Page 2 of 3 1 2 3
Re: 511 tf270 cam, header, Intake, gear selection? [Re: Dragula] #2842622
11/06/20 04:29 PM
11/06/20 04:29 PM
junction city oregon
V
viperblue72 Offline OP
V
Thank you guys for the input. It looks like I’m on the right track.
Andy how much porting would give me bang for buck. I plan to call modern
Cylinder head for an intake and hoping they have a cnc program.
For headers I already have the 2 to 2 1/8 coming.
I did find a Howard’s grind that’s 263/270 .675/.650 on 108.
Next question. Do I have to worry about lifter coming out of bores too far and uncovering the oil band?
Re: 511 tf270 cam, header, Intake, gear selection? [Re: Dragula] #2842623
11/06/20 04:30 PM
11/06/20 04:30 PM
V
V
Originally Posted by Dragula
Originally Posted by viperblue72
Drqgula it has the TA 4-speed with 2.47 1st gear. I’m thinking a4.10 with 30” tire.
I run a 31.5" tire with 4.10 gear, and that's a bit much on the street....I would go 3.91ish....
Dragula I was thinking possibly the same thing for gearing. Thank you.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842624
11/06/20 04:39 PM
11/06/20 04:39 PM
The rocker arm ratio affects the motor from idle to peak RPM, do the math on how much increase in the net valve lift and then decide if you want more lift on the lobes or do it with the increase rocker arm ratio work 1.5 X.420=.630 gross lift,1.6X=.672. I check the net lift at the retainers and it had closer to .700 net lift than .670 shruggy That cam pulled really hard all the way from a idle to whatever RPM I wanted to shift it at including up to 7800 RPM shock
That motor exceeded my wildest expectations from day one with a set of ported big valve 906 heads all the way up to buying and using the CNC ported Eddy RPM heads and then with the dyno testing on both the Indy 440-1 and the Indy SR M.W. heads. The SR heads flowed 340 CFM at .700 lift and the 440-1 flowed 370 CFM at .700 lift, the 440 -1 heads made 50 HP more on my pump gas motor at a little higher 7500 RPM than the SR heads did at 7300 RPM shruggy More air and fuel in makes more power up
I didn't work on the Indy 400-3 intake for either set of the Indy heads, it made good power and torque with all the heads I had on that motor with the same rocker arms with the Eddy RPM and SR heads, same brand and ratio on the 440-1 heads up
On the head swap tests I used the same carb with the same jets and ignition timing, head change only, both Indy heads had the same 76.0 CC on the combustion chambers, same head gaskets also up
I did test both sets of the Indy heads on my higher compression ratio 526 C.I., 440 mule motor, the 440-1 made 845 HP at 7500 RPM on race gas and the SR made 775 HP at 7500 RPM on pump swill shruggy
Good luck on your build, it should make a lot of power twocents
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842662
11/06/20 06:49 PM
11/06/20 06:49 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
As far as the lifter band uncovering, yes they can unless you bush the bores but I run the Isky solid body's so zero issues there......
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842723
11/06/20 09:22 PM
11/06/20 09:22 PM
V
V
Okay guys I got the cam today. Did some horse trading with a friend.
It’s
265/269
.660/.653
108lsa
Things are moving right along. 😀
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842748
11/06/20 10:15 PM
11/06/20 10:15 PM
Southern Alberta
Uberpube Offline
Uberpube  Offline
Southern Alberta
Are you planning on doing any chassis dyno pulls when you're done? Would like to compare when I get done.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842796
11/07/20 12:22 AM
11/07/20 12:22 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle.
Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: INTMD8] #2842811
11/07/20 12:49 AM
11/07/20 12:49 AM
V
V
I’ll be at .412 lobe lift 🤞
Re: 511 tf270 cam, header, Intake, gear selection? [Re: Uberpube] #2842813
11/07/20 12:50 AM
11/07/20 12:50 AM
V
V
I do plan to put it on either an engine dyno or chassis dyno 👍
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842816
11/07/20 01:12 AM
11/07/20 01:12 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Still, need to measure everything due to variance in lifter design and base circle.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2842898
11/07/20 09:40 AM
11/07/20 09:40 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: mopar dave] #2842924
11/07/20 10:52 AM
11/07/20 10:52 AM
Arizona
PolyDart Offline
PolyDart  Offline
Arizona
I just finished a 512 low deck stroker with 10.5:1, TF270s, deep ported Indy single plane, 2" headers, 1050 dominator, and a solid roller cam. It has yet to be on a dyno, but I can tell you that it's a beast in my 3200lb Dart. I'm running Caltracs and MT 295/65-15s and the car will light them up at will. Looking into Davis traction control so I can reliably put the power to the pavement.
Here is the cam card:
Re: 511 tf270 cam, header, Intake, gear selection? [Re: INTMD8] #2842968
11/07/20 12:48 PM
11/07/20 12:48 PM
V
V
I do realize that I need to measure. I should of been clear. Thank you for the advice.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: PolyDart] #2842971
11/07/20 12:49 PM
11/07/20 12:49 PM
V
V
Very nice build. Is the times in your signature with this motor?
Re: 511 tf270 cam, header, Intake, gear selection? [Re: PolyDart] #2842975
11/07/20 12:50 PM
11/07/20 12:50 PM
AndyF Offline
AndyF  Offline
Yeah that is a healthy cam for the 270 heads, should make plenty of power up top that is for sure. Looks like you polished the motor plate? Did that take a lot of work?
Re: 511 tf270 cam, header, Intake, gear selection? [Re: mopar dave] #2842977
11/07/20 12:51 PM
11/07/20 12:51 PM
AndyF Offline
AndyF  Offline
3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: AndyF] #2843090
11/07/20 03:59 PM
11/07/20 03:59 PM
V
V
Andy I’m going to be changing to a 295/65 or a 29” tire. So 3.91 may be my best bet. 👍
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2843091
11/07/20 04:02 PM
11/07/20 04:02 PM
V
V
Where do I order a Indy 400-2 intake from? Can the valves use unshrouding on these heads? I have a friend that wants to do intake porting and optimizing.
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2843095
11/07/20 04:13 PM
11/07/20 04:13 PM
AndyF Offline
AndyF  Offline
You have a 8.75 rearend behind 700 hp?
Re: 511 tf270 cam, header, Intake, gear selection? [Re: viperblue72] #2843096
11/07/20 04:14 PM
11/07/20 04:14 PM
AndyF Offline
AndyF  Offline
Don't touch the heads. The Indy intake can be purchased from most anyone.
Page 2 of 3 1 2 3
