Re: Mechanical Roller lifter suggestions.
[Re: Stanton]
#2836602
10/23/20 04:32 PM
10/23/20 04:32 PM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
I have those, I think that the new lifters are 99550's
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: AndyF]
#2836657
10/23/20 06:42 PM
10/23/20 06:42 PM
Posts: 3,253 Md.
carnut68
Md.
If it’s a street/strip build, then I first look at how many miles per year it will get driven...... and then determine if going to a SR makes sense for how the car will be used.
Then, if it looks like the ST is a viable option........along with the particular cam profile, spring loads, and rocker ratio........ determine how good the lifters need to be based on usage, initial cost, and replacement/rebuild time intervals. Low maintenance and pump gas are the main reasons i built another shortblock. Any 511 in an A body will be a handful. If you want low maintenance then go with a hyd roller rather than a solid roller. You'll give up some power above 6000 rpm but you most likely aren't going to take a 511 in an A body to redline very often anyway. I run hyd rollers in both of my cars for the same reason. The way the car is now it never sees the street. Its a 446 race gas only set up 590 cam so its not ideal for street driving. Best et 10.82 best mph 126.0.
America First!
[Re: carnut68]
#2837004
10/24/20 05:47 PM
10/24/20 05:47 PM
Posts: 3,253 Md.
carnut68
Md.
I'm not against solid roller at all. Checking lash is no big deal. I guess a better way to describe it would be turn key, load and go to track.
America First!
[Re: an8sec70cuda]
#2837871
10/27/20 07:52 AM
10/27/20 07:52 AM
Posts: 624 Deep DEEP SOUTH
LAD 524
Deep DEEP SOUTH
Isky Red Zone Extreme bushed rollers in mine, .730" net lift, 700lbs open,......lash never changes. Idling at 1100 - 1200 for oil splash. Oil is changed 2x per year, depending on the cars use; clean oil is supposed to be the mail thing to stay on top of with a bushed lifter. I have another near new set of the Isky Red Zones with needle rollers with little dyno use only - I might send them to Isky for conversion, I wonder if there is a contact for this, hmmm. So far, so good I asked them about converting mine from needle bearings to bushings a couple years ago and they said no problem. Costs around $700 IIRC. Thanks Chip, who is the best contact at Isky to contact? Ive done a few thousand kms on mine without issue. The Bullet roller Im using doesnt have super aggressive ramps/lobes', this is the key for a reliable mostly street, some strip mill.
[Re: LAD 524]
#2837873
10/27/20 08:03 AM
10/27/20 08:03 AM
Posts: 13,400 Marion, South Carolina [><]
an8sec70cuda
Isky Red Zone Extreme bushed rollers in mine, .730" net lift, 700lbs open,......lash never changes. Idling at 1100 - 1200 for oil splash. Oil is changed 2x per year, depending on the cars use; clean oil is supposed to be the mail thing to stay on top of with a bushed lifter. I have another near new set of the Isky Red Zones with needle rollers with little dyno use only - I might send them to Isky for conversion, I wonder if there is a contact for this, hmmm. So far, so good I asked them about converting mine from needle bearings to bushings a couple years ago and they said no problem. Costs around $700 IIRC. Thanks Chip, who is the best contact at Isky to contact? Ive done a few thousand kms on mine without issue. The Bullet roller Im using doesnt have super aggressive ramps/lobes', this is the key for a reliable mostly street, some strip mill. I want to say the guy I talked to was Richard? Not sure on that though.
[Re: an8sec70cuda]
#2837978
10/27/20 01:13 PM
10/27/20 01:13 PM
Posts: 43,300 Bend,OR USA
Cab_Burge
[quote=LAD 524] [quote=an8sec70cuda][quote=LAD 524] I want to say the guy I talked to was Richard? Not sure on that though. Richard Iskenderian is the younger brother of Ron. Richard has managed Isky for a lot of years now, he does good. Not so good results on ordering with Ron
[Re: Cab_Burge]
#2838100
10/27/20 08:00 PM
10/27/20 08:00 PM
Posts: 4,319 Prospect, PA
BSB67
Prospect, PA
[quote=LAD 524] [quote=an8sec70cuda][quote=LAD 524] I want to say the guy I talked to was Richard? Not sure on that though. Richard Iskenderian is the younger brother of Ron. Richard has managed Isky for a lot of years now, he does good. Not so good results on ordering with Ron Same, I think. One good, one not so good.
