Transmission fluid for slick shifted 4 speed #2846733
11/15/20 08:04 PM
11/15/20 08:04 PM
Rescue CA.
joes68340s Offline OP
Rescue CA.
I have a Liberty modified slick shift 833 trans. Wondering what people have used or recommend for trans fluid.
Re: Transmission fluid for slick shifted 4 speed [Re: joes68340s] #2846738
11/15/20 08:24 PM
11/15/20 08:24 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
If is a true slick shifted tranny, I use Dexron ATF.in mine. Pro shifted, a GL4 gear oil.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Transmission fluid for slick shifted 4 speed [Re: 68LAR] #2846740
11/15/20 08:29 PM
11/15/20 08:29 PM
Rescue CA.
Rescue CA.
[i][/i]. I think it had something like Redline MTL. Not sure.
Re: Transmission fluid for slick shifted 4 speed [Re: joes68340s] #2846744
11/15/20 08:34 PM
11/15/20 08:34 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I use Redline shockproof lube in my transmissions without syncro rings twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: Transmission fluid for slick shifted 4 speed [Re: fourgearsavoy] #2846755
11/15/20 08:54 PM
11/15/20 08:54 PM
Rescue CA.
Rescue CA.
Shockproof light or shockproof heavy.[
Re: Transmission fluid for slick shifted 4 speed [Re: joes68340s] #2846760
11/15/20 08:59 PM
11/15/20 08:59 PM
Is it slick shifted or Pro shifted?
Not face plated, correct?
I used type F ATF in my old 4 speed drag race NHRA stocker with both types of gears in it up
I did take it out and inspect it after 40 runs or so due to the clutches we had back then, mid 1970s only lasting around 40 runs shruggy
I would remove and dress up the 4th and 3rd gears and its slider after 80 runs and replace them after 150 + runs and have them redone on the engagement lugs up
I quit drag racing 4 speeds after 2 1/2 yrs of doing that grin work
Re: Transmission fluid for slick shifted 4 speed [Re: Cab_Burge] #2846762
11/15/20 09:03 PM
11/15/20 09:03 PM
Rescue CA.
Rescue CA.
I bought the car with this 4 speed setup don’t know a lot about it as the guy that built it doesn’t remember. I didn’t plan to run a 4 speed but for now it’s fun. It’s supposed to be just slick shift. It works well.
Re: Transmission fluid for slick shifted 4 speed [Re: joes68340s] #2847110
11/16/20 04:05 PM
11/16/20 04:05 PM
Slick shifts don't last on the street worth a hoot, you can burr up the slider and gears by missing one shift and then they don't shift good after that until you take them apart and fix them whiney shruggy
Yours is probably Pro Shifted, which is much better at the track and on the street as long as you shift it quickly up wrench grin
Re: Transmission fluid for slick shifted 4 speed [Re: Cab_Burge] #2847116
11/16/20 04:20 PM
11/16/20 04:20 PM
Washington
madscientist Offline
Washington
I’ve been driving slick shifted on the street for nearly 20 years. Touched up the gears once.
FWIW, synthetic gear oil (and specifically GL-6 gear oils) are FAR better than engine oil or ATF.
Re: Transmission fluid for slick shifted 4 speed [Re: madscientist] #2847217
11/16/20 06:52 PM
11/16/20 06:52 PM
Rescue CA.
Rescue CA.
It’s a track only car. Just drained The trans no metal clean fluid. Just not sure what they ran.
Re: Transmission fluid for slick shifted 4 speed [Re: joes68340s] #2847229
11/16/20 07:17 PM
11/16/20 07:17 PM
Hopefully the drain plug has a magnet on it, if not glue one on it. twocents up
