Need Help ID'ing a 727 Transmission #2842388
11/06/20 12:19 AM
11/06/20 12:19 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I'm working on my wife's 75 Duster 360 (real 360 car)..
The transmission (727) is stumping me because I'm not getting it to kick down like I expect it to. Lots of forums searches and reading tells me that unless it has a Part Throttle Kickdown, I can expect it not to downshift unless wide open.
I have no idea of the origins of the transmission, only that it's clean on the inside (I just dropped and changed the pan & gasket and topped it off while idling hot & in neutral).
Attached is a picture of the numbers on the drivers side housing. J2801542 3548481
I went over this list here : ( http://www.mymopar.com/downloads/transguide.pdf ) and it skips from 3516868 to 3633552
I have no idea of the transmission is original to the car and that's not even a real issue for me.
The Federal Government has not yet learned that you cannot legislate morality 1970 Coronet R/T FF4/FF8/V85/V1G 440/Auto/3.23 1970 Coronet R/T FK5/FK5/V8W/V1W 440/Auto/3.55 1970 Super Bee TX9/TX9/V8W/N96 383/Auto/3.91 1975 Duster 360 VS29L5 Daily Driver
Re: Need Help ID'ing a 727 Transmission [Re: shanker] #2842392
11/06/20 12:25 AM
11/06/20 12:25 AM
Corpus Christi, TX
shanker Offline OP
shanker  Offline OP
Corpus Christi, TX
I think I was looking at the wrong numbers.
2801542 would be a 1967 Dodge/Plymouth 318 Exc (Excluding???) Police/Taxi
Re: Need Help ID'ing a 727 Transmission [Re: shanker] #2842715
11/06/20 08:15 PM
11/06/20 08:15 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I believe the part throttle KD did not arrive until sometime in the mid ? 70's . That would concur with what you've been being told and the above Information. The good news is the earlier ones can be updated. I am not sure what all that requires but it can be done in the car. Hopefully someone with a bit more knowledge on the subject will chime in beer
Re: Need Help ID'ing a 727 Transmission [Re: TJP] #2843011
11/07/20 12:40 PM
11/07/20 12:40 PM
moparx Offline
Buying your homeless and unwanted bolt on battery terminals
moparx  Offline
it looks like 71 was the year. i think the /6 cars were first, as i remember mopar action did an article one time and said the /6 PTK module could be used and would retrofit to earlier valve bodies.
the pics posted are from a B&M shift kit.
hopefully, they will help.
beer
Re: Need Help ID'ing a 727 Transmission [Re: moparx] #2843042
11/07/20 01:20 PM
11/07/20 01:20 PM
Rio Linda, CA
John_Kunkel Offline
The Erection Connection
John_Kunkel  Offline
Rio Linda, CA
No earlier than '67. '71 was the first year for the V8 PTK, '67 for the /6 PTK.
Re: Need Help ID'ing a 727 Transmission [Re: John_Kunkel] #2843048
11/07/20 01:32 PM
11/07/20 01:32 PM
moparx Offline
moparx  Offline
thanks for setting the record straight john.
now that you mentioned it, i remember the article said the /6 was first before 71, but i don't/didn't remember just how many years before.
at least the pics show what the PTK valve looks like and where it goes.
beer
