Trans brake reverse . #2846151
11/14/20 04:06 PM
11/14/20 04:06 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
I got one of those A&A trans brake in a 727 when i had it out last weekend i noticed that when i put it into reverse and hold the button it would go into reverse like it had lots of drag in reverse(almost like it had emergency brakes on) any ideals on this ?.....Thanks wave
Re: Trans brake reverse . [Re: racerx] #2846222
11/14/20 06:11 PM
11/14/20 06:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
Try neutral and hit the button.
Re: Trans brake reverse . [Re: rickraw] #2847124
11/16/20 04:38 PM
11/16/20 04:38 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
So what am i suppose to be looking for? engagement? shruggy
Re: Trans brake reverse . [Re: racerx] #2847309
11/16/20 10:18 PM
11/16/20 10:18 PM
Fancy Farm Ky
W
wyoming Offline
wyoming  Offline
W
Fancy Farm Ky
Yes, it should engage when you push the button
Re: Trans brake reverse . [Re: wyoming] #2847321
11/16/20 10:51 PM
11/16/20 10:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think the OP is asking this.... he pushes the button and the car backs up, but there is drag on it while backing up. Think he wants that answered
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Trans brake reverse . [Re: B3422W5] #2847331
11/16/20 11:18 PM
11/16/20 11:18 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Am I missing something? Why would he hit the transbrake button with a 727 in reverse???
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Trans brake reverse . [Re: pittsburghracer] #2847340
11/16/20 11:29 PM
11/16/20 11:29 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
He is talking about backing the car up.
I am confident the guy races enough to know how to use a brake. It drags when backing up with it
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Trans brake reverse . [Re: B3422W5] #2847345
11/16/20 11:38 PM
11/16/20 11:38 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Call A&A and ask them how the brake is supposed to be used?? My Rossler trans you dont need the brake , you put it in reverse and it backs up. I know some brakes you use the button, but i thought they were with the shifter in R. Best bet... call the manufacturer and ask
....BAD A$$ STREET CAR.....
Re: Trans brake reverse . [Re: B3422W5] #2847346
11/16/20 11:40 PM
11/16/20 11:40 PM
PA.
"Little"John
"Little"John
PA.
Do that on a powerglide and you will instantly come to an unexpected stop. Ask me how I know. That is unless it’s a “Pro brake” and then you have to push the transbrake button and hold it to back up. I’m sure if you look into and read up on 727’s hitting the button in reverse isn’t the best thing to do.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trans brake reverse . [Re: pittsburghracer] #2847369
11/17/20 01:27 AM
11/17/20 01:27 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
Many of the "Pro" 727 Transbrake require the driver to push the button on the transbrake for the car to back up.....
some allow this to happen while the shifter is in neutral or reverse.....my Tranzact will back up in either neutral or reverse with the button pressed....il
His complaint is ....the trans seem to drag while backing up in reverse.....
Tony
70 AARCuda Vitamin C
Re: Trans brake reverse . [Re: pittsburghracer] #2847382
11/17/20 04:16 AM
11/17/20 04:16 AM
To make it back up, the ones I've had needed that like the Powerglides do in my current S/P car shruggy
Re: Trans brake reverse . [Re: 70AARcuda] #2847425
11/17/20 10:10 AM
11/17/20 10:10 AM
PA.
"Little"John
"Little"John
PA.
Well then like many posts on Moparts we have to guess whether he has a pro transbrake or not. My CRT 727 is older and I pushing the transmission brake button to back up was required.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Trans brake reverse . [Re: B3422W5] #2847490
11/17/20 11:39 AM
11/17/20 11:39 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yes that is it........last year before i put it up for winter everything was fine ,car haven't been out til the lasts part of the season this year and i discover this issue.
Re: Trans brake reverse . [Re: racerx] #2847566
11/17/20 01:11 PM
11/17/20 01:11 PM
Penna
70satelliteguy Offline
Penna
Maybe the drag backing up is not related to the valve body or transmission? Just an idea? I had a similar issue and it was the ring gear starting to crack!
Mike
Re: Trans brake reverse . [Re: racerx] #2847607
11/17/20 01:55 PM
11/17/20 01:55 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Can you push the car backwards with no drag when it's not running?
Re: Trans brake reverse . [Re: slantzilla] #2847763
11/17/20 06:30 PM
11/17/20 06:30 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Haven't tried that yet ,i no it goes forward easy i pushes it though the staging lanes myself. It's back on the trailer in the garage now.....
Re: Trans brake reverse . [Re: racerx] #2849802
11/22/20 12:20 AM
11/22/20 12:20 AM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Silly thought, you didn't recently wire the line loc to the trans bake to keep the car from rolling as the brake applies?
(don't ask me how I know)
Re: Trans brake reverse . [Re: ProStDodge] #2849818
11/22/20 05:00 AM
11/22/20 05:00 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Nope ...the car has been fine for years ,took it out for the first time this years and discovered this problem shruggy
