oil psi gauge flutter
#2840668
11/02/20 01:03 PM
11/02/20 01:03 PM
RapidRobert
I used a regular 100 lb psi gauge on my sending unit port & it flutters quite abit. do oil psi gauges have a dampener to soften this & this flutter is normal with a generic gauge? thank you for your time
Re: oil psi gauge flutter
[Re: Cab_Burge]
#2840693
11/02/20 01:38 PM
11/02/20 01:38 PM
RapidRobert
it is still on there but I will check it & it has to come off to put the new OE sender on (old one was shot) & it is a grocery getter so I should be OK with just a light for the time being. It was scaring me as the light would come on randomly so I put the gauge on there that I had on hand & it turned out the OE sender was bad but I did see all the fluttering. Thanks Cab
[Re: Cab_Burge]
#2840700
11/02/20 01:48 PM
11/02/20 01:48 PM
RapidRobert
what I gathered from your first post is that if the gauge does not have the small hole that fluttering is normal. right or wrong? I wont know until I pull it.
[Re: AndyF]
#2840717
11/02/20 02:20 PM
11/02/20 02:20 PM
RapidRobert
I do have another gauge that I will try.
[Re: AndyF]
#2840937
11/02/20 08:46 PM
11/02/20 08:46 PM
RapidRobert
Sounds like a person needs to use a quality one, no junk
[Re: dthemi]
#2841627
11/04/20 11:21 AM
11/04/20 11:21 AM
RapidRobert
it was jumping wildly over a 10-15 psi range & it has a good sized inlet
[Re: RapidRobert]
#2841762
11/04/20 04:20 PM
11/04/20 04:20 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
funny . mine started doing this a about 8 weeks ago . I use an Autometer only about 18 months old . I have a -6 line . Tried oil change ,then a different filter no change , opened filter no jewellry . Still has plenty pressure just the flutter .
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2841803
11/04/20 06:29 PM
11/04/20 06:29 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Don't know if this applies, but everytime I've seen a bouncing/ fluttering oil pressure gauge, it was due to a rod bearing going away??
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: duspan]
#2841858
11/04/20 08:12 PM
11/04/20 08:12 PM
68LAR
South Park, Pa.
hello if you are using the copper line for the gage an old trick is to put a couple loops in the line? . Yep. I do that. Learned that trick working on airplane engines.
[Re: 68LAR]
#2842101
11/05/20 12:11 PM
11/05/20 12:11 PM
Posts: 19,379 Las Vegas
Al_Alguire
Las Vegas
hello if you are using the copper line for the gage an old trick is to put a couple loops in the line? . Yep. I do that. Learned that trick working on airplane engines. What they said...
