highest mileage 5.7, stock untouched
#2844201
11/09/20 07:01 PM
11/09/20 07:01 PM
Posts: 2,919 Calgary, Alberta Canada
a12rag
Just curious how many miles (kilometers up here) that people are getting on stock 5.7 ?? My 06 Magnum RT AWD is at 223,000km (138,500miles) . . . and all seems totally fine, oil pressure 20lb @ idle and pops right up to 50lb over 1000rpm, no strange noises, ticks, etc., uses about 1/2 litre of oil between changes (every 5000km - 3000miles). I have never changed valve cover gaskets, cause never had the valve covers off or seen any leaks ! . . . always changed plugs every 50k km (30k miles), replaced thermostat, radiator and power steering pump and camshaft sensor. . . . had the car since new. . . .
Re: highest mileage 5.7, stock untouched
[Re: a12rag]
#2844465
11/10/20 11:52 AM
11/10/20 11:52 AM
Posts: 3,516 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I have a 2007 Magnum R/T that I have driven since new. It has 178,000 miles+ with no engine or transmission issues.
Most of the time Mobil 1 with 10,000 mile oil changes.
Lots of road miles until recently.
[Re: 340Cuda]
#2844697
11/10/20 10:40 PM
11/10/20 10:40 PM
Posts: 4,998 North Pole,New York
formula_s
North Pole,New York
Most of the time Mobile 1 with 10,000 mile oil changes.
Lots of road miles until recently. Mobile ???
[Re: a12rag]
#2844800
11/11/20 12:00 PM
11/11/20 12:00 PM
Posts: 1,213 Minn
SportF
Minn
2003 1500 Not really as much as some of you at 155,000. BUT, 120,000 was pulling my 24 foot enclosed trailer with a 63 Plymouth in it. As far as the whole truck goes, other that tires shocks and brakes, the ONLY things I've replaced was front and rear wheel bearings. Oh, and one rear tail lamp. That is it.
Edit whoops, almost forgot, a couple of idler pullies on the belt drive.
[Re: formula_s]
#2844802
11/11/20 12:01 PM
11/11/20 12:01 PM
340Cuda
Tulsa, Oklahoma
Lots of road miles until recently. Mobile ??? No Mobil
[Re: a12rag]
#2845323
11/12/20 01:39 PM
11/12/20 01:39 PM
Posts: 1,306 Laveen, Arizona
GTSDart340
Laveen, Arizona
Not the highest by any means, but my 06 Magnum is at 145k. It's got an exhaust leak under acceleration, but other than that it's great!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
[Re: a12rag]
#2846430
11/15/20 09:26 AM
11/15/20 09:26 AM
Posts: 4,255 Canada
WO23Coronet
Canada
I live in Manitoba, 05 Magnum RT, 270,000 kms on it. Gets driven every day, 365 days a year. Only thing I've replaced outside of normal maintenance is the crank sensor, a t-stat, oil pressure sensor, and A/C compressor. Runs pretty good but you can tell it's getting abit tired, will likely replace the timing chain this spring.
I think with our climate, you'd have to multiply your mileage by 1.5-2X to compare it to fair weather cars mechanically. 0 to -40 F is a real killer on vehicles
[Re: AeroMonte]
#2847941
11/18/20 01:58 AM
11/18/20 01:58 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
THis truck is at 354,000 miles. Original serpentine belt and tensioner, starter, alternator, water pump, power steering pump and A/C compressor. Plug changes every 40,000, trans service every 50,000. I did replace the EGR valve and thermostat. I replaced the A/C condenser fan twice. I'm on my second radiator.
[Re: Kern Dog]
#2848050
11/18/20 11:16 AM
11/18/20 11:16 AM
340Cuda
Tulsa, Oklahoma
THis truck is at 354,000 miles. Original serpentine belt and tensioner, starter, alternator, water pump, power steering pump and A/C compressor. Plug changes every 40,000, trans service every 50,000. I did replace the EGR valve and thermostat. I replaced the A/C condenser fan twice. I'm on my second radiator. What do you do when you have the transmission serviced? Flush and oil and filter change? Thanks!
[Re: 340Cuda]
#2848461
11/19/20 05:19 AM
11/19/20 05:19 AM
Kern Dog
Granite Bay CA
I do it myself. There are 2 filters inside the trans. Both get replaced along with what drains from the pan. I have had to replace the transmission control module twice. That requires removal of the valve body!
[Re: a12rag]
#2848538
11/19/20 10:35 AM
11/19/20 10:35 AM
Posts: 17,860 S.E. Michigan
ZIPPY
S.E. Michigan
When I sold my '03 Ram 2500 it had a little over 258,000 miles on it. As far as I know it had never been apart.
It had most of the usual issues (exhaust manifold leaks, the buyer told me he found oil pan rot) but it kept chugging along.
Rich H.
Esse Quam Videri
[Re: a12rag]
#2848942
11/20/20 09:36 AM
11/20/20 09:36 AM
Posts: 314 Northeast Indiana
73DAD
Northeast Indiana
Just curious how many miles (kilometers up here) that people are getting on stock 5.7 ?? My 06 Magnum RT AWD is at 223,000km (138,500miles) . . . and all seems totally fine, oil pressure 20lb @ idle and pops right up to 50lb over 1000rpm, no strange noises, ticks, etc., uses about 1/2 litre of oil between changes (every 5000km - 3000miles). I have never changed valve cover gaskets, cause never had the valve covers off or seen any leaks ! . . . always changed plugs every 50k km (30k miles), replaced thermostat, radiator and power steering pump and camshaft sensor. . . . had the car since new. . . . As a fellow owner of an '06 Magnum R/T AWD & a '70 road runner, I'll just say you have excellent taste in cars! 130,200miles on the wagon.
[Re: 73DAD]
#2849298
11/20/20 10:38 PM
11/20/20 10:38 PM
a12rag
Just curious how many miles (kilometers up here) that people are getting on stock 5.7 ?? My 06 Magnum RT AWD is at 223,000km (138,500miles) . . . and all seems totally fine, oil pressure 20lb @ idle and pops right up to 50lb over 1000rpm, no strange noises, ticks, etc., uses about 1/2 litre of oil between changes (every 5000km - 3000miles). I have never changed valve cover gaskets, cause never had the valve covers off or seen any leaks ! . . . always changed plugs every 50k km (30k miles), replaced thermostat, radiator and power steering pump and camshaft sensor. . . . had the car since new. . . . As a fellow owner of an '06 Magnum R/T AWD & a '70 road runner, I'll just say you have excellent taste in cars! 130,200miles on the wagon. Thanks . . . back at you !!!
[Re: a12rag]
#2855070
12/04/20 02:32 AM
12/04/20 02:32 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
9,800 miles last I checked on my '07 stock Hemi By the looks of your mileage the truck should last a couple more centuries. So glad I bought a Dodge.
Mo' Farts
Moderated by "tbagger".
[Re: Grizzly]
#2857134
12/08/20 03:40 PM
12/08/20 03:40 PM
Posts: 6,019 Morningside
AdventurerSport
waaaay out there in left field
Morningside
132,000+ on my 2011 Ram 1500 5.7L, stock, only changed the oil (Valvoline Full Synthetic) and plugs. Had the Variable Cam solenoid fail last year, replaced under warranty. Transmission filter fell off (dropped into pan), and started sucking air, couldn't move, so that had to be towed into the dealership and fixed (under warranty). Radio replaced once, under warranty, and I've replaced the brakes (twice), battery (once) and tires are the 4th set to be on this truck.
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red 06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II 06 Chrysler 300C AWD 5.7L Hemi 10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI 10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI 11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red 16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
