Re: Predator Engine [Re: dthemi] #2842131
11/05/20 01:19 PM
11/05/20 01:19 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Originally Posted by dthemi
We can still thank the 426 hemi for keeping the brand relevant. I watched all the 481X stuff be hailed as the next thing to overtake the hemi. Now I see them all coming out, and hemis going right back in lol.
Ain't that the truth of it......The Hemi rules in any class its allowed to run in.....I got to view a few of the new 4.9 Noonan ones, and man, that is next level stuff. Hoping that becomes more popular as well as the Goodwin Hemi's.....
And I totally agree on the Predator heads.....If they were priced a little lower, that would absolutely be the goto head for bigger power I am sure.
Re: Predator Engine [Re: dthemi] #2842904
11/07/20 09:59 AM
11/07/20 09:59 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Originally Posted by Dragula
Sombody said, to do the Predator right, you need to change the lifter bores on the Hemi block as well. What were they referring to, angle, or spacing? Does the stock Hemi layout work, or do you guys order a special Hemi block?
You don't have to change any of it, but you'll need a center bar lifter like the jesel ts tie bar if your block is 48 degree cam bank angle.
In a perfect world I'd do a 45 degree raised cam, +.5 deck block with the lifters spread .1 in each direction for a total of .2 spread. Going more than that on a stock config block will cause the lifters to hit the center cam bearing.
My first motor was built exactly like that, 604CI, Hemi block raised cam, 45* lifter angle, 2" spread, 55mm cam 7,4,3,2 swap. It lasted 27 runs as the dopes that built it didn't think an engine needed more than 40psi oil pressure. That was expensive! The right way to design one though was right, less the oil pressure.
Re: Predator Engine [Re: camastomcat] #2842906
11/07/20 10:02 AM
11/07/20 10:02 AM
Salt Lake City
camastomcat Offline
camastomcat  Offline
Salt Lake City
Yeah, any good head package costs that much. At some point you have to step up or step out.
Re: Predator Engine [Re: camastomcat] #2842917
11/07/20 10:34 AM
11/07/20 10:34 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Who has the fastest Predator headed door car
Re: Predator Engine [Re: FastmOp] #2842935
11/07/20 11:35 AM
11/07/20 11:35 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have heard there is one in this area that been high 4.40's NA supposedly. If so I would have to expect that's gotta be close if not best NA.
