oil psi gauge flutter #2840668
11/02/20 01:03 PM
11/02/20 01:03 PM
RapidRobert Offline OP
I used a regular 100 lb psi gauge on my sending unit port & it flutters quite abit. do oil psi gauges have a dampener to soften this & this flutter is normal with a generic gauge? thank you for your time
Re: oil psi gauge flutter [Re: RapidRobert] #2840686
11/02/20 01:30 PM
11/02/20 01:30 PM
Most of the stock and after market manual automotive oil pressure gauge have a very small hole in the inlet side on the back of the gauge, does yours? scope
I've use to use 1/4 I.D. lines to fed my manual oil pressure gauges in my old race cars, they reacted like a tach up scope
NHRA ban them, the larger I.D. lines, a long time ago whiney
Re: oil psi gauge flutter [Re: Cab_Burge] #2840693
11/02/20 01:38 PM
11/02/20 01:38 PM
it is still on there but I will check it & it has to come off to put the new OE sender on (old one was shot) & it is a grocery getter so I should be OK with just a light for the time being. It was scaring me as the light would come on randomly eek so I put the gauge on there that I had on hand & it turned out the OE sender was bad but I did see all the fluttering. Thanks Cab
Re: oil psi gauge flutter [Re: RapidRobert] #2840694
11/02/20 01:40 PM
11/02/20 01:40 PM
The gauge is talking to you about the varying oil pressure issue, FIX IT first twocents scope
Re: oil psi gauge flutter [Re: Cab_Burge] #2840700
11/02/20 01:48 PM
11/02/20 01:48 PM
what I gathered from your first post is that if the gauge does not have the small hole that fluttering is normal. right or wrong? I wont know until I pull it.
Re: oil psi gauge flutter [Re: RapidRobert] #2840704
11/02/20 01:57 PM
11/02/20 01:57 PM
AndyF Offline
AndyF  Offline
Do you have another gauge you can try? Sometimes gauges go bad.
Re: oil psi gauge flutter [Re: AndyF] #2840717
11/02/20 02:20 PM
11/02/20 02:20 PM
I do have another gauge that I will try.
Re: oil psi gauge flutter [Re: RapidRobert] #2840763
11/02/20 03:52 PM
11/02/20 03:52 PM
AndyF Offline
AndyF  Offline
I've seen mechanical gauges do all sorts of weird things. Flutter, read only partial pressure, read super slow, etc. I'm not sure what all the failure modes are but I've seen more than my share of them.
Re: oil psi gauge flutter [Re: AndyF] #2840937
11/02/20 08:46 PM
11/02/20 08:46 PM
Sounds like a person needs to use a quality one, no junk
Re: oil psi gauge flutter [Re: RapidRobert] #2841487
11/03/20 11:01 PM
11/03/20 11:01 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
The gauge damper is called a snubber. Without one it'll look like it has parkinsons
Re: oil psi gauge flutter [Re: dthemi] #2841627
11/04/20 11:21 AM
11/04/20 11:21 AM
it was jumping wildly over a 10-15 psi range & it has a good sized inlet
Re: oil psi gauge flutter [Re: RapidRobert] #2841633
11/04/20 11:43 AM
11/04/20 11:43 AM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Try an electric oil pressure gauge if you have access to one.
Re: oil psi gauge flutter [Re: RapidRobert] #2841762
11/04/20 04:20 PM
11/04/20 04:20 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
funny . mine started doing this a about 8 weeks ago . I use an Autometer only about 18 months old . I have a -6 line . Tried oil change ,then a different filter no change , opened filter no jewellry . Still has plenty pressure just the flutter .
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: oil psi gauge flutter [Re: tex013] #2841803
11/04/20 06:29 PM
11/04/20 06:29 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Don't know if this applies, but everytime I've seen a bouncing/ fluttering oil pressure gauge, it was due to a rod bearing going away??
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: oil psi gauge flutter [Re: 68LAR] #2841850
11/04/20 07:55 PM
11/04/20 07:55 PM
ma.
duspan Offline
duspan  Offline
ma.
hello if you are using the copper line for the gage an old trick is to put a couple loops in the line?
Re: oil psi gauge flutter [Re: duspan] #2841858
11/04/20 08:12 PM
11/04/20 08:12 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
. Yep. I do that. Learned that trick working on airplane engines.
Re: oil psi gauge flutter [Re: 68LAR] #2842101
11/05/20 12:11 PM
11/05/20 12:11 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
What they said...
