Re: 511 tf270 cam, header, Intake, gear selection?
[Re: Dragula]
#2842623
11/06/20 04:30 PM
11/06/20 04:30 PM
Posts: 2,141 junction city oregon
viperblue72
Drqgula it has the TA 4-speed with 2.47 1st gear. I’m thinking a4.10 with 30” tire. I run a 31.5" tire with 4.10 gear, and that's a bit much on the street....I would go 3.91ish.... Dragula I was thinking possibly the same thing for gearing. Thank you.
[Re: viperblue72]
#2842624
11/06/20 04:39 PM
11/06/20 04:39 PM
Posts: 43,275 Bend,OR USA
Cab_Burge
The rocker arm ratio affects the motor from idle to peak RPM, do the math on how much increase in the net valve lift and then decide if you want more lift on the lobes or do it with the increase rocker arm ratio 1.5 X.420=.630 gross lift,1.6X=.672. I check the net lift at the retainers and it had closer to .700 net lift than .670 That cam pulled really hard all the way from a idle to whatever RPM I wanted to shift it at including up to 7800 RPM That motor exceeded my wildest expectations from day one with a set of ported big valve 906 heads all the way up to buying and using the CNC ported Eddy RPM heads and then with the dyno testing on both the Indy 440-1 and the Indy SR M.W. heads. The SR heads flowed 340 CFM at .700 lift and the 440-1 flowed 370 CFM at .700 lift, the 440 -1 heads made 50 HP more on my pump gas motor at a little higher 7500 RPM than the SR heads did at 7300 RPM More air and fuel in makes more power I didn't work on the Indy 400-3 intake for either set of the Indy heads, it made good power and torque with all the heads I had on that motor with the same rocker arms with the Eddy RPM and SR heads, same brand and ratio on the 440-1 heads On the head swap tests I used the same carb with the same jets and ignition timing, head change only, both Indy heads had the same 76.0 CC on the combustion chambers, same head gaskets also I did test both sets of the Indy heads on my higher compression ratio 526 C.I., 440 mule motor, the 440-1 made 845 HP at 7500 RPM on race gas and the SR made 775 HP at 7500 RPM on pump swill Good luck on your build, it should make a lot of power
[Re: viperblue72]
#2842662
11/06/20 06:49 PM
11/06/20 06:49 PM
Thumperdart
State of confusion
As far as the lifter band uncovering, yes they can unless you bush the bores but I run the Isky solid body's so zero issues there......
[Re: viperblue72]
#2842796
11/07/20 12:22 AM
11/07/20 12:22 AM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
Next question. Do I have to worry about lifter coming out of bores too far and uncovering the oil band?
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle. Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery.
[Re: INTMD8]
#2842811
11/07/20 12:49 AM
11/07/20 12:49 AM
viperblue72
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle. Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery. I’ll be at .412 lobe lift 🤞
[Re: Uberpube]
#2842813
11/07/20 12:50 AM
11/07/20 12:50 AM
viperblue72
Are you planning on doing any chassis dyno pulls when you're done? Would like to compare when I get done. I do plan to put it on either an engine dyno or chassis dyno 👍
[Re: viperblue72]
#2842816
11/07/20 01:12 AM
11/07/20 01:12 AM
INTMD8
Lake Villa Il
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle. Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery. I’ll be at .412 lobe lift 🤞 Still, need to measure everything due to variance in lifter design and base circle.
[Re: mopar dave]
#2842924
11/07/20 10:52 AM
11/07/20 10:52 AM
Posts: 876 Arizona
PolyDart
Arizona
I just finished a 512 low deck stroker with 10.5:1, TF270s, deep ported Indy single plane, 2" headers, 1050 dominator, and a solid roller cam. It has yet to be on a dyno, but I can tell you that it's a beast in my 3200lb Dart. I'm running Caltracs and MT 295/65-15s and the car will light them up at will. Looking into Davis traction control so I can reliably put the power to the pavement.
Here is the cam card:
[Re: INTMD8]
#2842968
11/07/20 12:48 PM
11/07/20 12:48 PM
viperblue72
Yes, I measured this on mine. Many different lifter designs out there so that matters as well as the cam base circle. Based on the hyd flat tappet cam I had, discussed how much room I had to decrease the base circle with the cam grinder and how much room I had from there for lobe lift without uncovering the oil gallery. With an MP hemi block, unbushed, .430 intake lobe lift I'm only about .020 away on each end from uncovering the oil gallery. I’ll be at .412 lobe lift 🤞 Still, need to measure everything due to variance in lifter design and base circle. I do realize that I need to measure. I should of been clear. Thank you for the advice.
[Re: PolyDart]
#2842971
11/07/20 12:49 PM
11/07/20 12:49 PM
viperblue72
Very nice build. Is the times in your signature with this motor?
[Re: mopar dave]
#2842977
11/07/20 12:51 PM
11/07/20 12:51 PM
Posts: 31,061 Oregon
AndyF
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it.
[Re: AndyF]
#2843090
11/07/20 03:59 PM
11/07/20 03:59 PM
viperblue72
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it. Andy I’m going to be changing to a 295/65 or a 29” tire. So 3.91 may be my best bet. 👍
[Re: viperblue72]
#2843095
11/07/20 04:13 PM
11/07/20 04:13 PM
AndyF
My book shows 3.73 gear as being best starting line ratio with 4.25 stroke, 28' tire and 3400# for my car. 3.73 probably would be a good ratio with a 28 inch tire. I decided that 3.90 was the best ratio for my Duster but I have a 29.5 inch tire in it. Andy I’m going to be changing to a 295/65 or a 29” tire. So 3.91 may be my best bet. 👍 You have a 8.75 rearend behind 700 hp?
[Re: viperblue72]
#2843096
11/07/20 04:14 PM
11/07/20 04:14 PM
AndyF
Where do I order a Indy 400-2 intake from? Can the valves use unshrouding on these heads? I have a friend that wants to do intake porting and optimizing. Don't touch the heads. The Indy intake can be purchased from most anyone.
