Looking for 14" & 15" Trim Rings #2836585
10/23/20 04:01 PM
10/23/20 04:01 PM
North of the Motor City
DartGTDan Offline OP
My '71 Dart GT is wearing 14" X 5 1/2" (small bolt pattern) factory Rallyes up front and will be wearing 15" X 7" (also small bolt pattern) WheelVintiques Rallyes on the rear. I'm looking for matching chromed/polished (NOT BRUSHED) trim rings to fit. Who's products have you used?
Re: Looking for 14" & 15" Trim Rings [Re: DartGTDan] #2836604
10/23/20 04:42 PM
10/23/20 04:42 PM
Sault Ste. Marie, Ontario, Can...
moparmike1 Offline
moparmike1  Offline
Your best bet is probably the trim rings Wheel Vintiques offers:
https://www.wheelvintiques.com/accessories/trim-rings.html
Factory 14 inch trim rings were brushed but you want polished for the front so these should be what you're looking for:
https://www.wheelvintiques.com/accessories/trim-rings/14x6-oem-style-rounded-lip-trim-ring.html
For the rear, these should work:
https://www.wheelvintiques.com/accessories/trim-rings/7-o-e-m-style-trim-ring.html
Mike.
Re: Looking for 14" & 15" Trim Rings [Re: moparmike1] #2836747
10/23/20 09:33 PM
10/23/20 09:33 PM
Midwestern Indiana
duster2 Offline
duster2  Offline
Midwestern Indiana
You are probably not going to find an exact match. Mopars always use a stepped edge ring , never a smooth ring. Also the 15 inch version
used a small dime sized valve stem hole. The 14 inch used a much larger valve stem hole , rounded top and bottom , straight on the sides.
I have a couple 14 inch polished rings , but they dont match the polished 15 inch rings the Coker has , valve stem hole is different.
As I say an exact match , probably not, close , maybe.
Frank
