Re: Does 440 source still make ultra lightweight cranks?
[Re: moparAL]
#2840448
11/02/20 12:10 AM
11/02/20 12:10 AM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Its the weekend and 440 source is closed. Does anyone know off hand if they have stopped producing there Ultra lightweight cranks. When I go to the website it says no item found. Thanks everybody. Lest we forget !! 775.883.2590 Monday-Friday 9am-5pm PST
[Re: 451Mopar]
#2842559
11/06/20 01:52 PM
11/06/20 01:52 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
I've run one in my RB with their 7.1 inch rods, and like how the motor rev's with such smoothness and ease. My pistons only weigh 524 grams, which I'm hoping will help ease the strain on the main caps etc.I forget what the total bob weight is though. I've had it apart once due to a valve train harmonic issues, and there was no sign of cap walk at that point. The block does have main studs and a Hughes girdle.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: jbc426]
#2842857
11/07/20 04:30 AM
11/07/20 04:30 AM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
Last 505" stroker using 440 block, Source 4.25" lightweight stroker crank, 7.1" H-Beam rods, and the 27cc dish pistons (TF240 heads, mild pump gas build.) The average piston weight was 591.2 grams, pins 141.1 grams, rods (overall) 814.7 grams, rod small ends 252.0 grams, rod big ends 562.7, Total bob weight came out to 2271.24 grams.
[Re: 451Mopar]
#2843882
11/09/20 10:12 AM
11/09/20 10:12 AM
Posts: 3,187 Md.
carnut68
Md.
I used an Eagle 4.25 crank and Eagle 7.1 rods with IC842-.055 piston from 440 Source. Piston/603.5 rods/ big end/607 small/236.8 pin/141. Bob weight 2368.8. Just some info for you.
America First!
[Re: moparAL]
#2844183
11/09/20 06:26 PM
11/09/20 06:26 PM
Posts: 741 Carson City, NV
440sourcedotcom
Carson City, NV
Its the weekend and 440 source is closed. Does anyone know off hand if they have stopped producing there Ultra lightweight cranks. When I go to the website it says no item found. Thanks everybody. They were out of stock for a little while, but we got them back in last week, so they are back up on the web store and available for purchase again.
