cuda
Wise choice. Years ago when I freshened up my hemi I found some metal chunks in the oil pan. Didn't know where they came from initially...motor was running perfect. After looking over everything, I found the timing chain center links were breaking apart and the pieces were piling up in the oil pan. Luckily they weren't small enough to make it though the oil pickup. It was the expensive billet Cloyes Hex-a-just timing set. Replaced it w/ a Rollmaster and it's been fine ever since.
[Re: RATTRAP]
#2847918
11/18/20 12:04 AM
11/18/20 12:04 AM
Posts: 4,848 Memphis
HemiRick
Memphis
I was looking for a timing set for my 5.0 Mustang and this thread was just in time. Ordered a Rollmaster 10030 and its the nicest timing set I've ever seen.....Really like the torrington bearings.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
[Re: lancer493]
#2848442
11/19/20 01:50 AM
11/19/20 01:50 AM
Posts: 28,067 Irving, TX
feets
Senior Management
Senior Management
Irving, TX
Anything can fail under the right circumstances.
[Re: feets]
#2848453
11/19/20 03:31 AM
11/19/20 03:31 AM
Posts: 43,099 Bend,OR USA
Cab_Burge
Dude, you have the worst luck I've seen How bad did that failure affect the rest of the motor?
[Re: feets]
#2848471
11/19/20 06:15 AM
11/19/20 06:15 AM
RATTRAP
N/E, Michigan
Anything can fail under the right circumstances. My first thought,Is that a rollmaster? Then after looking at the gear i see its casted steel, Im guessing the cheap part was the right circumstance for the failure.
[Re: Cab_Burge]
#2848494
11/19/20 08:45 AM
11/19/20 08:45 AM
feets
Senior Management
Senior Management
Irving, TX
Dude, you have the worst luck I've seen How bad did that failure affect the rest of the motor? That was the reason I had to tear the 440 down last time. It is a Comp double roller set driving a .480" cam with standard Eddy heads and springs. I had about 45 minutes run time on it and was on the highway for a break in run when it happened. We never did figure out what the exact cause was. The cam bolt washer is bent back over the bolt head so the gear was leaning on it pretty hard. The locating pin was sheared. Instead of a drilled hole for the pin Comp used a slot cut upwards from the bolt hole. We can only assume the gear shifted slightly when the pin broke and tension pulled it down on the bolt. That broke out the back side of the grear and it let go. The strange part was damage to the rear edges of the lobes in front of each cam journal. It also took chunks out of the associated lifters. I was out of warranty by time (2 years on the shelf) but Comp engineers had never seen that failure and replaced the cam, lifters, and timing set. No complaints with them as the went out of their way to help. We could not rule out assembly error so I wrote it off and Sh!t Happens. 12 valves lightly kissed pistons and the front main bearing was wasted.
[Re: mopar dave]
#2848537
11/19/20 10:34 AM
11/19/20 10:34 AM
Posts: 7,274 s.w.fl
bonefish
s.w.fl
The ProGear is the one you want. The last 2 cloyes is used wore out fast. The ProGear will last you a long time. been very satisfied with PROGEAR'
[Re: mopar dave]
#2848737
11/19/20 04:30 PM
11/19/20 04:30 PM
Cab_Burge
Who makes the ProGear timing sets?
