highest mileage 5.7, stock untouched #2844201
11/09/20 07:01 PM
11/09/20 07:01 PM
Calgary, Alberta Canada
a12rag Offline OP
a12rag  Offline OP
Just curious how many miles (kilometers up here) that people are getting on stock 5.7 ?? My 06 Magnum RT AWD is at 223,000km (138,500miles) . . . and all seems totally fine, oil pressure 20lb @ idle and pops right up to 50lb over 1000rpm, no strange noises, ticks, etc., uses about 1/2 litre of oil between changes (every 5000km - 3000miles). I have never changed valve cover gaskets, cause never had the valve covers off or seen any leaks ! . . . always changed plugs every 50k km (30k miles), replaced thermostat, radiator and power steering pump and camshaft sensor. . . . had the car since new. . . .
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2844294
11/09/20 10:43 PM
11/09/20 10:43 PM
Chicago, Illinois
Devil Offline
Devil  Offline
Chicago, Illinois
230,000 miles-ish on my 2009 Challenger R/T. And never done anything but standard maintenance
Re: highest mileage 5.7, stock untouched [Re: Devil] #2844346
11/10/20 01:15 AM
11/10/20 01:15 AM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
300,000 km on my 05 300C. Still has the original plugs as far as I know.
Kevin
Re: highest mileage 5.7, stock untouched [Re: Twostick] #2844446
11/10/20 11:03 AM
11/10/20 11:03 AM
a12rag Offline OP
a12rag  Offline OP
300k km on original plugs ??? . . . yikes, I would hate to be the one taking them out . . . might be stuck in the threads and pull threads out ?!?!? . . .
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2844465
11/10/20 11:52 AM
11/10/20 11:52 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have a 2007 Magnum R/T that I have driven since new. It has 178,000 miles+ with no engine or transmission issues.
Most of the time Mobil 1 with 10,000 mile oil changes.
Lots of road miles until recently.
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2844654
11/10/20 08:39 PM
11/10/20 08:39 PM
southwest Alabama
challenger73400 Offline
southwest Alabama
My sons 2011 ram 5.7 was replaced by the dealer at 395,000 due to lifter tick. The truck now has 568,000 miles on it
Re: highest mileage 5.7, stock untouched [Re: 340Cuda] #2844697
11/10/20 10:40 PM
11/10/20 10:40 PM
North Pole,New York
formula_s Offline
formula_s  Offline
North Pole,New York
Most of the time Mobile 1 with 10,000 mile oil changes.
Mobile ???
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2844800
11/11/20 12:00 PM
11/11/20 12:00 PM
Minn
SportF Offline
SportF  Offline
Minn
2003 1500 Not really as much as some of you at 155,000. BUT, 120,000 was pulling my 24 foot enclosed trailer with a 63 Plymouth in it. As far as the whole truck goes, other that tires shocks and brakes, the ONLY things I've replaced was front and rear wheel bearings. Oh, and one rear tail lamp. That is it.
Edit whoops, almost forgot, a couple of idler pullies on the belt drive.
Re: highest mileage 5.7, stock untouched [Re: formula_s] #2844802
11/11/20 12:01 PM
11/11/20 12:01 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Mobile ???
No Mobil
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2845323
11/12/20 01:39 PM
11/12/20 01:39 PM
Laveen, Arizona
GTSDart340 Offline
GTSDart340  Offline
Laveen, Arizona
Not the highest by any means, but my 06 Magnum is at 145k. It's got an exhaust leak under acceleration, but other than that it's great!
1949 International KB-2 "Mater" - 302/T5
1968 Dodge Dart GTS "The Drat" - 340/727
2006 Dodge Magnum R/T - Hemi
2016 Dodge Durango Limited - 3.6
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2846430
11/15/20 09:26 AM
11/15/20 09:26 AM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
I live in Manitoba, 05 Magnum RT, 270,000 kms on it. Gets driven every day, 365 days a year. Only thing I've replaced outside of normal maintenance is the crank sensor, a t-stat, oil pressure sensor, and A/C compressor. Runs pretty good but you can tell it's getting abit tired, will likely replace the timing chain this spring.
I think with our climate, you'd have to multiply your mileage by 1.5-2X to compare it to fair weather cars mechanically. 0 to -40 F is a real killer on vehicles
Re: highest mileage 5.7, stock untouched [Re: WO23Coronet] #2847916
11/17/20 11:55 PM
11/17/20 11:55 PM
S.E. Missouri
AeroMonte Offline
AeroMonte  Offline
S.E. Missouri
2012 Ram 1500 4x4 has 224,500 miles on it and is driven every day. I still pull a car trailer with it. It has had a lifter tick for 120,000 miles now. No other issues beyond that. General maintenance only, by far the best vehicle I have ever owned. I have had it since new, almost 8 years now.
Re: highest mileage 5.7, stock untouched [Re: AeroMonte] #2847941
11/18/20 01:58 AM
11/18/20 01:58 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
THis truck is at 354,000 miles.
Original serpentine belt and tensioner, starter, alternator, water pump, power steering pump and A/C compressor.
Plug changes every 40,000, trans service every 50,000.
I did replace the EGR valve and thermostat. I replaced the A/C condenser fan twice. I'm on my second radiator.
Re: highest mileage 5.7, stock untouched [Re: Kern Dog] #2848050
11/18/20 11:16 AM
11/18/20 11:16 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
What do you do when you have the transmission serviced? Flush and oil and filter change?
Thanks!
Re: highest mileage 5.7, stock untouched [Re: 340Cuda] #2848461
11/19/20 05:19 AM
11/19/20 05:19 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I do it myself. There are 2 filters inside the trans. Both get replaced along with what drains from the pan.
I have had to replace the transmission control module twice. That requires removal of the valve body!
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2848538
11/19/20 10:35 AM
11/19/20 10:35 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
When I sold my '03 Ram 2500 it had a little over 258,000 miles on it. As far as I know it had never been apart.
It had most of the usual issues (exhaust manifold leaks, the buyer told me he found oil pan rot) but it kept chugging along.
Rich H.
Esse Quam Videri
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2848942
11/20/20 09:36 AM
11/20/20 09:36 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
As a fellow owner of an '06 Magnum R/T AWD & a '70 road runner, I'll just say you have excellent taste in cars! 130,200miles on the wagon.
Re: highest mileage 5.7, stock untouched [Re: 73DAD] #2849298
11/20/20 10:38 PM
11/20/20 10:38 PM
a12rag Offline OP
a12rag  Offline OP
Thanks . . . back at you !!!
Re: highest mileage 5.7, stock untouched [Re: a12rag] #2855070
12/04/20 02:32 AM
12/04/20 02:32 AM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
9,800 miles last I checked on my '07 stock Hemi
By the looks of your mileage the truck should last a couple more centuries.
So glad I bought a Dodge. up
Mo' Farts
Moderated by "tbagger".
Re: highest mileage 5.7, stock untouched [Re: Grizzly] #2857134
12/08/20 03:40 PM
12/08/20 03:40 PM
Morningside
AdventurerSport Offline
waaaay out there in left field
Morningside
132,000+ on my 2011 Ram 1500 5.7L, stock, only changed the oil (Valvoline Full Synthetic) and plugs. Had the Variable Cam solenoid fail last year, replaced under warranty. Transmission filter fell off (dropped into pan), and started sucking air, couldn't move, so that had to be towed into the dealership and fixed (under warranty). Radio replaced once, under warranty, and I've replaced the brakes (twice), battery (once) and tires are the 4th set to be on this truck.
JS
76 Dodge Adventurer Sport Power Wagon W100 318, 727, NP203 Fulltime 4x4 Russet Red
06 Jeep Commander Ltd 4x4, 5.7L Hemi, QuadraDrive II
06 Chrysler 300C AWD 5.7L Hemi
10 Mopar 10 Challenger R/T, #483/500, 5.7L HEMI
10 Jeep Grand Cherokee Ltd 4x4 5.7L HEMI
11 Dodge Ram 1500 LoneStar Quad Cab, 5.7L HEMI, Fulltime 4x4, Deep Cherry Red
16 Jeep Cherokee Limited 3.2L Pentastar V6, 9 Speed Torqueflite, 4x4, Black
