New Tremec TKX 5 speed #2842719
11/06/20 09:17 PM
11/06/20 09:17 PM
Minnesota
RROD Offline OP
RROD  Offline OP
Minnesota
Tremec just announced a new version of the TKO 600. The new tranny is the Tremec TKX. It’s claim to fame is being more compact, shift limit of 7500, torque rating of 600ft/lbs continuous. No testing on E body yet but may not require cutting on tunnel. B & A body will require cutting for center shifter location. They had a video/call presentation today. You can view the presentation on Facebook.
https://shiftsst.com/tremec-tkx-5-speed?utm_source=Moparts
Re: New Tremec TKX 5 speed [Re: RROD] #2842732
11/06/20 09:39 PM
11/06/20 09:39 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
oh looks like it could be pretty nice. wonder how much it will cost and if it would really fit in a mopar tunnel with much cutting up the torsion bar crossmember..
Re: New Tremec TKX 5 speed [Re: RROD] #2842760
11/06/20 10:43 PM
11/06/20 10:43 PM
Norwich CT USA
moparts Offline
moparts  Offline
Norwich CT USA
Quote
The New TREMEC TKX 5-Speed Is the Compact Transmission You’ve Been Waiting For!
Rockford, Tenn. Friday, Nov. 6, 2020
TREMEC® 5 and 6-speeds dominate the aftermarket as the premiere choice for strong, reliable and versatile transmissions. The Silver Sport Transmissions (SST) PerfectFit™ kit helped take the 5 and 6-speeds customization options to the next level, multiplying the two to three available shifter positions to well over 25 shifter positions and providing all the needed conversion components, cutting templates, sheet metal and instructions to help convert classic cars, trucks, 4WDs, and select imports into optimized, modern drivetrains. TREMEC’s latest 5-speed, the TKX, is a great option for classic car enthusiasts who need a compact, high-power capacity transmission.
The TKX’s rounded, compact case will eliminate cutting in most applications and minimize it in others. The bolt-in dimensions of the TKX are very similar to the TKO and 3550; the new TKX retains the same length, face to crossmember mount, and bellhousing mount dimensions. SST’s STX Shifters® and case modifications put the shifter exactly where it should be.
The multi-cone synchronizer design comes standard with carbon hybrid blocker rings and helps the TKX achieve an 7,500 rpm shift capacity. The TKX is strong with a 600 lb•ft torque rating in both gear sets.
The new TKX gearing options:
3.27, 1.98, 1.34, 1.00, 0.72
2.87, 1.89, 1.28, 1.00, 0.81 or 0.68
You can call Silver Sport Transmissions at 888-609-0092 for more information on the TKX or to place your order. Complete kits are available.
About Silver Sport Transmissions
Silver Sport Transmissions leads the aftermarket development of TREMEC transmission conversion kits for classic American cars, trucks, 4WD, and select imports. SST’s PerfectFit™ brand of conversion kits are found in more classic cars and trucks than any other brand. SST seeks to raise industry standards by emphasizing integrity, customer support, continuous development, and excellent products above all else.
Re: New Tremec TKX 5 speed [Re: moparts] #2842778
11/06/20 11:32 PM
11/06/20 11:32 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Bottom photo appears to be for Mopar shifter location.
This could be really good if the price is reasonable.
Re: New Tremec TKX 5 speed [Re: topside] #2842861
11/07/20 07:39 AM
11/07/20 07:39 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
TREMEC has set MAP pricing at $2,795.00.
Re: New Tremec TKX 5 speed [Re: RROD] #2842984
11/07/20 01:01 PM
11/07/20 01:01 PM
AndyF Offline
AndyF  Offline
I have a buddy with an early Impala and he is considering a switch from the factory T-10 to a five speed. It is a big project in one of those cars. Not sure if the TKX will help him with space or not, we'll have to take a look.
Re: New Tremec TKX 5 speed [Re: AndyF] #2843141
11/07/20 06:07 PM
11/07/20 06:07 PM
Spring Hill Fl
65Fury440 Offline
65Fury440  Offline
Spring Hill Fl
This is great news!
Re: New Tremec TKX 5 speed [Re: 65Fury440] #2843349
11/08/20 03:45 AM
11/08/20 03:45 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
How is this any different from the other Tremec 5 speed they have offered for years? Those are supposed to be modified to fit the B chassis with no cutting except for the shifter hole.
Re: New Tremec TKX 5 speed [Re: Kern Dog] #2843404
11/08/20 11:06 AM
11/08/20 11:06 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
The TKO is a very tall case, yes it fits (barely) in the 2nd and 3rd gen B bodies (I've done both), the TKO fits a bit better in the 3rd gen B bodies and 70-74 E bodies, however if you don't remove some of the excess casting ribs on the tail shaft and add a spacer to the tail shaft transmission mount the TKO install as delivered from most kit mfgs will have a profound downward driveline incline, with may cause problems with headers to suspension contact issues/carb to hood ram air systems, radiator/shroud/fan contact, etc, etc depending on your application/mods/etc....hopefully the new TKX eliminates fitment issues and solves driveline issues for the avg "bolt in" installer? I could live with a .68 OD offered on the TKX, although I like the .64 OD the TKO offers....the TKO offerings over the years had growing pains from the various kit mfgs, hopefully they have learned and applied that to the TKX offerings as I'd be interested in installing one of these
Mike
Re: New Tremec TKX 5 speed [Re: DAYCLONA] #2843501
11/08/20 02:16 PM
11/08/20 02:16 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
I have to wonder how relevant something like this is given all the problems and complaints over the years?
By now, 6 speeds from Challengers are affordable and better?
Mo' Farts
Moderated by "tbagger".
Re: New Tremec TKX 5 speed [Re: RROD] #2901174
03/20/21 08:05 PM
03/20/21 08:05 PM
Mentor, OH
doggs330 Offline
doggs330  Offline
Mentor, OH
New article showing 5 speed comparison pictures.
TKO vs TKX
Re: New Tremec TKX 5 speed [Re: doggs330] #2901228
03/21/21 12:35 AM
03/21/21 12:35 AM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I finished a TKO installation in my '70 Charger last month. I could have bought the TKX but the benefits it provided did not appeal to me. I got a great deal on my kit.
I went close ratio with the .64 Overdrive. THIS changed the feel of the car dramatically. Cruising at freeway speeds, the car is quieter, smoother, no vibrations....it is so much easier to drive fast. The 500 mile break in sucks though.
I had to cut the trans tunnel to make room for the top of the trans but SST provides a template and a patch panel. This was the only 5 speed swap that I have ever done and it went well. I wrote a multi page thread about the install at FBBO.
Re: New Tremec TKX 5 speed [Re: Kern Dog] #2901333
03/21/21 01:15 PM
03/21/21 01:15 PM
Pikes Peak Country
TC@HP2 Online content
TC@HP2  Online Content
Pikes Peak Country
Because years in the market with feedback from garages, installers and buyers has led to changes and improvements perhaps. Rounding the case, changing mount angles, altered shifter position, improving shift capability...sounds like they have been listening to complaints of previous models and rather than change an existing model, released a new version.
