slicks tubes Q #2844225
11/09/20 08:11 PM
11/09/20 08:11 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
I am going down width wise in size by about 3 " (mt et drag bias) from what I have now . Same wheels, same dia. tire .
The new tires call for a different size tube part # than what I have.
If I use the tubes I have am I committing a sin I will regret?
Re: slicks tubes Q [Re: Wirenut] #2844237
11/09/20 08:34 PM
11/09/20 08:34 PM
Do they call for a smaller size or larger size tube?
Re: slicks tubes Q [Re: Cab_Burge] #2844376
11/10/20 06:24 AM
11/10/20 06:24 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
[i][/i]
New tire is calling for smaller
Re: slicks tubes Q [Re: Wirenut] #2844403
11/10/20 09:09 AM
11/10/20 09:09 AM
an8sec70cuda Offline
Always been told too big of a tube will fold up and rub a hole in itself.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: slicks tubes Q [Re: an8sec70cuda] #2844681
11/10/20 09:59 PM
11/10/20 09:59 PM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Hmmm
Re: slicks tubes Q [Re: Wirenut] #2844692
11/10/20 10:29 PM
11/10/20 10:29 PM
I would put the old tube in one of the new size tires and inflate it enough to see if it will fold up or not scope twocents
What size do you use now and what size do they recommend to use on the smaller tires.
I've seen a lot of regular old tubes in street tires(back in the 1960 and 1970s when I owrked in gas service stations that use to sell a lot of tires to their customers) that had folds in them due to the tech not inflating those tubes several times without the valve stems in them and letting them deflate several times 2 or more times up to insure the tubes did not have folds in them before inflating them to the proper pressures for the tires wrench scope
I haven't used tubes in a lot of years now, all my slicks get run without tubes in them even if M/T recommends using them twocents
Re: slicks tubes Q [Re: Cab_Burge] #2844744
11/11/20 06:28 AM
11/11/20 06:28 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Thanks Cab
I don’t know dimensions of the tube . The end tire is same diam just 3” narrower .
How would I know if it’s folding up?
Re: slicks tubes Q [Re: Wirenut] #2844755
11/11/20 08:11 AM
11/11/20 08:11 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
I would follow the manufacturer instructions. Tubes aren't that expensive and not worth the hassle of remounting slicks.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: slicks tubes Q [Re: A39Coronet] #2844776
11/11/20 10:13 AM
11/11/20 10:13 AM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
If you ever see a down track tube failure, you'll think long, and hard about tubes from then on.
Re: slicks tubes Q [Re: dthemi] #2844787
11/11/20 11:01 AM
11/11/20 11:01 AM
Washington
madscientist Offline
Washington
Yep. I stopped using tubes in 1984 when Marv at M&H told to take them out.
Re: slicks tubes Q [Re: Wirenut] #2844914
11/11/20 02:56 PM
11/11/20 02:56 PM
Look at the sides of the tube in the tire inflated a little, if their smooth you good scope twocents
Make sure and inflate both tubes several times, 2 or more times, in the tires on the rims to stretch them out and let them deflate completely before using them up
These are race drag race tubes correct? If not don't use any tubes other than drag race tubes twocents
Re: slicks tubes Q [Re: Cab_Burge] #2845336
11/12/20 01:50 PM
11/12/20 01:50 PM
moparx Offline
moparx  Offline
don't forget a liberal sprinkling of baby powder inside the tire.
helps keep the tube from sticking to the inside, causing wrinkles. up
beer
