Does 440 source still make ultra lightweight cranks? #2840229
11/01/20 03:20 PM
11/01/20 03:20 PM
moparAL Offline OP
moparAL  Offline OP
Its the weekend and 440 source is closed. Does anyone know off hand if they have stopped producing there Ultra lightweight cranks. When I go to the website it says no item found. Thanks everybody.
Re: Does 440 source still make ultra lightweight cranks? [Re: moparAL] #2840448
11/02/20 12:10 AM
11/02/20 12:10 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Lest we forget !!
775.883.2590
Monday-Friday 9am-5pm PST
Re: Does 440 source still make ultra lightweight cranks? [Re: moparAL] #2842418
11/06/20 04:00 AM
11/06/20 04:00 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
looks like they have them for 4.25" stroke.
http://store.440source.com/4250-Stroke-Crankshafts/products/42/
If they don't have a lightweight version listed, call them. The crank supplier lists the lightweight cranks for both low and high deck engines in different stroke lengths.
Re: Does 440 source still make ultra lightweight cranks? [Re: 451Mopar] #2842559
11/06/20 01:52 PM
11/06/20 01:52 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
I've run one in my RB with their 7.1 inch rods, and like how the motor rev's with such smoothness and ease. My pistons only weigh 524 grams, which I'm hoping will help ease the strain on the main caps etc.I forget what the total bob weight is though. I've had it apart once due to a valve train harmonic issues, and there was no sign of cap walk at that point. The block does have main studs and a Hughes girdle.
Re: Does 440 source still make ultra lightweight cranks? [Re: jbc426] #2842857
11/07/20 04:30 AM
11/07/20 04:30 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Last 505" stroker using 440 block, Source 4.25" lightweight stroker crank, 7.1" H-Beam rods, and the 27cc dish pistons (TF240 heads, mild pump gas build.)
The average piston weight was 591.2 grams, pins 141.1 grams, rods (overall) 814.7 grams, rod small ends 252.0 grams, rod big ends 562.7, Total bob weight came out to 2271.24 grams.
Re: Does 440 source still make ultra lightweight cranks? [Re: 451Mopar] #2843882
11/09/20 10:12 AM
11/09/20 10:12 AM
Md.
carnut68 Online content
carnut68  Online Content
Md.
I used an Eagle 4.25 crank and Eagle 7.1 rods with IC842-.055 piston from 440 Source. Piston/603.5 rods/ big end/607 small/236.8 pin/141. Bob weight 2368.8. Just some info for you.
America First!
Re: Does 440 source still make ultra lightweight cranks? [Re: moparAL] #2844183
11/09/20 06:26 PM
11/09/20 06:26 PM
Carson City, NV
440sourcedotcom Offline
Carson City, NV
They were out of stock for a little while, but we got them back in last week, so they are back up on the web store and available for purchase again.
