Hemi 2x4 intake. Stage V vs Edelbrock #2842343
11/05/20 10:29 PM
11/05/20 10:29 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Does anyone have dyno results comparing the stage V intake to the Edelbrock? Stage V looks like it would be better in terms of more symmetrical runner shape/length. I know the carb spacing is wider. Thanks
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842351
11/05/20 10:39 PM
11/05/20 10:39 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Most dyno results will start above 3000rpm and really not give you the info where a street car lives......We have tested lots of manifolds and carbs on the Hemi over the years....
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: Dragula] #2842355
11/05/20 10:54 PM
11/05/20 10:54 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
I prefer short gearing/high rpm to low end torque. Looking to maximize horsepower 5000-7500rpm
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842361
11/05/20 11:02 PM
11/05/20 11:02 PM
Dragula Offline
Dragula  Offline
Then you will like this Hemi.....best sounding one I ever drove..
https://www.youtube.com/watch?v=mrm62S2Fmow
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: Dragula] #2842362
11/05/20 11:06 PM
11/05/20 11:06 PM
Dragula Offline
Dragula  Offline
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842403
11/06/20 02:33 AM
11/06/20 02:33 AM
Street and strip or strip only?
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: Cab_Burge] #2842455
11/06/20 09:28 AM
11/06/20 09:28 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Dragula, nice! That is bad ass
Cab, mostly street but it will see the strip. Main concern is which makes more high rpm power. Looks like Stage V would have an edge but they are both rather similar.
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842465
11/06/20 09:54 AM
11/06/20 09:54 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How does the ‘Rat Roster’ stack up to those two?
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: cudaman1969] #2842481
11/06/20 10:22 AM
11/06/20 10:22 AM
Dragula Offline
Dragula  Offline
Rat roaster is horrible....Had one of those years ago. Had it all modified with a 1" plenum space, ports all reworked and shortened, and then added 1" carb spacers. That's how it ran best. I have pics of that combo.
The Tunnel ram or the new single planes make the most power, but hood clearance is generally the issue. My buddy with the 572 Hemi has tested all the dual quad intakes & a six pack one, and the Stage 5 needs the center divider removed and a pair of carb spacers to optimize it. From there, the carb testing began. He has tested a ton of carbs on the dual quads. The fastest was with the new Eddy thunder series 800cfm carbs with a Modman intake if I remember right. Ran 9.80 with that combo.
Me, I like the tunnel rams and big single plane intakes and that's what I run now. Both the Indy & Ray Barton provide excellent distribution....Tunnel ram requires port matching and a plenum spacer.
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: Dragula] #2842511
11/06/20 11:49 AM
11/06/20 11:49 AM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
Both intakes are good - its just what's the application? If its a mild street engine around 500 CI - I would go with the edelbrock as it will probably be a little better down low. The intake was designed for the eddy Vic Jr. heads in mind and having the same carb spacing as stock so you can use a stock air cleaner set-up. The stage 5 is more like a short tunnel ram . I have the Stage 5 on my 572 - with two 800 AFB's and made 870 HP on the dyno - with bigger Holley carbs I am sure it would make more HP but mounting the carbs sideway - the linkage becomes a project - It's been done so its not out of the possibility . One thing I have found with the stage 5 is adding a 1" supper sucker carb spacer made a world of difference in idle and how even the plugs are now - I have also switched to the new AVS2 carbs which actually rate at 825 cfm - the throttle response is much cleaner with the AVS2
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: DoubleD] #2842520
11/06/20 12:13 PM
11/06/20 12:13 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
The application is 437ci, 12.4-1, solid roller, EFI, E85, tko600, 4.10's in a 69 Charger.
Again, no concern about down low, wanted to know which made more high rpm power so thought maybe someone had done a back to back test as they have both been around for a while.
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842537
11/06/20 01:29 PM
11/06/20 01:29 PM
Dragula Offline
Dragula  Offline
The Eddy dual quad was designed around a typical 528 Hemi engine and might lose some velocity with carbs on a smaller engine being a single plane, but your running EFI and that will keep any kind of velocity issues away with proper tuning as the EFI will only add fuel to the air it pulls in.... As mentioned above, we ran them on a 572 and they are very similar when you use a carb spacers....On a smaller cubic inch Hemi, I would probably lean toward the Stage 5 for dual quad and a half milled down divider running carbs, but since your efi, I like a straight path to the intake valve....I would go with the Eddy.
You could also call FHO and get his opinion as he has built countless numbers of these. Also note on the Eddy intake the built in height difference between the front and the rear carb....I am not a fan of that, but I do not use standard engine mounts and my Hemi sits level.
For a single quad, the RBRE was really surprising on how even the distribution was. We ran that on a 484 and it was awesome, and beat any dual quad I ever ran on a smaller Hemi.. And for all out, the tunnel ram will still get the win, even on the smaller engine if the carbs are sized right. The bug catcher tunnel ram setup was on my 484 Hemi....it was a beast. That regularly saw 7200rpm...You couldn't shift it fast enough, so I put an air shift in the car.
On my 605, I went with the biggest 4-barrel 4500 intake I could get, and started out with a 1250 carb and have switched to Sniper Stealth 4500....
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842630
11/06/20 04:53 PM
11/06/20 04:53 PM
EFI motors need a single plane intake to make the best use of the single O2 sensor and fuel management by the ECU based on the O2 readings twocents scope
Another thing to consider is which brand O2 you use, E85 should probably work the best with the NTK sensors instead of the standard gasoline sensors most EFI kits come with scope twocents
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: Cab_Burge] #2842632
11/06/20 05:11 PM
11/06/20 05:11 PM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
I agree, which is why of the two manifolds I'm considering both are single plane up
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2842665
11/06/20 06:59 PM
11/06/20 06:59 PM
New York
polyspheric Offline
polyspheric  Offline
New York
When the dual plane center divider is removed, what's left is a crude single plane.
Boffin Emeritus
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: polyspheric] #2842793
11/07/20 12:16 AM
11/07/20 12:16 AM
Lake Villa Il
INTMD8 Offline OP
INTMD8  Offline OP
Lake Villa Il
Sounds like something I don't want.
Re: Hemi 2x4 intake. Stage V vs Edelbrock [Re: INTMD8] #2843864
11/09/20 09:50 AM
11/09/20 09:50 AM
an8sec70cuda Offline
From what I've seen, I'd go w/ the Stage V manifold.
CHIP
'06 GMC 2500HD LBZ Duramax
